praegune kellaaeg 24.10.2026 10:31:54
09.04.2014 12:03:55
Uudis DDR4 maailmast: SK Hynix-lt 128GB DDR4 mälumoodul |
Lõuna-Korea pooljuhtide tootja SK Hynix demonstreeris hiljuti serveritele mõeldud 128GB mahuga DDR4 mälumoodulit. Kiirus on sellel 2133Mbit/s ning maksimaalne andmeedastuskiirus üle 64-bitise siini on 17GB/s.
Masstootmist loodetakse alustada järgmisel aastal, mil tulevad välja ka DDR4 toega emaplaadid.
SK Hynix unveils 128 GB DDR4 module
It may still be a few years before we see proper DDR4 adoption in the consumer space, but some memory manufacturers are certainly gearing up for the onslaught of motherboards supporting the improved memory spec. SK Hynix is one such company, today unveiling a DDR4 module with a massive capacity of 128 GB.
Based on Through Silicon Via (TSV) technology, the memory module uses SK Hynix's 20nm 8Gb chips, densely packed onto the standard-sized RAM unit. The module packs speeds of 2133 Mbps, and through a 64-bit wide bus can support transfers at 17 GB per second. It's also expected to be power efficient, operating at just 1.2V compared to the 1.5V required for DDR3.
It's no surprise that the 128 GB DDR4 module is destined for server applications, as its huge capacity will likely go unused in consumer systems for the time being. SK Hynix has mentioned that mass production of the modules will begin in 2015, coinciding with availability of DDR4-capable hardware.
Jutt edasi lingil:
http://www.techspot.com/news/56305-sk-hynix-unveils-128-gb-ddr4-module.html
211 |
heretic666
10.04.2014 23:57:03
| Selle aasta suvel tulev X99 chipset peaks olema juba ka DDR4 toega.
| Kommentaarid: 73 loe/lisa |
