praegune kellaaeg 21.09.2026 07:04:47
13.05.2014 19:12:00
Adobe turvaprobleemid: Adobe Patches Acrobat, Reader, Flash and Illustrator |
Summary: Updates to Acrobat, Reader, Flash Player and Illustrator are for critical vulnerabilities and will be available today.
Adobe has issued a series of updates to address a large number of vulnerabilities in their products. All updated products have at least one critical vulnerability.
The update to Adobe Acrobat and Reader fixes 11 vulnerabilities in the Windows and Mac products. The update to Flash Player fixes five vulnerabilities in all versions of the product: Windows, Mac and Linux, including the versions embedded in Google Chrome and Internet Explorer. The Illustrator update addresses a single vulnerability in the Windows and Mac products.
Windows and Mac Acrobat and Reader users can get updates with the Help-Check for Updates option. Flash users can get their updates by downloading them from Adobe, but if they use a browser which has the update included in their browser.
These updates should be forthcoming from Google and Microsoft. Adobe's instructions for updating Illustrator are in this PDF.
http://www.zdnet.com/adobe-patches-acrobat-reader-flash-and-illustrator-7000029397/
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
