praegune kellaaeg 21.09.2026 05:43:39
18.04.2014 22:12:12
Computerworld pajatab: Satellite communication systems are rife with security flaws, vulnerable to hackers |
Researchers found critical vulnerabilities in satellite communications devices used in the defense, maritime, aerospace and other sectors
IDG News Service - Security researchers have found that many satellite communication systems have vulnerabilities and design flaws that can let remote attackers intercept, manipulate, block and in some cases take full control of critical communications.
Between October and December last year, researchers from IOActive analyzed the firmware of popular satellite communications (SATCOM) devices that are used in the military, aerospace, maritime, critical infrastructure and other sectors. The research covered products manufactured or marketed by Harris, Hughes Network Systems, Cobham, Thuraya Telecommunications, Japan Radio Company (JRC) and Iridium Communications. The analysis focused on SATCOM terminals that are used on ground, in the air and at sea, not satellite communications equipment in space.
"IOActive found that all devices within the scope of this research could be abused by a malicious actor," the IOActive researchers said in a report published Thursday. "We uncovered what would appear to be multiple backdoors, hardcoded credentials, undocumented and/or insecure protocols, and weak encryption algorithms."
"These vulnerabilities allow remote, unauthenticated attackers to compromise the affected products," the researchers said. "In certain cases no user interaction is required to exploit the vulnerability; just sending a simple SMS or specially crafted message from one ship to another ship would be successful for some of the SATCOM systems."
For example, vulnerabilities that IOActive claims to have found in mobile Harris BGAN terminals would allow attackers to install malicious firmware or execute arbitrary code. Such terminals may be used by the military to coordinate attacks between different units and are common within the forces of the North Atlantic Treaty Organization (NATO), the researchers said.
Lugu ise lingil:
http://www.computerworld.com/s/article/9247766/Satellite_communication_systems_are_rife_with_security_flaws_vulnerable_to_hackers
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
