praegune kellaaeg 03.08.2026 21:37:46
12.04.2014 16:11:09
4K ka odavamatele telefonidele ja tahvlitele: Allwinner bringing 4K video to smartphones and tablets |
Allwinner will ship its A80 board, which has eight ARM CPUs and 64 PowerVR graphics cores
Allwinner, one of the biggest providers of chips for low-cost smartphones and tablets, is stepping up its efforts to bring 4K video to handheld devices.
The Chinese chip maker will ship a development board in May that includes its new UltraOcta A80 processor, a powerful chip designed to enable playback of 4K video on portable devices without putting too much strain on battery life.
The A80 chip recently began sampling to smartphone and tablet makers, and the board is significant because it will allow developers to start testing applications that can take advantage of its capabilities.
Video with 4K resolution, also called Ultra HD, provides four times the resolution of today's best HD standard. 4K TVs, monitors and cameras are already available, but mobile devices today struggle to handle video of that quality.
The A80 is designed to handle 4K video at 30 frames per second while minimizing the work that the CPUs and GPUs have to perform, which helps conserve battery life.
Edasi lingil:
http://www.itworld.com/hardware/414307/allwinner-bringing-4k-video-smartphones-and-tablets
ricom2ger
12.04.2014 16:14:50
Mis ime lahendus see 64 tuumaline videolahendus on, PowerVR ei pakugi sellist lahendust?
_________________ Kamehameha in your face! |
Vael
14.04.2014 16:41:01
| 4k 7-10 tolli peal, asjalik. Enamus töö\kodu 20+tolliseidki monitore pole FHD edasi arnenud....
Braien
14.04.2014 17:00:40
Tegu siiski 4K video, mitte ekraaniga.
jtamm
14.04.2014 17:29:32
| Eks seda 4K video võimekust arendataksegi, et saata pilti 4K ekraanile.
rex
15.04.2014 13:05:44
Räägiti 720p ja 1080p videost. Viimane siis 1K / Full HD. Kui me sealt nüüd 2160p peale hüppame, oleks see ju justkui 2K? Või mis loogikaga peaks äkki hakkama laiuse ridasid lugema? Puhas maksimaalselt suurte numbrite jahil marketing? Üldine, mitte antud teema või selle algatajaga seotud küsimus, mis mulle juba mõnda aega rahu andnud pole.
Peopesast sellise pildi vahtimise hädavajalikkust ei viitsi isegi kommenteerida.
15.04.2014 13:22:02
| rex kirjutas: |
Peopesast sellise pildi vahtimise hädavajalikkust ei viitsi isegi kommenteerida. |
Tee mõned ja hakka harjuma, et aasta 2015 saabki olema selline äge 4K-ajastu, kus siis 4K ekraanid ja 4K videod igal pool ründama hakkavad. Ning siis selles valguses ka Sinu enda telefoni, läppari, tahvelarvuti ning televiisori ära vallutavad ja 4K pildi igale poole ette manavad.
Mina küll olen selleks valmis, et mõne aasta pärast on mul - kirjade järgi - 4K võimekusega telo taskus ja et saab sellist osta "veidi kallima võileivahinna eest".
rex
15.04.2014 13:52:54
Sa osta kõigepealt SSD.
Ega mul midagi arengu vastu ei ole, aga vinti kõvasti üle optimaalse keerata pole ka pointi. Tehniliselt pole kuigi keeruline ka 10-meetrist labidavart toota. Pikem, järelikult ka etem.
silver010
15.04.2014 17:28:26
| Alguses arvasin, et 5" 1080p ekraan on ka üle pingutatud ning mõttetu, teeb siis välja 445ppi, kuid kui satun vaatama 720p 4.7" ekraani (312ppi), siis tunnen koheselt meetri kauguselt vahe ära. Arvan, et tunneksin ära vahe ka 4K ja 1080p vahel, kuigi üle 300 ei tohiks inimsilm jutujärgi enam eristada.
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
