praegune kellaaeg 21.09.2026 05:42:46
08.05.2014 09:29:09
ASRock Z97 Extreme6 Motherboard Capable of Supporting M.2 (NGFF) SSD With Speeds Up To 32Gb/s |
The SSD Review pajatab siis ASRocki "musklinäitamisest":
Intel Z97 based motherboards will be making their appearance very shortly and, once again, ASRock seems to flexing their muscle. If you remember their release of the Z87 series, they literally blew away competitors by releasing the Fatal1ty Killer AMD board with the worlds first native PCIe x2 M.2 socket, accomplishing the task of breaking that infamous SATA performance barrier (see report)
As if that wasn’t enough, their Intel based Z87 release of the Extreme 11/ac contained a whopping 22 SATA ports, the LSI SAS 3008 12Gb/s SAS controller, along with the LSI 3x24R expander which allowed the plugging in of 16 SATA or 8 SAS SSDs. Check out this report where we reached 6GB/s and 850K IOPS using 8 HGST 12Gb/s SAS SSDs.
Edasi juba lingil:
http://www.thessdreview.com/daily-news/latest-buzz/asrock-z97-extreme-6-motherboard-capable-supporting-pcie-gen-3-x4-ssd-32gbs/
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
