praegune kellaaeg 21.09.2026 07:05:19
16.05.2014 11:47:13
Midagi jalgrattafännidele: Solar-powered Skylock smart bike lock offers security, sharing |
Velo Labs has come up with a bike lock that alerts owners to possible thefts, alerts emergency responders to possible crashes, and has a keyless entry that lets users share bikes Airbnb-style.
Skylock works in conjunction with a smartphone app, either iOS or Android. Users can use their phones to lock and unlock their bikes, add other users, and toy with the settings to receive alerts if their bike is jostled while out-of-sight. The theft alert system works with either Bluetooth or Wi-Fi. And, if the lock's internal accelerometer senses a severe impact while a rider is on the bike, it has the ability to alert emergency responders.
As far as the solar powered battery goes, just one hour of sunlight gives users enough power to last a week. Velo Labs says a fully charged battery lasts a month for most users.
Skylock isn't the first smart bike lock. Startup Mesh Motion unveiled the BitLock keyless bike lock during its Kickstarter campaign last October. BitLock also works with iOS and Android apps via Bluetooth. However, it doesn't use Wi-Fi and its battery is lithium rather than solar.
Terve jutt siis lingil:
http://www.cnet.com/news/skylock-the-keyless-solar-powered-smart-bike-lock/
LKits
ArturTT
18.05.2014 12:46:35
| LKits kirjutas: |
Tundub vägagi uhke vidin olevat. Loodan, et aku ilma toiteta peab ikka piisavalt vastu, sest päris nadi oleks jätta jalgratas kuhugi ööseks või hakata seda kallis värki läbi lõikama  |
T2islaetud aku pidavat kestma kuu aega. sellest oleks vist enam kui küll!?
Loodame et asi ei j22 j2rjekordselt stoppama nagu tavaliselt sedasorti projektidele tavaks... See ratta "tjuuningu" teema on l2inud paaril viimasel aastal ikka v2ga huvitavaks oma helios baride, copenhagen wheelide jms kraamiga kuid valmis ei taheta neid kuidagi saada...
LKits
ArturTT
18.05.2014 16:12:35
| LKits kirjutas: |
| Loodan, et turvasüsteem/krüpteering pole liiga lihtne, sest BT hijackida on ikka väga kerge... |
Tundub et pole probleemi, Meestel on piisavalt kogemuste pagasit korraliku produkti loomiseks:
http://www.linkedin.com/in/jackalkahwati
Huvitav kuidas varga ja crashi sensor lahendatakse? Ei tahaks iga rattast m66duva tegelase pärast teadet saada, samas ei tahaks ka avastada et keegi on mõnesaja dollarilised pedaalid,bari jms maha kruvinud
Nagu aru olen saanud siis crashi korral kutsutakse automaatselt abi? Reageerib asi vist tugevamale põrutusele? seega agressiivsema s6idu puhul v6id endale abi kutsuda
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
