praegune kellaaeg 21.11.2026 03:01:28
31.03.2014 20:35:38
Usinaks vaidlemiseks: U.N. Climate Report Warns of Increased Risk to Crops |
Jäi silma teema mis peaks sobima usinaks vaidluseks - aga vaadakse, et silmi siniseks ei löö.
Crop yields are expected to decline due to climate change faster than scientists thought.
A few years ago scientists thought climate change wouldn’t cause much harm to overall food production until temperatures in a region rose by three to four degrees Celsius compared to current levels. But in the latest United Nations report on climate change, released today, scientists have revised those estimates, pointing to significant losses with a temperature rise of just two degrees Celsius.
The report is part of the Fifth Assessment Report from the Intergovernmental Panel on Climate Change, a group of 837 researchers from around the world who assess and summarize the scientific literature on climate change. The fourth assessment report came out in 2007, and since then scientists have accumulated far more data, revised their computer models, and done more to study how factors such as changes in precipitation and extreme weather interact.
Changes in crop yield—the amount of produced per hectare—are only one part of the current report, which has over 30 chapters. But the changes in scientists’ estimates of how climate change will affect agriculture are some of the most remarkable in the report. The report, looking at the major food crops of corn, wheat, and rice, says that yields are likely to start decreasing by 2030 and decline up to 2 percent a decade (climate change seems to be affecting crops already, but so far this has been offset by improvements in crop yield). Such a reduction in yield is particularly worrying because demand for food is expected to increase in coming years, at a rate of about 2 percent a year.
Assessing how climate change will affect crops is tricky. Increased concentrations of carbon dioxide, changes in temperature and precipitation, the increased frequency of extremely hot days, and changing patterns of crop disease all play a role. In some areas, climate change could help improve production—growing seasons may improve in cold areas, for example. But scientists are finding that even with current levels of warming, the negative impacts of climate change are more common. And as the climate continues to change, the negative impacts are expected to get worse.
Kogu lugu lingil:
http://www.technologyreview.com/news/525891/un-climate-report-warns-of-increased-risk-to-crops/
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
