praegune kellaaeg 21.09.2026 06:20:56
30.04.2014 14:26:44
TechRadar.Pro kirjutab: Windows kernel exploit can bypass all security |
TechRadar.Pro kirjutab ning eks peagi näis, kas see tõstatud probleem ka mingi suurema paanika kaasa toob või mitte.
Security firm Bromium Labs has discovered a way to use an old Windows kernel exploit to bypass popular anti-malware and other security software.
The method, known as Layer on Layer (LOL) attacks, allow hackers to bypass multiple layers of security in one fell swoop, without anyone being the wiser.
The technique affects application sandboxes, anti-virus software, rootkit detectors, host-based intrusion prevention systems (HIPS), Enhanced Mitigation Experience Toolkit (EMET), and Supervisor Mode Execution Prevention (SMEP), even if they are stacked upon one another. The exploit will either disable them or bypass them completely.
The attack takes advantage of the EPATHOBJ Windows kernel vulnerability, which was discovered last year and largely ignored.
Exploiting the vulnerability gives a hacker system privileges, allowing them to turn off or otherwise disrupt security. Malware can then be run freely. Worse yet, the hacker goes unnoticed.
Edasi lingil:
http://www.techradar.com/news/software/operating-systems/windows-kernel-exploit-can-bypass-all-security-1245903
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
