praegune kellaaeg 08.11.2026 10:38:43
Codecci
02.06.2013 17:21:47
Uuel telekal poedemo |
| Ostsin Samsungi 46" teleka, UE46ES5500 ja debiilne probleem - mingi poedemo režiim on peale jäänud, ehk vasakus nurgas näitab koguaeg igast logosid, nö reklaamina teleka funktsioone "SmartTV, digilevi" jne. Seadetest kuskilt sellist varianti ei leidnud kust maha saaks keerata. Keegi ehk oskab nõu anda?
| Kommentaarid: 22 loe/lisa |
20 |
02.06.2013 17:23:40
Codecci, vaata kas töötab ka selle mudeli puhul
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears.
2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar.
2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode. |
Allikas: http://www.neowin.net/forum/topic/651922-samsung-ln46a550-issue/
7 :: |
364 |
Codecci
20 |
