praegune kellaaeg 21.09.2026 05:42:46
24.04.2014 10:48:44
Jaapanlased leiutavad: Japan’s Plan for Centimeter-Resolution GPS |
Taas siis uus idee jaapanlastelt ning loodetavasti viivad nad selle idee ka ellu:
A $1.2 billion system of satellites and ground stations would give unprecedented accuracy
A stranger to Tokyo could easily get lost in its urban canyons. And GPS navigation, stymied by low resolution and a blocked view of the sky, might not be much help. But that won’t be the case after 2018. Engineers at Tokyo-based Mitsubishi Electric Corp. report that they’re on track to start up the first commercial, nationwide, centimeter-scale satellite positioning technology. As well as spot-on navigation, the technology will also usher in a variety of innovative new applications, its proponents say.
Named Quazi-Zenith Satellite System (QZSS), it is designed to augment Japan’s use of the U.S.-operated Global Positioning System (GPS) satellite service. By precisely correcting GPS signal errors, QZSS can provide more accurate and reliable positioning, navigation, and timing services.
Edasi lingil:
http://spectrum.ieee.org/aerospace/satellites/japans-plan-for-centimeterresolution-gps
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
