praegune kellaaeg 14.09.2026 16:14:04
xpander
13.11.2013 00:43:34
After Reset [Kickstarter] |
Kickstarter Link: Siin
After Reset RPG is a sci-fi post-apocalyptic role-playing game. Inspired by original Fallout 1/2, Baldur's Gate and Planescape:Torment.
Kodukas: www.afterreset.com
Stiil: RPG.
Platvormid: PC (Windows, Linux), Mac OS X.
mängu mootor: Unity 3D.
mängu moodused: üksikmäng, mitmikmäng
ringi jalutamise video:
_________________ Linux Gaming Videos: Xpander69 |
| Kommentaarid: 18 loe/lisa |
16 |
Timberg
ööKARU
13.11.2013 02:29:54
Väga lahe. Oleksin peaaegu kickstarteris panustanud, aga siis nägin, et 15-20 doltsi eest ei saa mingit alphat ega betat näppida.
"//update: closed alpha test (Windows/Linux/Mac) will be available in 2014 and closes beta will be available in 2015 for our backers only (for those who backed $35 or more) "
Natuke nukker... jälle. Iseenesest ootan juba väga pikka aega fallout 2'le väärilist järglast
272 |
xpander
13.11.2013 07:08:36
ma võtsin alpha/beta ära.
kahjuks aga tundub et nad oma 900k küll kätte ei saa.
kui just mõni suur juutuuber seda fallout2 ideed reklaamima ja kiitma ei hakka
16 |
Timberg
ööKARU
13.11.2013 13:06:01
Arvan sama. Üks kommentaator tõi päris huvitavat inffi välja:
Dawn_ about 5 hours ago
If you were to put a vulgar explanation of KS, 30% of your final goal is made in the first week. 30% is made during the campaign and the last 40% are made in the last 3 days.
Fast way to summerize it, i know. But seems to me this KS had a false start which will be hard to get over especially with the goal set so high.
I always think that starting a KS around the corner of December (be it beginning it or ending it in December) is a bad choice.
Last year i saw a lot of good project not achieving their goal because of tha miscalculation.
Plus for the comparison with Wasteland 2.
If you're looking at stattistics you should also see that on their first 3 days they had over 1M$
Not 11k.
272 |
