Kas oleksid nõus windows 10-t teenusena ostma ehk iga kuu kasutamise eest maksma? |
Kindlasti mitte |
65% |
[ 373 ] |
Pigem ei |
27% |
[ 155 ] |
Pigem jah |
5% |
[ 32 ] |
Kindlasti jah |
1% |
[ 8 ] |
hääli kokku : 568 |
sõnum |
03.07.2018 11:22:26
https://social.technet.microsoft.com/Forums/windowsserver/en-US/a8b8fe72-7e85-4e3d-beba-19c84c620dc8/the-backup-failed-the-rpc-server-is-unavailable-0x800706ba?forum=windowsbackup
üks nullist tehtud w10 home millele mõtlesin teha süsteemitaaste andis ülal toodud vea.. siit ja sealt hakkab silma, et probleem tekkis 1803 ega.
e:
Yup. Its a bug. The image backup is broken in 1803 on the 32 bit version only. If you try to perform an image backup to a network location it gives the RPC statement above. If you attached a local USB or SD drive, it fails also with the same message. I
türr.. sellise asjaga ollakse siis laivvis.
ja lahendus sellele saastale:
I talked to tech support (Ticket #1424749859) about this for over 3 hours while watching a tech on my laptop remotely, until he finally admitted defeat. ("Wait for an update that fixes the problem.")
After all was said and done, i replaced the x86 1803 version of wbengine.exe with the 1709 version through the recovery command prompt.
After that the image backup worked and a recovery disc PRIOR to 1803 successfully restored it.
While I wouldn't propose this as a solution, it certainly defines the problem.
wbengine.exe (x86) is the problem. RPC is merely a symptom.
The x64 version of wbengine.exe in 1803 is not a problem.
I reported this back to tech support under the same ticket number. Apparently you have to tell them from 4 different directions before someone notices.
_________________ Ketas, ketta, ketast, kettasse, kettas, kettast, kettale, kettal, kettalt, kettaks, kettani, kettana, kettata, kettaga. <--SPIKKER
mõned sülerid, mis hetkel müüa on -> https://www.facebook.com/marketplace/profile/100087345405856/ värskeim loetelu. Ei mingit otsa.ee d. kätte saad asap. |
03.07.2018 11:27:12
laurx kirjutas: |
e:
I reported this back to tech support under the same ticket number. Apparently you have to tell them from 4 different directions before someone notices. |
Sellele Backup veale on tegelikult olemas veel üks lahendus, vähemalt mõned tootjad on selle ära tabanud.
Ning on ise koheselt kaasa pannud "tootja-poolse" Recover-DVD.
Samamoodi nagu vanasti oli see kaasas Ordil ning Microlinkil.
Kusagil vist mingi kuu tagasi nägin kuidas uhiuue Firma-läppariga oli kaasas tootjapoolne, enda Recover-DVD.
Veel vihjeks: Backupi asemel kasuta hoopis Image tegemist. Ja kui on vaja, siis taastad selle Image.
Pole mingit probleemi, et miski ei tööta või on vigane. Töötab alati 100%.
03.07.2018 11:30:00
pole minu enda masin, rumal omanik kaotab minu higi ja vaevaga tehtud taastekettakomplekti nii ehk naa ära ja ma ei hakka ekstra selle jaoks mingit a eraldi ketast b hunnikut dvd sid ostma.. konfin selle oma varunduse nii, et korra kuus annab veateadet seni kui fix tuleb ja ükskord teeb ära ning loodan, et selle aja peale per.se ei keerata seda masinat.
sama masin, mille sisu pildid pitlikesse olukordadesse panin just. hetkel enam nii ei haise..
aht0
18.07.2018 11:43:25
Küsimus. Kust leida litsentsi XML faili Windows Store'ist pärit .appx failile?
Tahan Facebook Messengeri preinstallida Windows 10 (RS4) iso'sse.. Windows Store ise läheb eemaldamisele, nii et hilisem sealt installimine pole enam variant. Sellelt isolt installitud Windowsis plaani järgi pole suuremat osa preinstallitud kraamist ja poodi ennast ka mitte. Poodi ennast ajendab täielikult eemaldama see pidevalt automaatselt allatiritav kräpp. Messenger osutus aga üllatavalt kasutatavaks.
Vastava .appx paki lingi sain võrguliikluse capture abil kätte ja paki ise tiritud aga kust ja kuidas see paki litsentsi XML Windows Store rakenduseni jõuab jääb müstikaks. Ilma /LicensePath switchita DISM aga seda .appx pakki installida ei luba. /SkipLicense ei toimi, juba proovitud.
18.07.2018 12:51:13
Windows Store'is saab automaatse uuendamise keelata.
aht0
18.07.2018 15:07:21
Ikkagi. Probleem ise hakkas ka huvi pakkuma. Automaatse uuendamise keelamisega "kümnel" juhtub pahatihti nii et digimaagiliselt üks moment jälle lubatud..
NATAS999
18.07.2018 15:42:21
pois11 kirjutas: |
Mingi kamm ikka on. HP läpakaga muutus heli vaikseks. Sirka kuu aega kannatasin ja mõtlesin, et nii peab olema. Aga ükshetk võtsin heliseaded lahti ja panin kuhugi linnukese ja vali heli tuli tagasi. Hetkel peast kahjuks ei mäleta mis seade see oli. |
peale igat windowsi update on sama jama. automaagiliselt disableb loudness equalizationi ära.
puhtalt int. helikaardi või siis realteki pärusmaa. "profi" kaartidel sellist luksust ei ole kahjuks. kahjuks selle pärast, et ilma kompressioonita ei ole võimalik tänapäeva filme ega sarju vaadata, youtube ka ilma selleta päris piin tegelikult.
seriaalis dialoog: "soss-soss-soss-soss," keegi pillab udusule maha: "BOOOOMMMKRRSHSHSHHHHKRGRGLRGLRGL!!!!"
/ot breaking bad oli eriti halb veel, ress oli dialoogi ajal -3dB ja kui keegi ukselinki puutus, siis pidi -45dB keerama, et ress suitsema ei läheks ja kõllid maha ei põleks.
muusikat sellega loomulikult ei kuula.
18.07.2018 16:01:32
Heliteema on jah Win10's müstika. Endal on justkui kaks helikaarti, üks on int.heli ja teine monitor läbi DP/HDMI. Ning ikka korra-paar kuus on peale restarti äkki valitud helikaardiks monitor, mis ei tee piuksugi (sisseehitatud kõlareid pole). Korra kvartalis on int.heli ka devicede alt läinud ja saab draivereid uuesti installida.
DVDRW
18.07.2018 16:05:57
W10 update keeras HPl heleduse reguleerimise võimaluse fn+ f3/f4 kinni.
Ei tea kuhu me küll niimoodi lõpuks jõuame
NATAS999
18.07.2018 16:14:41
DVDRW kirjutas: |
Ei tea kuhu me küll niimoodi lõpuks jõuame |
cry me a river, W10 mingi update keeras mul ventikate juhtimise ja OS sisese OC kinni. asus AI suite 2 enam ei toimi ja uuematele mu emaplaadi tuge pole kirjutatud.
viimati muutis NATAS999 18.07.2018 16:19:03, muudetud 1 kord |
18.07.2018 16:15:56
tsitaat: |
OS sisese OC kinni
Kes see OC OS kaudu siis teeb
NATAS999
18.07.2018 16:30:24
jeesus188 kirjutas: |
tsitaat: |
OS sisese OC kinni
Kes see OC OS kaudu siis teeb |
see, kes teab, mis pinged ja sätted peavad olema ja muud asjad biosis on vastavalt sätitud ja kes ei viitsi iga sita asja pärast restarti teha. ajakulu OS sees kellad ja pinged paika panna on mingi suht nulli lähedane ja tüütuse koefitsient pea olematu võrreldes restardi tegemise ja biosis ekslemisega enne ja peale mängu käivitamist.
18.07.2018 17:05:29
NATAS999 kirjutas: |
tsitaat: |
OS sisese OC kinni
see, kes teab, mis pinged ja sätted peavad olema ja muud asjad biosis on vastavalt sätitud ja kes ei viitsi iga sita asja pärast restarti teha. ajakulu OS sees kellad ja pinged paika panna on mingi suht nulli lähedane ja tüütuse koefitsient pea olematu võrreldes restardi tegemise ja biosis ekslemisega enne ja peale mängu käivitamist. |
Windows 10 omab ka enda sisseehitatud OC-oskust. Ning armastab seda nii Inteli protsessoritega kui Nvidia videodega.
Lauaarvutis ei tea kuid läpparites - kasutades OpenHardwareMonitori nimelist programmi, on see MS-i OC täiesti nähtav.
Ja see on ka põhjus miks osad vanemad läpparid massiliselt videosurma surevad. Viimati suri Fujitsu-Siemensi läppar mille video ei pidanud liigkoormusele vastu. Ning tundub, et praegu jõudis minuni Delli Inspiron millel siis samuti W10 on videost jagu saanud.
NATAS999
18.07.2018 17:47:27
tahanteada, ei ole seal monitoris mingit OC'd, vente saab juhtida mingil määral ja see on ka kõik.
Ramones
18.07.2018 19:56:55
cry me a river, W10 mingi update keeras mul ventikate juhtimise ja OS sisese OC kinni. asus AI suite 2 enam ei toimi ja uuematele mu emaplaadi tuge pole kirjutatud. |
Seda oled proovinud? http://dlcdnet.asus.com/pub/ASUS/mb/Utility/AI_Suite2_Patch_1.00.00.zip
AI Suite II Patch file
This patch is to update an existing AI Suite installation for compatibility with the Windows Fall Creators Update.
1. Before you run the patch, please ensure that AI Suite II is installed.
2. Download and unzip the patch.
3. Run AxIns.exe |
ASUS andis 2018/03/12 mingi patchi vaikselt välja, mille kohta osad väidavad, et toimib.
Naljakas muidugi on, et selle patchi leiab ainult osade Ai2 kasutavate emaplaatide download lehelt, kui valida OS-ks Windows 7
NATAS999
18.07.2018 20:14:49
Ramones, minu plaadile ehitatud AIsuite2 ei nõustu installeeruma aiacpi.dll vms asi puudu ja kuskil rog foorumis pakutud mingisuguse x79 või x97 või mis iganes plaadi aisuite 2 installeerub, aga peale patchi installimist annab fan xpert mingi access violation at address 00000000 vea.
TL:DR SoL.
proovisin veel nii, et panin selle x79 cõi 97 või what ever the fuck plaadi oma see aisuite2 oli... et nagu... panin selle peale ja siis mõcin et lasen oma plaadi oma sellele selga, aga selle peale installer kilkas rõõmsalt et temal see üks teine aiaiaiaiiacpiEX.dll puudu.
TL:DR tegin kõik, mis aju suutis välja mõelda... endisel - SoL.
DVDRW
19.07.2018 10:42:39
Liiga absurdseks läheb juba, aeg lahkuda vist IT maailmast, teie maadelge edasi.
sukelduja
19.07.2018 10:48:02
DVDRW kirjutas: |
See heleduse reguleerimine käib tavaliselt tootja lisaprogrammi abil, mis tõenäoliselt uuendusega kaduma sai. Installi uuesti. Vaata BIOS ka igaks juhuks üle, selle jaoks peaks setting olema, kuidas Fn nupud käituvad.
19.07.2018 10:57:30
sukelduja kirjutas: |
DVDRW kirjutas: |
See heleduse reguleerimine käib tavaliselt tootja lisaprogrammi abil, mis tõenäoliselt uuendusega kaduma sai. Installi uuesti. Vaata BIOS ka igaks juhuks üle, selle jaoks peaks setting olema, kuidas Fn nupud käituvad. |
BIOS / reguleerimine ei mõjuta alati käitumist Windows 10-s.
Ise "maadlen" ühe Delliga kus on sama jama. Muuda BIOS-is palju tahad seda heledust, Windows 10-s on ikka "tume" ja ei reguleeri enne midagi kui juurde on installitud Windows 7-e lisaprogramm.
19.07.2018 11:32:28
tsitaat: |
sõna. 20 aastat vana auto parandamisega teenib kordi rohkem kui poest tulnud raua näppimisega.
19.07.2018 11:50:50
laurx kirjutas: |
tsitaat: |
sõna. 20 aastat vana auto parandamisega teenib kordi rohkem kui poest tulnud raua näppimisega. |
Selleks, et autot remontida, pead tundma autos kasutatavat kas Windows 10-t või siis on kasutusel mõni Linuxlane. Tõenäoliselt mingi Ubuntulane.
PS: Mina lähen millalgi lähiajal paari Autofirmasse, selleks, et seal töötavatele elektrikutele paar lihtviisilist elektroonika-värki ära näidata. Ning mille peale nad ise kohe mitte tulla ei oska. A la keegi pole kunagi õpetanud ning ma ka ise ei viitsi juurde õppida.
wirx
20.07.2018 00:15:17
Kas uuemate windows 10 versioonidega saab update kuidagi täielikult välja ka lülitada registri vms abil? Vanad trikid ei toimi, ikka updateb edasi.
rycyve
20.07.2018 03:08:58
Iga versiooniga annab midagi teha ja win update pole endal vähemalt miski probleem kui kasutan pro-d või enterprise.Google+tiba kannatust aitab seda ravida
Senini pole MS Update kunagi tüüdanud kui ma ise ei taha
wirx kirjutas: |
Kas uuemate windows 10 versioonidega saab update kuidagi täielikult välja ka lülitada registri vms abil? Vanad trikid ei toimi, ikka updateb edasi. |
Spooky
20.07.2018 10:39:22
wirx, Control Panel - Administrative Tools - Services - Windows Update - Disabled ja Group Policies-es samuti kõik akende uuendustega asjad disabled peale.
DVDRW
20.07.2018 11:49:08
wirx
Windows update service panna manual ja:
