uus teema   vasta Uudised »  Turvalisus ja privaatsus »  Paljudest Asuse ruuteritest leiti ohtlik tagauks märgi kõik teemad loetuks
sõnum 23.02.2014 04:23:54 Paljudest Asuse ruuteritest leiti ohtlik tagauks vasta tsitaadiga
Chron nimelise blogi andmeil on tuvastatud, et paljudes Asuse ruuterites on leitud ohtlik tagauks, mille kaudu on suvalistel inimestel võimalik ligi pääseda su võrku ühendatud kõvaketaste sisule.
Probleemsed Asuse ruuterid:
    RT-AC66R Dual-Band Wireless-AC1750 Gigabit Router
    RT-AC66U Dual-Band Wireless-AC1750 Gigabit Router
    RT-N66R Dual-Band Wireless-N900 Gigabit Router with 4-Port Ethernet Switch
    RT-N66U Dual-Band Wireless-N900 Gigabit Router
    RT-AC56U Dual-Band Wireless-AC1200 Gigabit Router
    RT-N56R Dual-Band Wireless-AC1200 Gigabit Router
    RT-N56U Dual-Band Wireless-AC1200 Gigabit Router
    RT-N14U Wireless-N300 Cloud Router
    RT-N16 Wireless-N300 Gigabit Router
    RT-N16R Wireless-N300 Gigabit Router
According to the text message left on Jerry’s drive – and Lovett’s own research – the fix is to disable services that allow remote access to the router and the drives behind it, including FTP and Asus’ AICloud.
Allikas: http://blog.chron.com/techblog/2014/02/got-an-asus-router-check-your-hard-drive-for-a-warning/
HV-s ID-kaardiga autentimine
sõnum 23.02.2014 10:12:46 vasta tsitaadiga
Kui kõrvale muid allikaid lugeda, siis on näha, et turvaaukudest ollakse teadlikud juba nii 8 kuud. Kuid nendest probleemidest pole veel lõplikult jagu saadud.
Paar linki, kus siis seda teemat lahatakse:
1. 14 Jul 2013
Full Disclosure ASUS Wireless Routers Ten Models - Multiple Vulnerabilities on AiCloud enabled units
In June I released a partial disclosure for just the RT-N66U on the issue of directory traversal. I have only heard back from ASUS a twice on the issue, and I understand they are working on a fix.
However, no serious attempt to our knowledge has been made to warn their customers in the meantime, even after multiple requests from several different security professionals.
http://seclists.org/bugtraq/2013/Jul/87
2. February 19th, 2014
Asus router users still vulnerale to remote hacking
Asus routers are still vulnerable to remote hacking after months of the disclosure of the flaw that allows hackers to access to the device-connected drive.
Ars security portal reported that hackers expose eight-month-old weakness in Asus routers by leaving a message on victims’ drives. An Ars reader claimed to have found a strange message browsing the content of his external hard drive, the note was in a text file and advised him that he had been hacked thanks to a critical flaw in the Asus router he used to access the network storage.
http://securityaffairs.co/wordpress/22365/hacking/asus-router-users-still-vulnerale-remote-hacking.html
sõnum 23.02.2014 10:54:50 vasta tsitaadiga
Tanel kirjutas:
1) Ligi pääseb vaid kõvaketastele, mis on USB kaudu ühendatud ruuteriga.
2) Ligi pääseb vaid juhul, kui Ruuteris on lubatud kettale Ligipääs FTP kaudu või töötab AiCloud Teenus.
Antud juhul jääb aga mulje nagu saaks ligi suvalisele Asuse ruuteriga ühendatud NAS`ile või võrgukettale.
sõnum 23.02.2014 10:55:43 vasta tsitaadiga
Etz, ei ole eksitav ju ja Asus ise tunnistab viga. Ühtlasi näidatakse, kuidas tagauks ajutiselt sulgeda.
Ahto
Ahto
sõnum 23.02.2014 12:26:20 vasta tsitaadiga
Ka Linksys ruuteri omanikud peaks oma seaded üle vaatama.
Some Linksys routers targeted by TheMoon malware
Kommentaarid: 93 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 88
Forss
Forss
sõnum 23.02.2014 12:34:46 vasta tsitaadiga
Päris karmid turvaaugud ikka.
Enamus tavakasutajaid ei uuenda kunagi ruuteri tarkvara ja auklikke ruutereid jääb metsikult alles.
sõnum 23.02.2014 12:48:40 vasta tsitaadiga
Forss kirjutas:
Nojah - aga ega siis Asus ka ise selle 8 kuu jooksul niiväga midagi ette ei võtnud oma klientide teavitamisega. icon_cool.gif Ja nagu ühelt lingilt lugeda oli, üritati lappida ainult paar mudeli tarkvara, kuid ka need lapitud kohad ei kipu häkkereid kinni pidama.
Asus declared to have fixed the Vulnerabilities in RT-N66U, RT-N66R and RT-N66W Routers, but the attack suffered by the Ars reader demonstrates the existence of still vulnerable Asus routers.
PS: Ja kui nüüd meenutada, kui kõva reklaami tehti eelmisel aastal nendesamadele Asuse ruuteritele ja kui massiliselt neid kõikvõimalikesse kontoritesse ja kodudesse paigaldati, siis võib oletada ikka suuremat paanikat, mis nüüd lahti läheb ning kus siis võrkude ehitajad ning nende ruuterite müüjad kõvasti sebida saavad. icon_smile.gif
Forss
Forss
sõnum 23.02.2014 13:14:40 vasta tsitaadiga
tahanteada kirjutas:
Pigem enamusel on täiesti suva.
Ei mõelda üldse turvalisusele enne kui hilja.
Sama nagu backupide tegemisel.
"Ah ei viitsi aega raisata, praegu pole midagi juhtunud veel..."
mikk150
sõnum 23.02.2014 15:33:35 vasta tsitaadiga
Forss kirjutas:
ja juhtub, ning mitu korda kuus(2 korda kuus ketast vahetada on tore)
sõnum 23.02.2014 15:33:55 vasta tsitaadiga
DD-WRT peale. Fixed.
sõnum 23.02.2014 15:52:11 vasta tsitaadiga
SKG kirjutas:
Kauaks? Kuni leitakse ka seal turvaauk.
Ega need augud pole nagu Tallinna tänavail, et samm ja auk, pool sammu ja oi, näe, jälle auk. icon_lol.gif
Asjasthuvitatud pigem teevad tõsist tööd selle nimel, et neid auke leida. Loomulikult neist leidudest palju ei räägita.
sõnum 23.02.2014 17:05:06 vasta tsitaadiga
jägaja kirjutas:
SKG kirjutas:
Erinevalt stock softist uuendatakse seda tihti ja võimalus väiksem.
ftp://ftp.dd-wrt.com/betas/
sõnum 23.02.2014 17:32:10 vasta tsitaadiga
SKG kirjutas:
jägaja kirjutas:
SKG kirjutas:
Igasugu uuendamine ja DD-WRT pealeajamine on tavaliselt ikkagi tavainimeste hobi oma ruuteri tarkvaraga mässata. icon_smile.gif
Antud probleemsed N-mudelid ja AC-mudelid on kallimast hinnaklassist ning selliseid ostavad tavapäraselt enamjaolt firmad, mitte eraisikud.
Ning siis nii, nagu ruuter ostes on, on ta ka siis aastaid firmakontoris tööd rabamas.
PS: Aga nagu öeldud, praegu puhtalt Asuse enda probleem, et 8 kuuga pole suudetud auke ära lappida ning ka nüüd ei pakuta ju tegelikult mingit lõplikku lahendust välja. Seega saaga jätkub edasi.
sõnum 27.02.2014 11:55:29 vasta tsitaadiga
SKG kirjutas:
Üleval toodud nimekirjast on esmapilgul vaid kolmel mudelil DD-WRT supporditud. Ehk not fixed.
Kommentaarid: 765 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 571
sõnum 27.02.2014 13:28:33 vasta tsitaadiga
SKG kirjutas:
jägaja kirjutas:
SKG kirjutas:
Aga ara siis massa. Lase peale, kui on stabiilne, siis jata kaima ja kaib aastaid.
Betamax kirjutas:
SKG kirjutas:
Taiesti voimalik, samas saab ainult end syydistada kui enne ostu piisavalt eeltood ei teinud...
sõnum 27.02.2014 13:30:42 vasta tsitaadiga
Eeltööd, et millise ruuteri originaaltarkvaral võib kunagi turvaauke leiduda? Sebid kusagilt softi ja ajad sõrmega koodis järge?
M: HP Elitedesk 800 G3 SFF
sõnum 27.02.2014 14:01:20 vasta tsitaadiga
Betamax kirjutas:
sõnum 27.02.2014 14:18:48 vasta tsitaadiga
Ega need pole ainsad ruuterid, kui sa just ASUSe fänboi pole.
sõnum 27.02.2014 14:32:08 vasta tsitaadiga
http://www.dd-wrt.com/wiki/index.php/Supported_Devices_802.11n
http://secure.dd-wrt.com/wiki/index.php/Supported_Devices
http://www.dd-wrt.com/site/support/router-database
sõnum 27.02.2014 15:10:19 vasta tsitaadiga
Sa järjekindlalt üritad alahinnata tarbija laiskusindeksit.
Draqula
sõnum 27.02.2014 15:34:01 vasta tsitaadiga
Ahto kirjutas:
See uudis juba mõnda aega väljas, kuid Linksysi poolt parandust pole ikka tulnud.
Mnator
sõnum 27.02.2014 16:27:54 vasta tsitaadiga
ega tulegi ilmselt
sõnum 27.02.2014 16:36:16 vasta tsitaadiga
Kodukasutajale moeldud ruuterite tootjapoolne kasutajatugi on yldjuhul vaga halb. Bugfixe voibki ootama jaada, feature requestidest ei hakka yldse raakimagi.
Juba selle tottu tuleks algselt 3rd party toega karp valida. Kui seda pole tehtud, siis koige oigem olemasolev maha arida ja miskit asjalikumat asemele osta.
sõnum 27.02.2014 16:59:32 vasta tsitaadiga
SKG kirjutas:
Vaata - küsimus pole üleüldse niiväga kodukasutajates, kuna selliseid kallima hinnaga N-toega ning AC-toega ei osteta veel massiliselt kodudesse, vaid neid paigutati massiliselt enamjaoilt ikkagi kõikvõimalikesse firmadesse.
Seega on see ikkagi praegu enamjaolt WiFi-firmade probleem käia oma klientide juures ja siis vastavad turvaaugud peale panna. No ei hakka ju firmadirektor või Nõukogu esimees mingeid ruutereid uuendama. icon_smile.gif Tal on selleks palgatud IT-hooldusfirma, kes sellega tegeleb.
PS: Hiljuti arvutasin, et palju läheks maksma kodutehnika üleviimine AC-standardile. Summa tuli sadades eurodes, no ei pane mind miski jõud veel sellist kulutust tegema. Kui hinnad kukuvad nii poole võrra, siis mõtlen edasi, et kas võtan juba ette selle kulutuse.
sõnum 27.02.2014 17:29:33 vasta tsitaadiga
SKG kirjutas:
Cisco, Juniper, Palo Alto jms entry level kraam ei maksa nüüd nii palju, et peaks firmasse ASUS ja Linksys crap-i ostma. Jah, koju kolbab ja sinna ta ongi moeldud.
Tuleks siis seda IT-hooldusfirmat vahetada kui nad sellist jama teevad voi neile rohkem maksta, mitte kokku hoida kohast, kust seda tegma ei peaks.
sõnum 27.02.2014 21:11:47 vasta tsitaadiga
Suvalisteks Access Pointideks ei hakka sul ükski firma Junipere või Ciscosid ostma, va need, kel muidugi pappi jalaga segada ning IT eelarve suurem kui Eesti Vabariigil.
napoleon
Unknown virus
napoleon
sõnum 14.03.2014 15:05:01 vasta tsitaadiga
Hmm... võibolla peaks see eraldi uudis olema, aga täna avastasin juhuslikult, et Asuse tahvlis on ka backdoor. Peale update'i ütles utiliit ise, et uuenduse ajalugu näed devicetracker.asus.com lehelt. Läksin siis huvi pärast vaatama ja oma üllatuseks avastasin, et seal saab tahvlit positsioneerida, helisema panna ja andmeid kustutada. Kontaktid ja sõnumid on ka juba link olemas, aga neile klikates teatatakse coming soon. Kui peaksin tahvli ära kaotama või see varastatakse, siis on ju iseenesest tore, AGA:
1. seadme poolt ei pea midagi tegema ja seda teenust ei saa deaktiveerida. See tähendab, et Asus ise saab igal ajal mind positsioneerida, kui wifi või 3g sisse on lülitatud. Seade ei anna ekraanil ka mitte mingil moel märku, et positsioneeriti, ainuke mille järgi aru võib saada on see, et kui gps pole sisse lülitatud, lülitatakse see luba küsimata sisse.
2. seal lehel konto loomiseks on vaja teada vaid seadme seerianumbrit. Seda saab vaadata menüüst, samuti on see karbi peal kirjas. Ehk tegelikult ei ole selle teadasaamine väga keeruline, ma ei seisa ju paranoiliselt selja taga, kui keegi korraks tahvlit küsib, samuti teab seda seadme müüja ja teoreetiliselt võib näha ka suvaline inimene kui karp käes poest välja astun.
No krt, kas tõesti ei tehtagi enam seadmeid, millega ei pea häkkima, et nad luba küsimata "koju" ei helistaks.
Selle kohta on natuke juttu ka siin http://forum.xda-developers.com/showthread.php?t=1833442
enterprice
enterprice
sõnum 21.03.2014 12:34:20 vasta tsitaadiga
Tanel kirjutas:
Kus seda näidatakse, mul ka üks selline kodus. Ei kasuta küll ftp ega cloudi õnneks ja ketas pole ka igapäevaselt küljes.
Kommentaarid: 106 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 98
K3ndu
K3ndu
sõnum 21.03.2014 12:45:26 vasta tsitaadiga
napoleon, https://www.google.com/android/devicemanager?u=0 pole midagi uut ju?!
Kommentaarid: 135 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 125
ThedEviL
ThedEviL
sõnum 21.03.2014 14:24:31 vasta tsitaadiga
No isegi cisco mitte niiväga entry level kraam on sama s*tt kui linksys või isegi kategooria hullem kui TP-link ja buffaika.
Tagauksi leidub kõiges. Ka dd-wrt on pidanud seda tunnistama. Openwrt samuti. Iga levinud ehk igavlevatele patsiga poistele atraktiivne seade omab tagaust.
