praegune kellaaeg 24.10.2026 19:59:34
johnnypro
02.02.2014 23:46:47
Läpakas |
| Nimelt mul selline probleem, et mu läpakal Dell Inspirion N5110l on selline probleem, et lihtsalt vahest hakkab ekraan virvendama ja arvuti hakkab pinisema. Ei oska täpselt seda häält kirjeldada ja teine probleem on see, et Wi-Fist logib lihtsalt välja, näitab, et wifi võrk pole saadaval ja enne netti tagasi ei saa, kui restart on tehtud. Probleemid tekkisid peale seda kui ajasin kohvi arvuti peale.
Mnator
03.02.2014 09:28:33
| osta uus
kakukeo
03.02.2014 10:52:49
| see,et sa seda oled edasikasutanud on jah asja ysna kindlalt taastamatuks teinud
Märt.
03.02.2014 17:54:59
| Mnator kirjutas: |
| osta uus |
...kohv...
kirill113
03.02.2014 19:08:34
kontrolli kaablid üle, ja kui see ei aita siis kas oled mingit tarkvara peale lasnud hiljuti?
variant B:
To isolate the issue between hardware and software, run the hardware diagnostics test. Please find the steps below to run the test.
- Press the power button to turn on the system
- Hit F12 repeatedly to get the Boot menu.
- Select diagnostics.
and wait for the test to complete. In case screen flickers or you get multiple lines while running the test that means LCD is faulty. Check the Vertical lines on BIOS screen as well.
Steps to go to BIOS screen
- Hit F2 repeatedly to get the BIOS screen and check whether you are getting vertical lines there or not.
Kindly update the BIOS and Video driver from dell support website. Please find the steps below for the same.
Link:- http://dell.to/16dKcJN
1) Enter the Service Tag and press submit button. ( You can find the service tag at the bottom of the laptop on white sticker, it’s a seven digit alphanumeric code which ends with BS or number 1.)
2) Click on Drivers and Downloads.
3) Choose the Operating system.
4) Click on video and BIOS option and update the driver .
In case of any further assistance Please feel free to contact me directly by sending a reply to this blog.
We would recommend you do not post your private information on a public forum.
Thanks and regards,
Kaveri D
#iworkfordell
JOKKER666
04.02.2014 00:09:30
| Kui kohvi ikka peale aetud, tuleb asi lahti võtta ja puhastada. Äkki juhtub ime ja emaplaat jäi ellu.
viljar77
04.02.2014 21:38:32
Eks selle kohvi ja probleemide vahel mingi seos võib isegi olla
Sellisel puhul alati arvuti kinni, aku küljest ja puhastusse. Nii on märksa suurem tõenäosus, et see töötab veel aastaid. Kui see jätta puhastamata, siis tihti juhtub nii, et mõne aja pärast on täiesti surnud. See kohv põhjustab emaplaadil oksüdeerumise ja ühel hetkel ongi vaikus.
_________________ Varuosad väga paljudele erinevatele sülearvutitele. Täpsema info saamiseks saada mulle PS.
Süle- ja lauaarvutite remont ja hooldus. |
