praegune kellaaeg 21.09.2026 05:44:38
26.03.2014 10:09:10
Tuuleelektri huvilistele: World's Highest Wind Turbine Will Hover Above Alaska |
Midagi siis ka tuuleelektri huvilistele:
The title for world's largest wind turbine is constantly up for grabs as manufacturers build higher and bigger to capture more energy from the passing air.
One turbine in Alaska, however, will now spin high above the rest. Altaeros Energies will launch its high-altitude floating wind turbine south of Fairbanks to bring more affordable power to a remote community. Ben Glass, CEO of Altaeros told The New York Times that the company expects to provide power at about $0.18 per kilowatt-hour, about half the price of off-grid electricity in Alaska.
Unlike its earth-bound brethren, the airborne turbine is not intended to supply power for large electric grids. Instead, its sweet spot is serving far-flung villages, military bases, mines, or disaster zones. Various researchers have been developing floating wind turbines for years, but the 18-month project in Alaska will be the first longer-term, commercial project to test the technology, according to Altaeros.
Altaeros’ Buoyant Airborne Turbine (BAT) is an inflatable, helium-filled ring with a wind turbine suspended inside. It will float at a height of 300 meters, where winds tend to be far stronger than they are on the ground. The altitude of the BAT is about double the hub height of the world’s largest wind turbine.
Edasi lingil:
http://spectrum.ieee.org/energywise/energy/renewables/first-commercial-floating-wind-turbine-hovers-above-alaska
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
