praegune kellaaeg 21.09.2026 07:05:19
13.05.2014 22:47:42
USB ja Thunderbolti vaheline kiiruse-võidujooks jätkub: USB SuperSpeed will relegate Thunderbolt to a niche |
The new USB spec is expected to eventually scale throughput beyond 40Gbps
Computerworld - The USB SuperSpeed specification and accompanying hardware are about to undergo a number of major evolutionary makeovers that will leave little room for the Thunderbolt hardware interface to expand in the market.
Both USB SuperSpeed and Thunderbolt have recently undergone version upgrades - USB moved to v3.1 (SuperSpeed+) and Thunderbolt to v2. And both upgrades double the maximum throughput speed -- USB 3.1 to 10Gbps and Thunderbolt 2 to 20Gbps.
But, the USB SuperSpeed specification has a lot of elasticity built into it.
"This tech will scale well beyond 10Gbps," said Rahman Ismail, a USB 3.0 senior architect at Intel. "We believe we already have a protocol that will scale well past 40Gbps."
Other than speed, Thunderbolt 2 has another advantage over USB 3.1 - 10 watts of power compared with USB SuperSpeed's 4.5 watts.
Edasi lingil:
http://www.computerworld.com/s/article/9248291/USB_SuperSpeed_will_relegate_Thunderbolt_to_a_niche
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
