Jäi silma "sahin", et Moto X saab endale 2xMIMO antennisüsteemi. Kui nii, siis see saab olema ISP-dele peagi suurem peavalu, kuidas hakata ehitama, nutitelefonide tarbeks, ultramoodsat 2XMIMO levisüsteemi. The device, which Motorola has been touting heavily over the July 4 holiday, will boast dual LTE MIMO (Multiple-Input, Multiple-Output) antennas, so says Taylor Wimberley, founder of Android and me.
The tech, more commonly associated with high-speed Wi-Fi, means there'd be two antennas pulling in and spitting out downloads and uploads at the same time, increasing speeds for owners of the device. Could the Moto X smartphone sport the fastest LTE speeds on the block? http://leandrahallis.blogspot.com/2013/09/could-moto-x-smartphone-sport-fastest.html
Ja samalaadne "sahin" ka veidi varasemast ajast:
In a nutshell as well as in regular English, the dual LTE MIMO smart antenna would mean a couple of LTE-capable antennas which will be able to receive and send data simultaneously, where the logical conclusion would be experiencing a faster data exchange. You could more or less equate that to widening a 2-lane highway into a 4-lane one. Are you stoked by this particular rumor should it actually turn out to be true?: Moto X Could Come With Dual LTE MIMO Smart Antenna: http://www.ubergizmo.com/2013/07/moto-x-could-come-with-dual-lte-mimo-smart-antenna/
... ja väidetavalt on põhjuseks, et keegi ei tee neile siin ametlikku hooldust (Motorola'dele st). _________________ Kõik ülalpool öeldu on minu isiklik arvamus, ei vastuta kõikide faktide korrektsuse eest.
üksvahe ju müüsid tolasid küll siin, sõber ostis ~1,5a tagasi EMT-st RAZR MAXX-i. et kui keegi neid ei hoolda, tea mis siis saab kui see peaks nüüd garantiid vajama? saadavad kuskile välismaale? _________________ nooope!
Suhtlesin alles hiljuti MTTC Eestiga , kuna toon maale Moto G telefone ning nende vastus oli, et nende kaudu käib garantii remont. Ei oska muidui öelda, kuidas asi on amazonist tellitud isenditega.
kuna nexuse kogemus puudub siis ei oska kommenteerida (kuigi youtubis võrdlusi enne ostu vaatasin siis jah nexusel numbinäit aku osas parem, aga tegelik elu vastupidine. Seal öeldi, et motorola vennad on teineud väga hea arhitekti töö). Aga reaalsus mul endal igapäevane kasutus, siis aku 2 päeva peab vastu hetkel.
endiselt rahul, ainuke mille kallal võib nuriseda on pildikvaliteet.
Asi mis mulle väga meeldib on see, et taskust võttes ilma nupule vajutamatta näed kas sul on meil tulnud vms. Vaatasin uut androidi esitlust ja tundub et Android L-ile pannakse ka miskit sarnast külge. Õnneks on X-il OLED ehk siis kasutab ainult väikest osast displayd ehk siis akut ei söö.
Kurat, panin mööda täiega. Telefon on LTE/CDMA only
Tegin bootloaderi lahti ja proovisin mingit patchi, aga asjatult vist. Pole nii pädev selles teemas...
XT1060? Sel juhul Eestis pole suurt peale hakata.XT1052 oleks parim, Euroopa mudel, millel ka 4G LTE töötab.
XT1058'l peaks töötama kõik peale 4G LTE, sagedused ei klapi, vähemalt Elisa puhul.Vähemalt kättejuhtunud eksemplaril on ekraan ebameeldivalt sinakam kui Moto G'l.Active Display ning telefoni suutlikus sleep'ist ise välja tulla laualt/taskust võttes on vägagi märkimisväärne lisamugavus.
Kas kuskilt veel Euroopa XT1052 varianti ka saada on? Ebay pakub vaid mõnd üksikut ning need ligi 300 EURi, Aliexpressis on vaid XT1058 mudel kuid üsna hea hinnaga - kuskil 180.-
