djkiller
13.12.2013 13:37:02
Probleem uue komplektiga teeb ise restarte |
Arvutiks järgmine conf
AMD Athlon II X2 240e
GIGA-BYTE MB AMD 990XSB950 SAM3+ATXGA-990XA-UD3
3x Gigabyte Radeon R9 270x 2GB GDDR5 OC WINDFORCE 3X
KINGSTON MEMORY DIMM 4GB PC12800
KINGSTON SSD SATA2.5" 30GBSS200S330G
CHIEFTEC PSU 750W BPS-750C2
klokanud midagi ei ole
kuid veateated on järgmised
just öösel mitte päeval
umbes sama kellaaeg ka
Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>2</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2013-12-13T06:36:40.493606900Z" />
<EventRecordID>3231</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>igor-PC</Computer>
<Security UserID="S-1-5-18" />
</System>
- <EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">false</Data>
<Data Name="PowerButtonTimestamp">0</Data>
</EventData>
</Event>
- <System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2013-12-12T19:57:39.741609100Z" />
<EventRecordID>640</EventRecordID>
<Correlation />
</System>
- <EventData>
</EventData>
</Event>
- <System>
<Provider Name="EventLog" />
<EventID Qualifiers="32768">6008</EventID>
<Level>2</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2013-12-13T06:36:47.000000000Z" />
<EventRecordID>3232</EventRecordID>
<Security />
</System>
- <EventData>
<Data>4:58:31</Data>
<Data>13.12.2013</Data>
<Data />
<Data />
<Data>15724</Data>
<Data />
<Data />
<Binary>DD070C0005000D0004003A001F006403DD070C0005000D0002003A001F006403600900003C000000010000006009000000000000B00400000100000000000000</Binary>
</EventData>
</Event>
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
- <EventData>
</EventData>
</Event>
- <System>
<Provider Name="Service Control Manager" Guid="{555908d1-a6d7-4695-8e1e-26931d2012f4}" EventSourceName="Service Control Manager" />
<EventID Qualifiers="49152">7023</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8080000000000000</Keywords>
<TimeCreated SystemTime="2013-12-13T00:07:34.091465900Z" />
<EventRecordID>3211</EventRecordID>
<Correlation />
<Execution ProcessID="560" ThreadID="2052" />
<Security />
</System>
- <EventData>
<Data Name="param1">Superfetch</Data>
<Data Name="param2">%%1062</Data>
</EventData>
</Event>
- <System>
<Provider Name="volsnap" />
<EventID Qualifiers="49158">36</EventID>
<Level>2</Level>
<Task>0</Task>
<TimeCreated SystemTime="2013-12-12T22:48:24.740818600Z" />
<EventRecordID>3174</EventRecordID>
<Security />
</System>
- <EventData>
<Data>\Device\HarddiskVolumeShadowCopy1</Data>
<Data>C:</Data>
<Binary>000000000200300000000000240006C0020000000000000000000000000000000000000000000000</Binary>
</EventData>
</Event>
- <System>
<EventID Qualifiers="16384">7036</EventID>
<Level>4</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2013-12-12T22:17:04.791223200Z" />
<EventRecordID>2549</EventRecordID>
<Correlation />
<Execution ProcessID="456" ThreadID="1452" />
<Security />
</System>
- <EventData>
<Data Name="param1">Diagnostic System Host</Data>
<Data Name="param2">running</Data>
<Binary>570064006900530079007300740065006D0048006F00730074002F0034000000</Binary>
</EventData>
</Event>
ootaks abi
suured tänud ette
| Kommentaarid: 225 loe/lisa |
204 |
okest
13.12.2013 16:17:13
Kaevanduse masin tundub olevat? See error log ei ütle suht midagi. Viskab resa tehes ette BSOD-i?
Kõige lihtsam vast analüüsida dump file. Ei hakka siia pikka teksti maha kirjutama, kõige lihtsam on vast sul googeldada: dump file debug/analyze.
viimati muutis okest 13.12.2013 16:19:36, muudetud 1 kord |
| Kommentaarid: 134 loe/lisa |
131 |
djkiller
13.12.2013 16:18:44
jah kaevur.
ei ole blue screeni.kui hommiku arvutisse tulen siis on ees mul win log.login sisse panen uuesti tööle kuni järgmise hommikuni:S
204 |
okest
13.12.2013 16:21:56
| Aa no see blue screen võib korraks ka ette visata ja siis teeb arvuti resa rahus. Kuna 270x suht uued kaardid siis võib miskit driverites ka olla, eriti kui on 3ne xfire. Vaata kas sul eksisteerib seal minidump kaustas neid minidump file, asub windowsi kaustas siuke folder nagu minidump.
131 |
djkiller
13.12.2013 17:04:37
kaust on tühi
kahe kaardiga jooksis nagu ok
kolmandaga koos mingi jama.hetkel see draiver peal mis oli plaadiga kaasas
204 |
martin366
13.12.2013 17:10:59
| djkiller kirjutas: |
kaust on tühi
kolmandaga koos mingi jama.hetkel see draiver peal mis oli plaadiga kaasas |
Lase kõik AMD software maha ja installi AINULT driver peale, catalyst jms jura võibki sul seda jama põhjustada.
mineri jaoks ei pea crossfire peal olema
172 |
djkiller
13.12.2013 17:15:35
| ok teen proovi
204 |
martin366
13.12.2013 17:19:56
| ok teen proovi |
Ava Catalysti installer, vajuta install, oota kuna ära extractib siis sulge installer.
Driveri asukoht C:\AMD\Support\13-9_win7_win8_64_dd_ccc_whql\Packages\Drivers\Display
172 |
djkiller
13.12.2013 17:22:47
| mis ikka parem on 270x kaartide jaoks 13,9 või siis 13,11?
204 |
martin366
13.12.2013 17:58:26
| mis ikka parem on 270x kaartide jaoks 13,9 või siis 13,11? |
Kõige uuem ma eeldan
172 |
Klm_on
15.12.2013 01:03:06
| Mul oli kunagi analoogne juhtum. selgus, et windowsi update tegi ise restarti igal ööl. Kui draiverite kala ei ole, siis kontrolli seda ka.
| Kommentaarid: 68 loe/lisa |
60 |
djkiller
15.12.2013 11:08:12
hetkel öösel vaikus. mida siis tegin
win update keerasin välja
kogu sisu võtsin korpusest välja
draivereid ei uuendanud
igaks juhuks panin ups vahele(kuigi ups aku läbi)
204 |
725 |
djkiller
16.12.2013 15:21:42
nüüd uus probleem.
sai korra oma toide pandud sõbra konfile katsetuseks ja tema enda konfile.
nüüd mul üks pesa ei toimeta korralikult.ei saaks nagu voolu. kiirus kuni 70
muidu 420
milles võib jama olla. olen antud pesas erinevaid kaarte sinna pannud ja toite juhtmeid.
kas sai katsetuse käigus midagi viga?
204 |
725 |
okest
16.12.2013 15:39:09
| Räägite PCI-E pesadest? vb tõmbas seadistuse paigast ära, vaata biosist üle.
131 |
djkiller
16.12.2013 17:00:25
probleem selles et sõbral masin 280 kaks kaarti toide 650w see toide vist väsis ära.
siis proovisimegi kas see toide töötab ja panin oma masina külge prooviks.ja minul jooksutas kaht e270 kaarti.võib olla et mingi draiverite jama?
voolu ei saa selles jama nagu ongi.mul see energia tarbimise junn vahel
edit:
asi töötab.panin korra molu hiire ja klaveri taha,.draivereid ei näppinud
204 |
