praegune kellaaeg 21.09.2026 05:43:50
26.04.2014 09:20:02
Midagi uut "autopesu vihkajatele": Nissan’s self-cleaning car could kill off car washing forever |
Is the car wash a thing of the past? Nissan is testing a self-cleaning nanotech paint that repels dirt. Nissan describes it as a superhydrophobic and oleophobic paint, meaning it repels water and oils. A Nissan Note subcompact is being tested in Europe with half the car treated and the other half with just its normal paint. Photos and a Nissan video show the treated half is markedly cleaner.
Nissan says it’s the first automaker to use the technology, called Ultra-Ever Dry, on car bodywork, creating a protective barrier between the car paint and the outside world. It stops most water and grime from sticking and creating marks on the car. The Nissan Note is similar to the Nissan Versa Note sold here.
Edasi lingil:
http://www.extremetech.com/extreme/181370-nissans-self-cleaning-car-could-kill-off-car-washing-forever
AC7
27.04.2014 17:41:52
| Definitsioon ju vale. Tegu pole isepeseva autoga, vaid kattekihiga, mis hülgab paremini mustust. Btw selline asi väga ammu olemas ja on ka autosid sellega kaetud.(viidete otsimiseks liiga laisk hetkel)
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
