destiny12
30.09.2013 22:26:02
HP Compaq dc7900 Small form factor BIOS |
HP Compaq dc7900
Esimesel käivitusel peale F1 Boot nupu vajutust annab teate. CTRL-ALT-DELETE kombinatsiooniga restarti tehes enam antud veateadet ei anna ja windows hakkab laadima.
2233 - HECI error during MEBx execution
MEBX Status = 0302
ME BIOS Extension module halted
Update Bios or ME firmware if problem persists
2206 End of POST HECI Failure
System halted. Power cycle the system to reboot.
Mida ma nüüd tegema peaks? Pole aega loomkatseteks. Ehk kellelgil on kogemusi?
_________________ "Ära mine sinna, kuhu rada viib. Mine selle asemel sinna, kus rada ei ole, ja saa teerajajaks." |
| Kommentaarid: 83 loe/lisa |
77 |
| Kommentaarid: 760 loe/lisa |
570 |
destiny12
01.10.2013 11:18:42
Tundub, et viimane bios-i versioon on hetkel peal. Vähemalt installer nii väidab. Või on mõtet uuesti üle lasta?
Mida sa ME firmware update endast kujutab?
77 |
01.10.2013 11:59:37
Sama nagu BIOSi update. HP kodukal peaks sellele uuendus olemas olema.
570 |
destiny12
01.10.2013 12:02:03
link
See? Tõmbasin alla, kuid hetkel ei jaga matsu lahti, kuidas antud failidega nüüd tegutseda.
77 |
01.10.2013 12:07:13
Readme fail peaks kaasas olema. Su link tegelikult ei vii kuskile.
OK, navigeerisin sinna driverite lehele. Description ju täitsa olemas:
This package contains utilities that can be used to update the Intel Management
Engine (ME) Firmware on the supported desktop models with a 786Gx system BIOS.
NOTE: The Intel Active Management Technology (AMT) 5.2 ME firmware image is
only intended for HP Compaq dc7900 PC, HP Compaq 8000 Elite PC, HP Compaq 8000f
Elite USDT PC, HP Compaq 8080 Elite CMT PC, HP Compaq 6080 Pro, and HP Compaq
6000 Pro PC configurations. This SoftPaq does NOT include a system BIOS image.
However, it is recommended that the system BIOS be updated to the latest
version before upgrading the ME firmware. Once the ME firmware is updated to
this new image, it CANNOT be re-flashed to an older ME AMT 5.0, 5.1, or 5.2
firmware version.
Several methods for updating the ME firmware may be chosen. Included in this
package are the following methods:
- The DOS utility updates the Intel ME firmware for the local machine in a DOS
environment, and also verifies that the firmware has been updated.
- The Microsoft Windows utility updates the Intel ME firmware of the local
machine in a Microsoft Windows environment, and also verifies that the firmware
has been updated. |
570 |
destiny12
01.10.2013 12:07:34
link
Readme on kaasas küll, kuid kas mina olen loll või pole otsest tegevuskava seal kirjas.
77 |
01.10.2013 12:13:00
| 2. Double-click the downloaded file and follow the on-screen instructions. |
Ma oletan, et see asjandus pakib end kusagile C:\ kettale lahti ja seal on veel faile.
570 |
destiny12
01.10.2013 12:16:39
Pildid failidest, et asi selgem oleks.
Instruktsioon:
Windows ME Updating
Another FWUpdLcl.exe utility in the ME Flash\Local-Win directory is designed to update the ME firmware within a local Windows environment. For more information and utility options, view ReadMe.txt located in the ME Flash\Local-Win folder. The ME can be updated by executing the following command "FWUpdLcl.exe <XXXXbbbb.bin> -generic". The ME Flash folder contains a binary update image for the ME. The binary image file is named XXXXbbbb.bin where "XXXX" is the abbreviated ME firmware version and "bbbb" is the build version number. For example, 52501039.bin is the ME update file version 5.2.50 with the build number of 1039. The update binary image and the Local-Win folder contents can be copied to any Windows accessible media such as a CD/DVD or USB flash media device, including HP Drive Key and M-Systems DiskOnKey®. |
FWUpdLcl faili avades viskab korraks dos akna ette, mis koheselt ka sulgub ja ongi kõik.
77 |
01.10.2013 12:19:07
Pead vist DOSis käivitama, kui õigesti mäletan.
570 |
destiny12
01.10.2013 12:39:57
Bin faili dos-is käima lükates avab ta mulle vlc. Ilmselgelt teada miks, kuid hetkel on juhe koos.
77 |
01.10.2013 12:48:33
Sul on lihtsalt VLC määratud .bin faile avama.
Kas sa BIOSist seda ME värki kinni lihtsalt ei saa keerata? See peaks ka veateate elimineerima. See pole küll õige lahendus, aga saad vähemalt veateatest lahti. Siin on vihje, kust seda otsida võiks.
link
Enterprise Mode Setup and Configuration
Enterprise mode is for large corporate customers. An SCS is required for Enterprise mode Setup and Configuration.
The SCS is also known as a Provisioning Server as seen in the MEBx.
Enterprise Mode - AMT Setup and Configuration Steps
The AMT Setup portion for Enterprise mode is the same as SMB mode. Repeat Steps 1 through 15 to perform
AMT Setup. This will take the system from Factory Mode to In Setup Mode.
Refer to “SMB Mode - AMT Setup and Configuration with MEBx” on page 3 for examples of MEBx menus
and full text. The following are quick steps for AMT Setup:
1. Access the MEBx by pressing Ctrl-P during POST.
2. Type the default password, which is admin.
3. Change the MEBx password, following strong password guidelines.
4. Select Intel ME Platform Configuration.
5. In Intel ME State Control, select Enabled.
6. In Intel ME Firmware Local Update Qualifier, select Always Open.
7. Select Intel ME Features Control.
a. Select Check Manageability Features.
b. Select Intel AMT.
8. Select Intel ME Power Control.
a. Select ME ON in Host Sleep States.
b. Select Option 7.
9. Select Exit and save. The system displays the Intel ME Configuration Complete message, and then
reboots.
After the system reboots, starting with Step 10 you will set some of the options differently than SMB
mode.
10. Press Ctrl+P during POST to enter MEBx Setup again.
11. Type the MEBx pass |
word.
570 |
destiny12
01.10.2013 14:06:45
Huvitav. Alla paremasse nurka ilmub kiri MEBx ja rohkem ei midagi. Muidugi f1 boot ka töötab. Jätan vist midagi tegemata.
Miskipärast on mulle komme kõigepealt kõige keerulisemad asjad ära proovida ja siis lihtsamaid asju proovida. Tegin kastil kaane lahti ja clearisin CMOS-i ära. Märkasin veel, et üks mäludest oli vales slotis. Üks pidi olema mustas slotis.
Igastahes tundub, et probleem on lahendatud!
77 |
