uus teema   vasta Hinnavaatlus »  Bitcoin ja muud krüptorahad »  Üldine arutelu ja krüptorahadega seotud uudised märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 119, 120, 121 ... 172, 173, 174  järgmine
flake
sõnum 06.02.2018 00:29 vasta tsitaadiga
Ma eeldan et see sait on kõigile tuttav? https://cryptopanic.com/
anubis
anubis
sõnum 06.02.2018 09:52 vasta tsitaadiga
https://arstechnica.com/tech-policy/2018/02/tether-says-its-cryptocurrency-is-worth-2-billion-but-its-audit-failed/
For months, critics have raised questions about Tether, a cryptocurrency whose value is supposed to be "tethered" to the United States dollar. The company behind Tether claims to have a dollar in the bank for every tether that's in circulation. And the Tether website claims that these cash holdings are "subject to frequent professional audits."
But those "frequent professional audits" have been slow in coming. The accounting firm Friedman LLP had been working on an audit of Tether and Bitfinex—a cryptocurrency exchange that is closely linked to Tether—since May. But last Saturday, Tether admitted to Coindesk that its relationship with Friedman had "dissolved."
"Given the excruciatingly detailed procedures Friedman was undertaking for the relatively simple balance sheet of Tether, it became clear that an audit would be unattainable in a reasonable time frame," a Tether spokesperson told Ars by email.
flake
sõnum 06.02.2018 10:21 vasta tsitaadiga
Tether on eilne uudis. Samuti.. 2 miljardi "turuväärtusega" token ei oma ju erilist mõju turule kus pöörleb virtuaalselt mõnisada miljardit dolalrit. aga noh. inimesed on lambad.
anubis
anubis
sõnum 06.02.2018 10:28 vasta tsitaadiga
Kui see paar miljardit on kasutatud BTC hinna ülespumpamiseks siis ikka on küll oluline mõju.
flake
sõnum 06.02.2018 10:30 vasta tsitaadiga
Väidetavalt siis SECi tänane avaldus on et ICOd vajavad regulatsiooni aga muidu krüptod on Iz go.
https://www.reddit.com/r/Tronix/comments/7vlwv9/the_sec_isnt_going_to_crack_down_at_all/
Täis source siis siin: https://www.banking.senate.gov/public/_cache/files/a5e72ac6-4f8a-473f-9c9c-e2894573d57d/BF62433A09A9B95A269A29E1FF13D2BA.clayton-testimony-2-6-18.pdf
anubis
anubis
sõnum 06.02.2018 10:55 vasta tsitaadiga
flake kirjutas:
Siin see 2 miljardit ongi, BTC top3 2/3 on USDT paariga. Kui nüüd selgub, et USDT on mänguraha millel pole katet siis sõidab BTC ja krüptoturg tervikuna mudaliigasse paariks aastaks.
Viilutaja
Viilutaja
sõnum 06.02.2018 12:14 vasta tsitaadiga
flake kirjutas:
See on tegelikult väga hea ja positiivne uudis, et mingi regulatsioon tuleb ICO'le.
Kuid siin on üks aga. Kardetakse, et tehakse nii, et ainult akrediteeritud firmad ja/või isikud saavad osaleda ICO'des- tehakse ainult ligipääsetavaks superrikastele ja pööbel süüakse välja...
Loodetavasti nii ei lähe ja lihtsalt ICO peab saama SEC approved templi lihtsalt juurde oma Whitepaperile thumbs_up.gif
Kui see viimane variant siis alles hakkab suuremat raha sisse tulema, sest usaldus on saavutatud suuremate korporatsioonide silmis.
viimati muutis Viilutaja 06.02.2018 12:19, muudetud 1 kord
anubis
anubis
sõnum 06.02.2018 12:16 vasta tsitaadiga
Kui aferistidest lahti saab siis sektoril helge tulevik.
“Always remember that the crowd that applauds your coronation is the same crowd that will applaud your beheading. People like a show.” - sir Terry Pratchett
Viilutaja
Viilutaja
sõnum 06.02.2018 12:18 vasta tsitaadiga
anubis kirjutas:
flake kirjutas:
Kust sa võtad, et paariks aastaks on mudas BTC? Halvimal juhul kukub BTC tagasi 1000-2000 euro vahemikku, mis kohe kindlasti pole mudaliiga. Ning 2018.a. lõpuks on see kindlasti tõusnud 2-6x. Tõuseb aeglasemalt, kuid kindlamalt ja vähemate swingidega.
elukaz
elukaz
sõnum 06.02.2018 12:32 vasta tsitaadiga
Kuskohas see kaks miljardit seal on? Käibe suurus sõltub ju otseselt perioodi pikkusest, see on kauplemisaktiivsus korda aeg. See on nagu kW ja kWh omavahel segi ajada. Mõnel mündil on 24h volum olnud suurem kui marketcap.
sukelduja
sukelduja
sõnum 06.02.2018 12:34 vasta tsitaadiga
Viilutaja kirjutas:
anubis kirjutas:
flake kirjutas:
Millest see 1000-2000 hinnang? Kuidagi palju on. Mis asi peaks tegelikult sellist tõusu tekitama?
Viilutaja
Viilutaja
sõnum 06.02.2018 12:37 vasta tsitaadiga
sukelduja kirjutas:
Viilutaja kirjutas:
anubis kirjutas:
flake kirjutas:
Vaatan lihtsalt hetkel BTC ajaloost, kus on kõige suurem support olnud. See on hetkel kõige mustem stsenaarium (kui välja jätta see, et hind läheb 0 ja krüptoga on kõik- ebatõenäoline).
Kuid mina ise olen arvestanud selle mustema stsenaariumiga. Samas nüüd on see hetk mida ma varem endale ütlesin- "magasin õige hetke maha, et osta". Elus ei anta tihti uusi võimalusi.
Tuleb kinni haarata.
anubis
anubis
sõnum 06.02.2018 12:47 vasta tsitaadiga
elukaz kirjutas:
Jah. Ma saan aru, et see ei ole päriselt see summa. Kuid probleem pole selles - probleem on, et USDT on kahtlane münt mis väidab, et nad on 1-1 reaalse USDga kaetud. Kui seda kasutatakse ilma reaalse väärtuseta krüptomulli ülespuhumiseks (sest suurimad mahud BTCd liiguvad BTC/USDT paaris) siis on kogu see mull veel suurem kui ta praegu välja paistab. Valerahaga on mull üles puhutud, ju , seljuhul.
Viilutaja
Viilutaja
sõnum 06.02.2018 12:55 vasta tsitaadiga
Jah, samas on USD ka kahtlane valuuta. Mida vajadusel lihtsalt juurde trükitakse. Keegi ei virise seal sest liiga paljud kasutavad seda.
Lisaks ka see, et alates 1960'dest alates ei ole USD tagatud enam ühegi reaalse väärtusega. Kuni selle hetkeni oli US dollar seotud kullaga. Edaspidi on ainult olnud ausõna peal see väärtus...
Praegu oleks justkui olukord kus pada näitab näpuga katla peale: "Sa oled räpane ja must" icon_biggrin.gif
elukaz
elukaz
sõnum 06.02.2018 12:58 vasta tsitaadiga
anubis kirjutas:
elukaz kirjutas:
Paljud börsid ei kauple dollariga ja esimene loogiline variant ongi selle asemel tetherit kasutada nii et skämm ei ole ainus mis käivet teeb.
anubis
anubis
sõnum 06.02.2018 12:59 vasta tsitaadiga
USD omab siiski reaalset väärtust seniks kuniks see riik püsib.
sukelduja
sukelduja
sõnum 06.02.2018 13:01 vasta tsitaadiga
Viilutaja kirjutas:
USD tagatiseks on siiski USA majandus ( ja mõnel määral ka sõjaline jõud ). USA ei saa ilma üliränkade tagajärgedeta lasta oma valuutat rämpsuks muutuda. Bitcoini tagatiseks on täpsemalt mis?
Viilutaja
Viilutaja
sõnum 06.02.2018 13:11 vasta tsitaadiga
sukelduja kirjutas:
Viilutaja kirjutas:
Detsentraliseeritud maksed, kiired ülekanded ükskõik kellele, ükskõik kuhu vs tavaline valuuta. Inimesed kellel pole panka tavamõistes või ligipääsu sularahale (kõik 3'nda maailma riigid). Neil oleks reaalne võimalus teenida väärtust ja seda edasi maksta, kasutades ühte seadet mis on ka neil olemas- mobiil.
Põhimõtteliselt oleks igapäeva pangandus olemas sul mobiilis, ning pole vaja vahemeest ehk panka. Ning teadmine, et see 21miljonit on maksimaalne valuuta ühik mis on ringluses ja keegi kunagi juurde trükkida ei saa, et selle väärtust langetada.
Ala mingid keenia ja muu aafrika riigi 200 000 000 000 mln numrilised rahatähed.
sukelduja
sukelduja
sõnum 06.02.2018 13:23 vasta tsitaadiga
Viilutaja kirjutas:
sukelduja kirjutas:
Viilutaja kirjutas:
See ei ole tagatis, see on müügijutt. Nende miljonite kolmanda maailma riikide kodanike teenindamiseks pole tegelikult võimalusi, nagu pole ka nendel inimestel raha kõrgeid teenustasusid maksta. Neid huvitavad meie mõistes mikrotransaktsioonid, milleks bitcoin absoluutselt ei sobi.
riaak
riaak
sõnum 06.02.2018 13:25 vasta tsitaadiga
Viilutaja, miks BTC ja mitte nt pea igat pidi parem ETH?
BTC on dinosaurus, mis tuleks põhja lasta.
¯\_(ツ)_/¯
Wiltz
sõnum 06.02.2018 13:30 vasta tsitaadiga
isegi üldiselt nõus jah. samas btc on endiselt kahjuks või õnneks see, kus on nähtavasti kõige suuremal määral nö. reaalset raha sees...ka siis kui igasugused valerahad ja shady business välja jätta. ja paraku kui praegu vaadata siis kõigi krüptode väärtus kukub rõõmsalt täpselt ühes ja samas tempos btc'ga kolinal ja mürinal.
villu70
villu70
sõnum 06.02.2018 14:00 vasta tsitaadiga
Vahest loed siin ja hoiad pead kinni.... what da hell, mis toimub .... et kas tõesti võib mõni inimene nii loll olla. icon_lol.gif
... ma annaks oma 15a. tütrele vastu pead, kui idioodi juttu ajaks. icon_evil.gif
Viilutaja
Viilutaja
sõnum 06.02.2018 14:11 vasta tsitaadiga
sukelduja kirjutas:
Miks ei ole võimalusi? Nutitelefon on tänapäeval püksata neegril ka Aafrika südames ning pakun, et mingites keskustes on ka olemas 3G/4G võrk. Kes mainis bitcoini mikrotransaktsioonideks? Siin käib jutt ükskõik millisest krüptost!
Ma olen aru saanud, et need Bitcoini vastased on üldised krüptoraha vastased siin, seega ei hakanud eraldi välja tooma seda.
riaak kirjutas:
Omaarsut ei maininud kordagi BTC'd... icon_rolleyes.gif See kehtib kõikide krüptorahade kohta. Eriti nende kohta millel on väiksed tasud.
villu70 kirjutas:
Ma pakun, et see su oma tütar annab sulle paari aasta pärast vastu pead, et kuradi lolli juttu sa ajasid mulle pähe. icon_lol.gif
viimati muutis Viilutaja 06.02.2018 14:13, muudetud 1 kord
Killer85
sõnum 06.02.2018 14:12 vasta tsitaadiga
villu70 kirjutas:
Miks see sind niiväga häirib, mida teised oma rahaga teevad?
Ise kaevasin, kui hind oli nii 400€ tuuri. Olin täiesti loll eksole, sa paigutasid oma raha kahtlemata paremini thumbs_up.gif
Viilutaja
Viilutaja
sõnum 06.02.2018 14:21 vasta tsitaadiga
Killer85 kirjutas:
villu70 kirjutas:
Ma ka ei saa aru, ise ei taha sinna raha alla panna - OK. Ära pane, kuid miks nagu teistele vastu nägu karjuda, et KOLA PAHA asi...
Minul on seal all täpselt niipalju kui ma kaotada julgeks, ei rohkem ei vähem. Kui veab siis olen korterilaenust lahti kunagi. Kui mitte siis oli vähemalt huvitav asjas osaleda.
Miks loteriipileti ostmine teistmoodi on? Võibolla sa (villu70) kisad kuskil muus teemas ka, et loterii ja õnnemäng on paha. Sisuliselt raha tuulde viskamine...
Ma ütleks, et tänapäeval uue auto ostmine poest on ka mõttetu raha välja viimine kontolt.
Esiteks auto hind langeb -20% kui autoga välja sõidad poest. Teiseks maksad iga kuu bensiini ja liisingut vms. Ainult kulutused...
Miks ma ei võiks seda raha parem investeerida lootuses, et mul on hiljem rohkem käes! Autoga sa nagunii ainult kaotad selle raha, kallimaks ta ei lähe sul. icon_rolleyes.gif
Inimene ajab ainult oma paha jura suust välja, et omalgi hakkab kahju lausa... eriti veel nendest kes peavad sellise inimesega päevast peale suhtlema.
uus teema   vasta Hinnavaatlus »  Bitcoin ja muud krüptorahad »  Üldine arutelu ja krüptorahadega seotud uudised mine lehele eelmine  1, 2, 3 ... 119, 120, 121 ... 172, 173, 174  järgmine
