praegune kellaaeg 11.11.2026 10:30:52
rayos
16.02.2014 19:22:58
Paluks Macro abi |
Teema tegelikult lihtne : on 6 erinevat vihikut(vihik1;vihik2 jne) iga vihiku 1 lehest oleks vaja teha koopia. Peab tekkima vihik kus on kõikide vihikute 1 lehed järjestikuste sheetidel ja sheetid tuleb nimetad vihiku nr järgi.
Macro1 Macro
Sheets.Add After:=Sheets(Sheets.Count) // loob mulle nii mitu lehte ma soovin teiste vihikutest tuua
Workbooks.Open Filename:= _
"C:\Documents and Settings\A\Desktop\Test\Vihik1"
Windows("Vihik1.xlsx").Activate
Sheets("Leht1").Select
Cells.Select
Selection.Copy
Windows("Macro.xlsm").Activate
ActiveSheet.Paste // kleebib suvalisele lehele
Range("A1").Select // tervest lehest oleks koopiat vaja
Sheets("Leht1").Name = "Vihik1"
'Application.CutCopyMode = False
ActiveWindow.Close
viimati muutis rayos 17.02.2014 17:06:51, muudetud 1 kord |
alfreedo
16.02.2014 23:04:33
Ehk on abiks.
Sub Copy_Lehed_kokku()
Dim fso As Object, fld As Object, Fil As Object
Dim FilePath As String, fName As String, SubFolderName As String
Dim wb As Workbook, Wkb1 As Workbook
Dim SheetC As Integer
Dim Ipos As Long
Application.ScreenUpdating = False ' et ekr-l ei vilguks
Set wb = ActiveWorkbook ' s.o. fail kuhu andmed tuuakse
Sheets(1).Select
Set fso = CreateObject("Scripting.FileSystemObject")
SubFolderName = ThisWorkbook.Path
FilePath = ActiveWorkbook.Path
If Right$(FilePath, 1) <> "\" Then FilePath = FilePath & "\"
Set fld = fso.GetFolder(SubFolderName)
For Each Fil In fld.Files
If Fil.Name <> ThisWorkbook.Name And Left(Fil.Name, 1) <> "~" Then
fName = Fil.Name 'ka uue lehe nime jaoks
Application.DisplayAlerts = False ' keelab hoiatusaknad nagu: ...wbk sisaldab makrosid.... jne
Set Wkb1 = Workbooks.Open(FilePath & fName, UpdateLinks:=0)
Wkb1.Activate
'eemaldame faililaiendi
fName = Trim(fName)
Ipos = InStr(fName, ".")
fName = Left(fName, Ipos - 1)
'Sheets(1) s.t. et copy-takse sõltumata lehe nimest Wbk-i esimene sheet.
Sheets(1).Activate
Wkb1.Sheets(1).Copy After:=wb.Sheets(wb.Sheets.Count)
ActiveSheet.Name = fName
Wkb1.Close
wb.Save
End If
Next Fil
Sheets(1).Activate
Application.ScreenUpdating = True
Application.DisplayAlerts = True
'puhastame mälu
Set wb = Nothing
Set fld = Nothing
Set Wkb1 = Nothing
MsgBox "Done"
End Sub
Pane see kood .xlsm faili ja jooksuta.
.xlsm fail peab asuma samas kaustas, kus "vihikudki".
.xlsm failis ei tohiks olla vihikutenimelisi Lehti.
rayos
17.02.2014 17:18:20
Ole sa tänatud
alfreedo
20.02.2014 21:45:42
rayos.
Mul küll toimib ka formaadi copymine.
