praegune kellaaeg 21.09.2026 07:05:13
17.05.2014 19:47:43
Uus turvateooria Hitachilt: Are your veins going to replace your PIN at the ATM? |
ATM access has traditionally been about you inserting your bank card and then entering your PIN - but that may be about to change.
Cash machines being rolled out in Poland are using a different form of identity verification developed by Japanese electronics company, Hitachi.
The new cash points, set to appear in 2,000 locations around the country, take a new approach to biometrics.
The infrared scanner on one of these new machines will literally get under your skin as it scans the veins inside your finger. The light from the scanner is partially absorbed by haemoglobin in the veins and returns a unique pattern which can then be matched to an existing profile.
Edasi juba lingilt:
http://nakedsecurity.sophos.com/2014/05/16/are-your-veins-going-to-replace-your-pin-at-the-atm/
Netist on näha, et see teema on üsna popp ja paljudel linkidel on ka üksjagu juttu.
Väike näide:
Forget fingerprints – banks are starting to use vein patterns for ATMs
New technology is thought to be as accurate in identifying individuals as iris scans and is making a European debut in Poland
http://www.theguardian.com/money/2014/may/14/fingerprints-vein-pattern-scan-atm
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
