praegune kellaaeg 30.11.2026 20:45:36
Lord Ami
| Kommentaarid: 57 loe/lisa |
52 |
Lord Ami
03.12.2013 14:03:46
http://forum.avast.com/index.php?topic=141705.0
Päris huvitav:
We are more than happy to announce AVAST 2014 R2 BETA1 (build number 9.0.2009).
We're introducing several important pieces in this release:
* GrimeFighter -- performs a scan to identify ways to speed up, clean up, and better protect your PC. GrimeFighter will run the scan and show you where you can improve the performance of your PC. It then sedates your PC and performs all of the cleaning functions. This need feature is a result of our acquisition of Jumpshot earlier this year. It is an early stage integration into our user interface and we really need your feedback on it
IMPORTANT NOTE: DON'T RUN GRIMEFIGHTER ON WINDOWS 8/8.1, ENCRYPTED OR RAID DISKS! WE WILL FIX THESE ISSUES SOON...
* SavePrice -- we added a new function to the browser plugins that helps you save money when you are shopping online. It finds better prices for items you are searching for. At the moment, Chrome, Firefox, and Safari are supported. Internet Explorer should be supported in the near future.
* avast! tutorial -- for users who run avast! trials, a tutorial is now available explaining all the great things avast! can do to protect your PC
* Stream Filtering -- a completely rewritten function that is part of the new Web Shield launched in v2014. The three main components of Stream Filtering are a rewritten scanner, new kernel mode inspection techniques, and a new HTTP parser. All of these functions lead to more effective detections of threats
* Firewall -- most importantly, we the previous issues with Java have been solved. The firewall should be more stable and with better compatibility with other network applications |
Täpsemini kirjutatakse siin: http://forum.avast.com/index.php?topic=141743.0
Üldiselt said programmi põhikomponendid täiustusi nii kiiruse kui ka kaitse osas.
Eks ole näha mis see GrimeFighter ka teeb. Üks asi mis mulle meeldib on startupi haldamine (ala mõttetute asjade automaatne kinnikeeramine).
Reeglina ollakse sellega hädas.
Aga üldiselt, eks paljud AVd liiguvad "full suite" suunas, kus AV teeb ka puhastus/koristustööd arvutis. Kas see ka hea on, ei oska öelda. Samas "all in one" korralik lahendus, miks ka mitte.
52 |
estdata
28.12.2013 20:32:17
| Lord Ami kirjutas: |
Päris huvitav:
Aga üldiselt, eks paljud AVd liiguvad "full suite" suunas, kus AV teeb ka puhastus/koristustööd arvutis. Kas see ka hea on, ei oska öelda. Samas "all in one" korralik lahendus, miks ka mitte. |
Eesti keeles seda pole uuut 2014 ja kuidas oleks see arvuti resurssidega , kas koormab arvutit rohkem eelmistte versioonidega ?
| Kommentaarid: 22 loe/lisa |
16 |
Lord Ami
28.12.2013 20:54:21
| tptdairy kirjutas: |
Päris huvitav:
Eesti keeles seda pole uuut 2014 ja kuidas oleks see arvuti resurssidega , kas koormab arvutit rohkem eelmistte versioonidega ? |
Peab olema eesti keeles. Koormab vähem, eriti uus veebikilp mis ei kasuta enam kohalikku proxyt, et liiklust kontrollida (eeldusel, et sul on Windows 7 või uuem Windows). Olen ise tähele pannud, et alguses on arvuti suht uimane avast!'iga, aga pärast päeva kasutamist muutub OKiks, kuna avast! whitelistib osad rakendused ja muud asjad ära
52 |
estdata
28.12.2013 21:12:41
Päris huvitav:
Peab olema eesti keeles. Koormab vähem, eriti uus veebikilp mis ei kasuta enam kohalikku proxyt, et liiklust kontrollida (eeldusel, et sul on Windows 7 või uuem Windows). Olen ise tähele pannud, et alguses on arvuti suht uimane avast!'iga, aga pärast päeva kasutamist muutub OKiks, kuna avast! whitelistib osad rakendused ja muud asjad ära  |
või jaab whitelistima ja arvuti kogu aeg uimane kuda siis f-secure ja avast vahel asjad on
16 |
-kristo
13.02.2014 21:26:07
Kas see uus uuendus on mingi lahjem kui eelmine või ma lihtsalt ei leia seda avasti foorumist üles et teada saada mis siis uut on.
Lord Ami
52 |
-kristo
18.02.2014 14:47:49
Uuendasin ära aga kuidas ma selle saan tagasi et aastane proovi versioon oleks ?
Edit: lasin uuenduse maha nüüd korras
Lord Ami
52 |
