praegune kellaaeg 21.09.2026 05:43:50
08.05.2014 22:08:20
Apple patenteerib: Future iPhones may use optical image stabilization to create 'super-resolution' images |
Apple Insider pajatab:
Documents discovered on Thursday show Apple is hard at work on tech to take iPhone picture quality to new levels, specifically a "super-resolution" imaging engine that uses optical image stabilization to capture multiple samples that are then stitched together to form an incredibly high-density photo.
With the iPhone already one of the world's most popular digital consumer cameras, Apple is looking to build on its lead in the sector with new technology that significantly boosts picture resolution without the need for more megapixels.
According to a patent application published by the U.S. Patent and Trademark Office on Thursday covering "Super-resolution based on optical image stabilization," Apple is testing out alternative and unique uses for existing OIS tech, a much different path than rival smartphone makers.
Edasine jutt ning pildid juba lingil:
http://appleinsider.com/articles/14/05/08/future-iphones-may-use-optical-image-stabilization-to-create-super-resolution-images
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
