napoleon
Unknown virus
30.10.2013 21:35:57
SMART info tõlgendamine |
Täna vaatasin huvi pärast läpaka ketta SMART infot ja tulemus on selline:
*** DiskCheckup V3.1 Build: 1007 Report ***
SysInfo DLL Version: SysInfo v1.0 Build: 1030
Time of export: 21:28:43 30-Oct-2013
Device information:
Device ID: 0
Interface: ATA
Device Capacity: 152625 MB
Serial Number: K62KT8A28R2U
Model Number: FUJITSU MHZ2160BH G2
Firmware Revision: 00000009
Partitions:
C: 122524 MB
D: 29999 MB
ATA information:
Disk geometry:
Cylinders: 19457
Tracks/Cylinder: 255
Sectors/Track: 63
Bytes/Sector: 512
Total disk sectors: 312581808
Logical sector size: 512
Physical sector size: 512
Media rotation rate: N/A
Buffer size: 8192 KB
ECC size: 0 Bytes
Standards compliance:
ATA8-ACS Supported: Yes
ATA/ATAPI-7 Supported: Yes
ATA/ATAPI-6 Supported: Yes
ATA/ATAPI-5 Supported: Yes
ATA/ATAPI-4 Supported: Yes
Serial/Parallel: Serial
SATA 3.0 Compilance: No
SATA 2.6 Compilance: No
SATA 2.5 Compilance: Yes
SATA II: Ext Compilance: Yes
SATA 1.0a Compilance: Yes
ATA8-AST Compilance: Yes
World Wide ID: 500000E042D7912E
Feature support:
SMART supported: Yes
SMART enabled: Yes
SMART self-test supported: Yes
SMART error log supported: Yes
LBA supported: Yes
IORDY supported: Yes
CFast supported: No
DMA supported: Yes
Maximum Multiword DMA mode supported: 2
Multiword DMA selected: None
Maximum UltraDMA mode supported: 5
UltraDMA selected: 5
Maximum PIO mode supported: 4
SATA Compliance: Yes
NCQ priority information supported: No
Unload while NCQ commands are outstanding supported: No
Phy Event Counters supported: Yes
Receipt of power management requests supported: Yes
NCQ feature set supported: Yes
SATA Gen2 Signaling Speed (3.0Gb/s) supported: Yes
SATA Gen1 Signaling Speed (1.5Gb/s) supported: Yes
Software Settings Preservation: Supported, Enabled
In-order data delivery: Not supported
Initiating power management: Supported, Enabled
DMA Setup auto-activation: Supported, Enabled
Non-zero buffer offsets: Not supported
Trusted Computing supported: No
Host Protected Area (HPA) supported: Yes
Read look-ahead supported: Yes
Read look-ahead enabled: Yes
Write cache supported: Yes
Write cache enabled: Yes
Power management supported: Yes
Security mode supported: Yes
Security mode enabled: No
Device Configuration Overlay (DCO) supported: Yes
48bit Addressing supported: Yes
Auto Acoustic Managment (AAM) supported: Yes
Auto Acoustic Managment (AAM) enabled: Yes
Recommended AAM level: Maximum performance
Current AAM level: Maximum performance
Power-up in Standby (PUIS) supported: No
Advanced Power Management (APM) supported: Yes
Advanced Power Management (APM) enabled: Yes
Current APM level: Minimum power consumption without Standby
CompactFlash Association (CFA) supported: No
General Purpose Logging (GPL) supported: Yes
Streaming supported: No
Media card pass through supported: No
Extended power conditions supported: No
Extended status reporting supported: No
Write-read-verify supported: No
Free-fall control supported: No
TRIM command supported: No
SCT command transport supported: Yes
NV Cache enabled: No
NV Cache Power Management supported: No
SMART ATTRIBUTES:
ID Description Status Value Worst Threshold Raw Value TEC
1 Raw Read Error Rate OK 100 100 46 258696 N.A.
2 Throughput Performance OK 100 100 30 28835840 N.A.
3 Spin Up Time OK 100 100 25 1 N.A.
4 Start/Stop Count OK 99 99 0 1827 N.A.
5 Reallocated Sector Count OK 100 100 24 8589934592000 N.A.
7 Seek Error Rate OK 100 100 47 1922 N.A.
8 Seek Time Performance OK 100 100 19 0 N.A.
9 Power On Time OK 88 88 0 6138 N.A.
10 Spin Retry Count OK 100 100 20 0 N.A.
12 Power Cycle Count OK 100 100 0 1805 N.A.
192 Power off Retract Count OK 100 100 0 80 N.A.
193 Load Cycle Count OK 97 97 0 72908 N.A.
194 Temperature OK 100 100 0 33 C N.A.
195 Hardware ECC Recovered OK 100 100 0 2808 N.A.
196 Reallocation Event Count OK 100 100 0 455213056 N.A.
197 Current Pending Sector Count OK 100 100 0 0 N.A.
198 Uncorrectable Sector Count OK 100 100 0 0 N.A.
199 UltraDMA CRC Error Count OK 200 253 0 0 N.A.
200 Write Error Count OK 100 100 60 25315 N.A.
203 Error Correction Code Errors OK 100 100 0 433761550916 N.A.
240 Head flying hours OK 200 200 0 0 N.A.
Kui total sector count on oluliselt pisem kui reallocated sector count, siis ei saa viimast tõenäoliselt tõsiselt võtta. Aga kas on põhjust uut ketast otsima hakata või on see lihtsalt mingi SMART anomaalia? Masin töötab normaalselt, mingeid probleeme kettaga pole siiani täheldanud.
| Kommentaarid: 79 loe/lisa |
60 |
30.10.2013 23:06:25
Mis tõlgendamisse puutub, siis:
RAW value on töötlemata info. Reallocated sector count puhul on ta enamasti arvuliselt võrdne ümbermapitud sektorite arvuga, aga põhimõtteliselt ei pea ta seda olema. Kuna ketta SMART staatus antud parameetri puhul on OK ja (firmware poolt) normaliseeritud väärtus (value) on kõrgem kui lävi (thershold) ning võrdne 100-ga, (mis enamasti ongi selle algväärtus), siis peaks kõik korras olema. (SMARTi poolest)
Pole välistatud, et esimese sektori ümbermappimisel hakkab raw value väärtus ka reaalset sektorite arvu näitama, aga selle peale mürki võtta ka just ei maksaks.
Pole üldse välistatud, et ühel hetkel mõni kettatootja otsustab, et ketta omanikul ei ole lisaks normaliseeritud väärtusele vaja teada vigaste sektorite tegelikku arvu ja ta hakkab tootma kettaid, millel kasutab vigaste sektorite loendamiseks mingit ainult talle teada olevat "hägustamistehnikat" (obfuscation) selle tegeliku väärtuse varjamiseks.
Mind häirib aga hoopis see, et ka Reallocation Event Count raw value on selline "imelik". See võiks nagu viidata sellele, et midagi on siiski mäda. Ometi pole ka seal normaliseeritud väärtus veel allapoole kukkuma hakanud.
Muidugi need normaliseeritud väärtused võivad lõputult püsida ja/või ühel hetkel ka väga järsult kukkuda - oleneb ketta firmwarest, kui "tuimaks" ta on tehtud vigaste sektorite arvu suhtes ja kui kiiresti kukkuma on see väärtus seatud, kui see mingi piiri ületab.
Minu meelest oli Fujitsul ka mingi ketta testimise utiliit olemas. Katsuks selle üles leida kusagilt (Toshiba kodukalt?) ja ketast sellega testida, utiliit peaks andma ketta seisundile õigema ja konkreetsema hinnangu kui SMART. Vaid see oskab seda seisundit antud kettatootja määratud spetsifikatsioonile vastavalt õigesti hinnata.
______________________
Vaata siia: http://storage.toshiba.com/storage-services-support/warranty-support/software-utilities
Tõmba sealt DOS Diagnostic Tool ja sellega testi ketast. Pead tegema endale DOS-i bootiva mälupulga ja utiliidi sinna peale kopeerima, pulgalt bootima ja utiliidi puhtas DOS-is käivitama.
tarc
31.10.2013 12:45:05
| Dogbert kirjutas: |
Mind häirib aga hoopis see, et ka Reallocation Event Count raw value on selline "imelik". See võiks nagu viidata sellele, et midagi on siiski mäda. |
Ära lase ennast sellest häirida. Pole veel ühregi FS ketast näinud millel hdtune 0 näitaks. Kõigil sadadestuhandetes. Vist oli victoria, mis näitas 0-i.
_________________ Pakkumistes arvestan, et kodanik asub Tallinnas Tondil, kui profiilis pole märgitud teisiti.
Prosed, mälud, kettad, lcd-d, wifid, wwanid, laadijad ja muu. PS-is lähem inf. |
| Kommentaarid: 841 loe/lisa |
638 |
31.10.2013 21:27:22
Siis ongi kettatest tootja utiliidiga ainus võimalus usaldusväärse hinnangu saamiseks.
Minu käest on Fujitsu kettaid suhteliselt vähe läbi käinud.
tarc
638 |
loox
01.11.2013 20:49:38
Need suured numbrid võib teisendada kuueteistkümnendsüsteemi, siis on näha, et parem pool on puha nullid.
hdtune paneb ilmselt liiga palju baite ühte patta, võibolla ka vastupidi, et kettatootja kuritarvitab baite mis alati nullid on.
02.11.2013 01:02:23
Mina loen päisest DiskCheckup. Kust te selle HDTune jutu võtate kõik?
Võiks hdparm ja smartctl väljundit ka vaadata.
napoleon
Unknown virus
60 |
loox
06.11.2013 12:54:03
Täna juhtumisi tegelen ühe Fujitsu kettaga, vaatasin smartctl väljundit ja seal on küll mõistlikud numbrid:
=== START OF INFORMATION SECTION ===
Model Family: Fujitsu MHZ BH
Device Model: FUJITSU MHZ2120BH G2
Serial Number: xxx
LU WWN Device Id: 5 00000e 042db894a
Firmware Version: 8909
User Capacity: 120 034 123 776 bytes [120 GB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 3f
Local Time is: Wed Nov 6 11:12:54 2013 EET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 487) seconds.
capabilities: (0x51) SMART execute Offline immediate.
No Auto Offline data collection support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 69) minutes.
SCT capabilities: (0x003f) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 100 100 046 Pre-fail Always - 90355
2 Throughput_Performance 0x0005 100 100 030 Pre-fail Offline - 22937600
3 Spin_Up_Time 0x0003 100 100 025 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 099 099 000 Old_age Always - 3477
5 Reallocated_Sector_Ct 0x0033 100 100 024 Pre-fail Always - 0 (2000 0)
7 Seek_Error_Rate 0x000f 100 100 047 Pre-fail Always - 42
8 Seek_Time_Performance 0x0005 100 100 019 Pre-fail Offline - 0
9 Power_On_Hours 0x0032 088 088 000 Old_age Always - 6160
10 Spin_Retry_Count 0x0013 100 100 020 Pre-fail Always - 0
11 Calibration_Retry_Count 0x0032 253 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 3202
182 Erase_Fail_Count_Total 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0033 253 253 097 Pre-fail Always - 0
185 Unknown_Attribute 0x0010 100 100 000 Old_age Offline - 4
186 Unknown_Attribute 0x0032 253 253 000 Old_age Always - 0
187 Reported_Uncorrect 0x0032 253 100 000 Old_age Always - 193273528320
188 Command_Timeout 0x0032 253 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 253 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 069 048 000 Old_age Always - 31 (Min/Max 31/35)
191 G-Sense_Error_Rate 0x0032 253 253 000 Old_age Always - 16580608
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 4194368
193 Load_Cycle_Count 0x0032 096 096 000 Old_age Always - 81252
195 Hardware_ECC_Recovered 0x001a 100 100 000 Old_age Always - 18
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 (0 6983)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 253 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x000f 100 100 060 Pre-fail Always - 1357
203 Run_Out_Cancel 0x0002 100 100 000 Old_age Always - 429597260459
240 Head_Flying_Hours 0x003e 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed without error 00% 3186 -
# 2 Short offline Completed without error 00% 3185 -
# 3 Extended offline Completed without error 00% 1 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
tarc
06.11.2013 13:12:22
Vaata nüüd hdtune või DiskCheckupiga, kui programmi nimi mingit tähtsust omab.
638 |
06.11.2013 13:32:50
| tarc kirjutas: |
| Vaata nüüd hdtune või DiskCheckupiga, kui programmi nimi mingit tähtsust omab. |
smartctl näitab seda HEX väärtust (millest loox rääkis) ka sulgudes, nt Reallocated_Sector_Ct puhul (2000 0), mida DiskCheckup õigeks väärtuseks peab, aga oskab selle siiski nulliks lugeda. Pole nagu mõtet teistega jantima hakatagi - eriti kuna ta on mul Linuxi masina küljes praegu ja backup pooleli. Hiljem, kui ta Windowsi masinale tagasi panen, võin ju ka vaadata põhimõtteliselt, aga väärtus on üsna selgelt neil sama, smartctl oskab seda vaid õigesti tõlgendada.
DiskCheckup'i poolt algses postituses näidatav väärtus on 8589934592000. Kui kaksad sealt paremalt poolt nullid maha, jääb järele 8589934592=200000000 HEX
