-vodafone-
12.05.2014 19:00:45
Pxelinux modifitseerimine - vaja abi. |
(Kustutasin eelmise teema)
Niisiis on mure Pxelinux serveris ISO´de ja grldr käivitamisega.
Skeem on hetkel selline, et androidi peal on ServerUltimate PXE teenus - tööjaamad leiavad PXE serveri ülesse ning vaikimisi seadistus ning funktsioonid kõik töötavad. Soovin lisada aga pxelinux.cfg alla oma valikuid ISO´de bootimiseks.
pxelinux.cfg conf: (esimesed 4 valikut on lisatud ise, ülejäänud on vaikimisi ja töötavad.
MENU TITLE Ice Cold Apps
TIMEOUT 600
#Add here your own labels with corresponding start commands!
LABEL Bootwim
MENU LABEL BOOT.ISO
APPENS iso
LINUX /tools/memdisk raw
INITRD /images/Boot.iso
LABEL Hirens
MENU LABEL Hirens
pxe keep
APPEND iso
INITRD /images/Hirens.iso
LABEL grldr
MENU LABEL Load grldr with PXE support
pxe keep
terminal console
chainloader --force --raw /grldr
LABEL grldr2
MENU LABEL GRUB4DOS menu (chain.c32 ntldr=)
TEXT HELP
This entry will bring you to the GRUB4DOS menu.
ENDTEXT
COM32 /tools/chain.c32
APPEND ntldr=/grldr
LABEL coldreboot
MENU LABEL Cold Reboot
COM32 tools/reboot.c32
LABEL warmreboot
MENU LABEL Warm Reboot
APPEND -w
LABEL poweroff
MENU LABEL Power Off
COM32 tools/poweroff.c32
LABEL hdt
MENU LABEL Hardware Detection Tool (HDT)
TEXT HELP
HDT is a module designed to display low-level information for any x86 compatible system.
ENDTEXT
COM32 tools/hdt.c32
label disk
MENU LABEL Disk
TEXT HELP
This will display some info about all hard disks it can find.
ENDTEXT
COM32 tools/disk.c32
label dmitest
MENU LABEL DMI Test
TEXT HELP
This can display some information about: Memory bank, Battery, BIOS, System, Base board, Chassis, CPU
ENDTEXT
COM32 tools/dmitest.c32
label meminfo
MENU LABEL Meminfo
TEXT HELP
This displays the output of the various memory size/range functions.
ENDTEXT
COM32 tools/meminfo.c32
LABEL sysdump
MENU LABEL Sysdump to TFTP Server
TEXT HELP
This is a diagnostic utility module that will gather certain system-specific data that can be used to help diagnose hardware-specific issues.
ENDTEXT
COM32 tools/sysdump.c32
APPEND tftp sysdump.cpio.gz |
Lisan pildi tftp serveri failipuust ning kohast, kuhu boot seisma jääb.
Oskab keegi nõu anda, mis valesti on? Kuidas saaks ISO´d bootima?
Edit: Postituse kirjutamise ajal oli ülaltoodud VM liikund edasi sellisesse seisu :
217 |
Omega
12.05.2014 19:48:01
Algatuseks ütlen kohe ära, et pole ise sellist asja kordagi kasutanud ja selle conf faili süntaksit ei tunne, aga mis silma jäi:
Trükivead: kumb on õige? APPENS iso või APPEND iso
Failide asukohad: pildi järgi ei asu need isod sugugi /images/ kaustas, vaid /SD Card/pxeserver/images/ juhul kui pildil on ikka terve kataloogi tee. Vaadates töötavaid punkte siis konfifailis võid kasutada ka kuju images/ (ilma alguse / -ta: nt nii INITRD images/Boot.iso ), kui täis teed ei taha kasutada. See punkt paistab kehtivat kõikide asukoha teede kohta, mille ise lisanud oled. - Failid ei asu seal, kus ütled need olevat konfi faili järgi.
| Kommentaarid: 22 loe/lisa |
21 |
-vodafone-
12.05.2014 21:04:22
Tänud vastamast!
Failide asukohad on arvatavasti õiged (memdiski leiab ülesse ja laeb ka ära - kirjutab real Loading /tools/memdisk... OK) Kaust pxeserver on süsteemi root kaust. Pilt on tehtud kogu androidi SDkaardi sisust.
Olen proovinud ka ilma alguse / -ta, kuid seis endiselt sama.
Hea tähelepanek selle trükivea osas - APPEND on õige. Kuid vaatamata sellele ei toimi kumbki ISO boot.
Edit: Eemaldasin trükivea, tegin ilma alguse / -ta .
Seis endine (lisasin kõik osad pildile):
217 |
Omega
13.05.2014 10:58:28
Siis tuleb ikkagi confi failist põhjust otsida.
Siin on juttu memdiski kasutamisest http://www.syslinux.org/wiki/index.php/MEMDISK Ehk on abiks.
Ka võimalik, et memdiski asemel tuleb hoopis mõnda teist meetodit kasutada. (memdisk laeb kõigepealt iso mällu ja siis üritab sealt bootida)
Kahjuks aga rohkem edasi aidata ei oska
21 |
Adebisi
13.05.2014 12:05:48
Hiren'si jaoks võid proovida
LABEL Hirens
MENU LABEL Hirens
kernel /tools/memdisk
append iso initrd=/images/Hirens.iso raw
Mille iso see teine muidu on? Mingi linuxline või winpe?
| Kommentaarid: 58 loe/lisa |
55 |
-vodafone-
13.05.2014 12:16:45
| Adebisi kirjutas: |
LABEL Hirens
MENU LABEL Hirens
Mille iso see teine muidu on? Mingi linuxline või winpe? |
WinPE
217 |
Adebisi
13.05.2014 12:21:51
| XP või kõrgema baasil?
55 |
-vodafone-
13.05.2014 12:31:55
| Adebisi kirjutas: |
| XP või kõrgema baasil? |
Kõrgem. win7 ja 8 jaoks
Eesmärk olekski eelkonfitud .wim imageid panna apply´ma võrgukettalt. Aga see tarkus oleks juba siis boot.wim(iso) sees.
217 |
Adebisi
13.05.2014 12:46:07
Praegu see toimida ei saanudki seetõttu, et sa andsid põmst windowsile linuxi tuuma ette
LABEL wimBoot
menu label WinPE
com32 linux.c32
append wimboot initrdfile=tools/bootmgr,tools/BCD,tools/boot.sdi,tools/boot.wim |
Vastavad failid muidugi tools kausta enne tõsta.
Kuna servers ultimate paistab pxelinux'it kasutavat siis võid probleemide korral googleldada näiteks pxelinux wimboot või syslinux winpe
55 |
-vodafone-
13.05.2014 13:54:00
| Adebisi kirjutas: |
LABEL wimBoot
menu label WinPE
com32 linux.c32
Kuna servers ultimate paistab pxelinux'it kasutavat siis võid probleemide korral googleldada näiteks pxelinux wimboot või syslinux winpe |
Proovisin kõik antud variandid läbi ning ikkagi on seis sama. Ei lae.
Jääbki ette Loading /images/Hirens.iso...
217 |
