praegune kellaaeg 24.10.2026 12:38:54
laurixx
01.12.2013 18:27:29
Ubuntu serveris tohutu liiklus,palun abi |
Nimelt siis kasutusel Ubuntu-10.04 server ja ühel kuupäeval on serveris Outgoing liiklus üle TB. Oskab keegi öelda, kuidas ma saan nüüd jälile, mis siis toimund on sel päeval? Serveris on vaid mõned veebilehed, muud ei midagi.
Edit: lähemal uurimisel on selgunud, et servisse proovitakse sisse logida väga paljudelt erinevalt ip-aadressidelt üle terve maailma. Mida nüüd siis teha, et server päris kummuli ei kukuks ja rünnakuohvriks ei langeks?
daemon.log fail mõned näited:
Nov 26 16:29:00 xxx named[400]: client 94.102.51.196#42341: query (cache) './ANY/IN' denied
Nov 26 21:10:39 xxx named[400]: client 195.211.153.38#58747: query (cache) 'stopdrugs77.com/A/IN' denied
Nov 27 01:09:19 xxx named[400]: client 80.82.64.125#49266: query (cache) 'iana.org/A/IN' denied
Nov 27 01:09:19 xxx named[400]: client 80.82.64.125#55175: query (cache) 'iana.org/A/IN' denied
Nov 27 07:04:27 xxx named[400]: client 64.236.64.139#56367: query (cache) 'dnsscan.shadowserver.org/A/IN' denied
Nov 27 22:30:49 xxx named[400]: client 94.102.56.229#51132: query (cache) 'stopdrugs77.com/ANY/IN' denied
Nov 28 03:20:21 xxx named[400]: client 195.154.118.249#42838: query (cache) 'loo1.ru/ANY/IN' denied
Nov 28 05:38:24 xxx named[400]: client 80.82.64.238#51219: query (cache) 'fkfkfkfa.com/ANY/IN' denied
Nov 28 05:52:45 xxx named[400]: client 64.236.64.139#46667: query (cache) 'dnsscan.shadowserver.org/A/IN' denied
Nov 28 06:09:27 xxx named[400]: client 204.42.253.2#35592: query (cache) '90db0aee.openresolvertest.net/A/IN' denied
Nov 29 01:55:42 xxx named[400]: client 80.82.64.121#53100: query (cache) 'hccforums.nl/ANY/IN' denied
Nov 29 04:02:45 xxx named[400]: client 5.178.66.116#34060: query (cache) './ANY/IN' denied
Nov 29 06:31:13 xxx named[400]: client 80.82.64.238#50135: query (cache) 'fkfkfkfa.com/ANY/IN' denied
Nov 29 07:44:58 xxx named[400]: client 223.130.85.119#56007: query (cache) './ANY/IN' denied
Nov 29 08:35:39 xxx named[400]: client 64.236.64.139#65283: query (cache) 'dnsscan.shadowserver.org/A/IN' denied
auth.log näited:
Nov 29 02:48:22 xxx sshd[22965]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.147.103.71 user=root
Nov 29 02:48:24 xxx sshd[22965]: Failed password for root from 61.147.103.71 port 15839 ssh2
Nov 29 02:48:32 xxx sshd[22969]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.147.103.71 user=root
Nov 29 02:48:34 xxx sshd[22969]: Failed password for root from 61.147.103.71 port 17466 ssh2
Nov 29 02:48:42 xxx sshd[22974]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.147.103.71 user=root
Nov 29 02:48:44 xxx sshd[22974]: Failed password for root from 61.147.103.71 port 19075 ssh2
Nov 29 02:48:52 xxx sshd[22980]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.147.103.71 user=root
Nov 29 02:48:54 xxx sshd[22980]: Failed password for root from 61.147.103.71 port 20754 ssh2
Nov 29 02:49:01 xxx CRON[22988]: pam_unix(cron:session): session opened for user root by (uid=0)
Nov 29 02:49:02 xxx sshd[22984]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.147.103.71 user=root
Nov 29 02:49:03 xxx CRON[22988]: pam_unix(cron:session): session closed for user root
Nov 29 02:49:04 xxx sshd[22984]: Failed password for root from 61.147.103.71 port 22398 ssh2
Nov 29 02:49:12 xxx sshd[23026]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.147.103.71 user=root
Nov 29 02:49:15 xxx sshd[23026]: Failed password for root from 61.147.103.71 port 24009 ssh2
01.12.2013 20:31:29
Hakka IP-vahemikke blokkima.
| Kommentaarid: 763 loe/lisa |
571 |
laurixx
01.12.2013 22:34:55
| Betamax kirjutas: |
| Hakka IP-vahemikke blokkima. |
Kuidas ma selle peale küll varem ei tulnud, muidugi.. tänud Olin vist ilmselt liiga paanikas
Kas on mingi võimalus, et saaks välja sorteerida vaid IP-aadressid kogu sellest rägastikust? Log file on üsna pikk ja mahukas ja sealt nende ip-aadresside otsimine võtab ikka päris kaua aega.
Edit: leidsin juba lahenuse Fail2Ban ja DenyHosts näol. Lisaks sai ka SSH port ära muudetud. Nüüd peaks server rahulikumaks muutuma
estdata
28.12.2013 21:52:27
| laurixx kirjutas: |
| Betamax kirjutas: |
Edit: leidsin juba lahenuse Fail2Ban ja DenyHosts näol. Lisaks sai ka SSH port ära muudetud. Nüüd peaks server rahulikumaks muutuma  |
olemas proge mis automaatselt blockib , selle nimetus oli vist blockhosts , pythoni baasil vist
http://www.aczoom.com/blockhosts
| Kommentaarid: 22 loe/lisa |
16 |
