praegune kellaaeg 21.09.2026 06:21:22
06.05.2014 12:52:26
Testijad kiidavad: SanDisk Extreme PRO 128GB USB 3.0 Flash Drive Review – Speed, Security and a Lifetime Warranty |
Jäi silma üks testimine ning tundus huvitav. Ja eks igaüks siis ise saab edasi lugeda ja uurida neid teste.
The world of flash drives continues to change and, for the most part, many features we might like to see still aren’t present in today’s solutions. Simple software security that allows a secure folder to store sensitive data, apart from the normal storage area where we can throw daily data, comes to mind right away. And what about lifespan? Even today we wonder just how long our flash drive will really last and what type of performance drop we might see along the way. And then there is the issue of speed….
SanDisk has tried to change all of that with their new SanDisk Extreme PRO 128GB USB 3.0 Flash Drive and, taking a look at many of its features, someone seems to have finally been listening to what the consumer asked for. Our review will get into much more detail about things such as a very easy to use SanDisk Secure Access Vault, along with amazing speeds and a very well-built device, but perhaps the best thing SanDisk has included for consumer confidence is a lifetime warranty on the Extreme Pro. Thats right…a flash drive that will last as long as its owner and one that is 60x faster than any USB 2.0 flash drive.
Edasi juba lingil:
http://www.thessdreview.com/featured/sandisk-extreme-pro-128gb-usb-3-0-flash-drive-review/
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
