ABC
23.05.2013 01:23:51
Ülevaade: Roccat Kone XTD |
Tekkis võimalus Roccatilt saada ülevaate eesmärgil antud toode. Hetkeseisuga (22.05.2013) on see nende parim, kalleim hiir ning olen seda kasutanud umbes 5 päeva.
Kohale jõudis üpriski kiiresti. Üllatuseks oli muidugi see, et kella 11 paiku hommikul marssis DHL ukse taha ilma sellest ette teatamata.
Tuli päris suures pappkastis, kus sees oli 2 väikest karpi hiirtega ja korralikult mullikilet.
Hiire andmed inglise keeles.
Features
FULLY-ADJUSTBALE 8200DPI PRO-AIM (R3) SENSOR
with 41 true DPI setting ranging from 200 to 8200
ROCCAT™ CLICK MASTER
switch tech powered by Omron© for precision button activation
EASY-SHIFT[+]™ BUTTON DUPLICATOR
with Easy-Aim + Easy-Wheel functions for max command power
32-BIT TURBO CORE V2 PROCESSOR
for lightning-fast computing speed
TRACKING & DISTANCE CONTROL UNIT
for less pick-up flight & more precise gaming
576KB ON-BOARD MEMORY
for storing a wealth of macros and settings
4-LED LIGHT SYSTEM
for customizable colors + effects
7 buttons + tiltable mouse wheel
for a full complement of command options
4 EASY-TO-CLIP-IN WEIGHTS (4 X 5G)
for customized weight adjustment
ROCCAT™DRIVER + MACRO MANAGER
for advanced customization + presets for games & apps
ROCCAT™ ACHIEVEMENTS DISPLAY
for monitoring gaming performance
Technical Specifications
Pro-Aim Laser Sensor R3 with up to 8200dpi
1000Hz polling rate
1ms response time
12000fps, 10.8megapixel
30G acceleration
3.8m/s (150ips)
16-bit data channel
1-5mm Lift off distance
Tracking & Distance Control Unit
72MHz Turbo Core V2 32-bit Arm based MCU
576kB onboard memory
Zero angle snapping/prediction
1.8m braided USB cable
Additional Info
Dimensions
Max. length 13.5cm x approx. 7.8cm max. width. 4cm high.
Weight
Approx. 123g (excl. cable) +4 optional weights in 5g, 10g, 15g or 20g
System requirements
Windows® XP/Windows Vista® 32/64-bit/Windows® 7 32/64-bit
Windows® 8 / Windows® 8 Pro
USB 2.0 port
Internet connection for driver installation
Pakend ise on kena, lahti saada polnud ka raske, võrreldes näiteks Razeri kõrvaklappide pakenditega.
Pildid pakendist:
Kindlasti ei huvita enamusi pakend, vaid just see, mis sealt pakendist välja tuleb. - Kaaluvihid, kasutusjuhend ja muidugi hiir ise.
Hiir on mugav, kuid veidi raskendatud on minu jaoks DPI + ja - nuppude vajutamine.
Sellel on sleevitud kaabel, 7 füüsilist nuppu ja kolmes suunas vajutatav rullik. Enamikele nuppudele saab lisada EASY-SHIFT[+] abil ka teise funktsiooni.
Siiamaani on hiir olnud väga täpne ja ei ole mind alt vedanud, on enam-vähem sama täpne ka tavalisel puidust laual.
Rulliku kogemata vajutamist siiani ette pole tulnud.
Olles seda natukene kasutanud ning nuppe veidi sättinud otsustasin RTCW:ET-d mängima hakata.
Kuigi ma polnud seda umbes 1a. mänginud ning enam-vähem sama aja ka touchpadil elanud ei olnud vastastele pihta saamine mingi probleem.
Hiirt matilt tõsta pole mul enamasti vaja, kuid seal peitub probleem: hiir libiseb tõstes kergesti käest isegi ilma kaaluvihtideta. Koos kaaluvihtidega on see pea võimatu. Kaaluvihtidest endast nii palju, et nende hoiukarbist välja saamine on raskendatud. Hiirest nende välja saamist näppudega ei ole mõtet proovidagi, ka magnet ei toiminud. Üritasin umbes 10 minutit ning siis võtsin appi näpitsad, millega need üpriski kergelt sealt kätte saab. Näpitsaid hiire kasutamisel siiski vaja minema ei peaks.
Pilte hiirest ja kaaluvihtidest:
Tore lisa on ka hiire valgustus, täpsemalt siis 4 LED-i, neil saab muuta värve ja lisada erinevaid efekte.
Tegin nendest "Demo" video.
https://vimeo.com/66770085
Tarkvara on lihtne kasutada, probleeme seda kasutades tekkida ei tohiks.
Mõned kuvatõmmised tarkvarast:
Kokkuvõte ja hinnang:
Üldiselt mugav hiir, minu jaoks väikeste/mitte oluliste puudustega (hiire tõstmisel selle käest libisemine, kaaluvihtide eemaldamise raskus, DPI nuppude vajutamine pole just eriti mugav), mille kaaluvad üles erinevad lisafunktsioonid, hiire kena välimus ja mugavus.
Mugav
Ilus
Kallutatav rullik, mida saab kerida ka kalde all
EASY-SHIFT[+] abil nuppudele teiste funktsioonide lisamine
Sleevitud kaabel
Lihtne tarkvara
Täpne
LED valgustus
Macile drivereid ei tehta
Minu jaoks halvasti paiknevad DPI +,- nupud
Roccati logo pole valgustatud
Kaaluvihtide eemaldamine on raske
Tõstes libiseb kergesti käest
Hinnates seda kümne punkti skaalal, paneks mina hindeks 8.
Toode HinnaVaatluses: https://www.hinnavaatlus.ee/products/Arvutiriistvara/Hiired+ja+hiirematid/281760/
Soodsaimalt peaks selle kätte saama Photopointist, makstes NPNK kaardiga saab 20% soodustust.
Vabandan piltide kehva kvaliteedi pärast ning kui peaks esinema kirjavigu, andke sellest teada!
Tänan Roccatit mulle selle toote saatmise eest.
Roccat Kone ülevaade Worm390lt: https://foorum.hinnavaatlus.ee/viewtopic.php?t=437942
Toode Roccati lehel: http://www.roccat.org/Products/Gaming-Mice/ROCCAT-Kone-XTD/
viimati muutis ABC 30.05.2013 11:35:50, muudetud 4 korda |
| Kommentaarid: 11 loe/lisa |
seeMees
23.05.2013 07:55:14
Roccat Kone lagunes mul enne garantiiaja lõppu (õnneks) - üks klahvidest lakkas normaalselt töötamast. Ühe kliki asemel tegi kaks või siis mitte midagi. See oli siis esimese versiooni isend.
Kuna Kone enam ei toodetud sain vigase roti asemele Roccat Kone +.
Mul sellised väiksemapoolsed "kontoriroti", mitte pikkade sõrmedega klaverimängija käed ja kuidagi ära väsitas see hiir. Liiga suure küüruga vist minu jaoks. Et kellel pisikesed käed, siis ei soovita.
Draiveritega oli mingi jama, isegi Roccati enda Taito matil pidi hiirt üsna tihti uuesti kalibreerima. Tihti ei rakendunud profiilid etteantud programmidega/mängudega, või vahetusid lihtsalt puust mängu ajal. Ohverdasin ühe nupu siis vastava makro jaoks. Loodetavasti on need vead nüüdseks parandatud. Jutt Wind7'st, Macile Roccat draivereid ei tee.
Meeldisid tolle hiire puhul EASY-SHIFT[+] ja rulliku funktsionaalsus. Selles suhtes teeb teistele nn mängurihiirtele küll ära.
Mõni aeg tagasi sai Helsingis Verkkokauppas igasuguseid närilisi peos hoitud ja proovitud. (Sellist võimalust kahjuks Eestis pole kusagil.)
Ja üsna pea sai selgeks, et Razer Imperator on just see, mis minu käele sobib. Draiverid ka olemas nii Winnile kui Macile (kasutan mõlemat). Mõeldud, tehtud - rott laual ja käsi vägagi rahul.
Pika jutu kokkuvõtteks:
Roccat - sõbrale ei soovita (kahe hiirega ebameeldiv kogemus),
Imperator - soovitan igati just väiksema käega mänguritele (siiani ülimalt rahul).
ABC
23.05.2013 16:28:14
| seeMees, Lisan selle, et Macile drivereid ei tehta miinustesse.
softis
23.05.2013 19:05:52
seeMees, Hp-Compaq, Roccati toodang on suunatud siiski mänguritele ja Maci peal väga ei ole neid mänge... Seega miinuseks panna seda on veidi rumal tegu. Pigem miski nii ja naa variant.
| Kommentaarid: 21 loe/lisa |
21 |
seeMees
24.05.2013 07:12:22
| softis kirjutas: |
seeMees, Hp-Compaq, Roccati toodang on suunatud siiski mänguritele ja Maci peal väga ei ole neid mänge... Seega miinuseks panna seda on veidi rumal tegu. Pigem miski nii ja naa variant.  |
Razeri toodang on samuti suunatud mänguritele. Ja just selle pärast ma Imperatori ostsingi, et mängin just iMac'il.
Need mängud (mis mind huvitavad) on Mac'ile täiesti olemas.
See on üldse mingi iganenud mõtteviis, et Mac'idele mänge ei tehta
Kuid jah, see vast arvustaja oma suva, kas loeb seda miinuseks või mitte.
Minu jaoks on see muidugi suur miinus.
summutaja
24.05.2013 08:01:18
Küsiks, et kuidas on lood Lift-Off-Distanciga? Kui tõstad hiire matilt üles ja paned selle matile tagasi, kas hiire kursor vahetab oma algset asukohta ja kui palju? (driverites saad seda sättida, huvitaks option "ultra low".
See saab saatuslikuks just FPS mängudes, kui see hiir hüppab.
| Kommentaarid: 124 loe/lisa |
117 |
ABC
24.05.2013 10:27:35
summutaja, Jään hetkel vastuse võlgu, kuna see funktsioon ei tööta kasutusel oleval hiirematil. Üritan sellele kiiremas korras asenduse leida.
Sai ka Roccatilt küsitud, vastati, et valged tsipa peegeldavad pinnad võivad problemaatilised olla.
Tõstsin siis hiire puust lauale ning töötas päris kenasti. Sinu asemel ootaksin siiski ära selle korraliku hiirematiga katsetamise, aga räägin siis lähemalt sellest Ultra low'st laual.
Ei usu, et "keset sõda" oleks väga aega tõstmiseks parem asend võtta seega
-Hiire tavalise käes hoidmise pealt tõstmine ~1cm liigub kursor.
-Ilusti kinni võtta ja vähe hoolikamalt tõsta siis liigub mõni mm.
summutaja
24.05.2013 11:07:35
| Hp-Compaq kirjutas: |
-Ilusti kinni võtta ja vähe hoolikamalt tõsta siis liigub mõni mm. |
Oskad sa öelda, mis DPI`ga sa seda testisid? Kui sul võimalik, siis määra 4000DPI ja pane ultra low peale ja vaata palju siis liigub, kui hoiad hiirt normaalselt käes ja tõstad üles ja paned tagasi matile.
Lisaks jään korraliku matiga tulemusi ootama
117 |
ABC
24.05.2013 12:24:01
Tõstsin DPI 4000-ni
Koputasin ~20 korda õrnalt vastu lauda tõstes ~1cm kõrgusele ja tulemus oli päris hea, kursor ei liikunud üldse või liikus mõni mm. liikumist oli kusjuures harvem.
summutaja
24.05.2013 12:49:10
Tõstsin DPI 4000-ni
Koputasin ~20 korda õrnalt vastu lauda tõstes ~1cm kõrgusele ja tulemus oli päris hea, kursor ei liikunud üldse või liikus mõni mm. liikumist oli kusjuures harvem. |
See oli sul nüüd korraliku matiga tulemus?
117 |
ABC
24.05.2013 13:52:22
Ei.
Aga peaks Steelseries QcK saama mingi tunni või paari jooksul, on vast piisavalt korralik selle jaoks.
Edit: Sain mati kätte, tulemus sellest eriti erinev ei ole: Tõstsin DPI 4000-ni
Lähen teen ET-s ühe tiiru selle mati ja extra low peal, vaatan, kas skoor on parem.
summutaja
24.05.2013 14:34:53
Ei.
Lähen teen ET-s ühe tiiru selle mati ja extra low peal, vaatan, kas skoor on parem. |
OK Ootan huviga tulemusi
117 |
ABC
24.05.2013 14:49:08
Kui nüüd aus olla, siis mulle millegipärast see extra low ei istu. Vajab vast harjumist.
Hiirt matil liigutades tõuseb vahest äär veidi ülesse ja ongi kursor paigal
Mängin veits veel ja annan teada.
summutaja
24.05.2013 14:57:25
Mängin veits veel ja annan teada. |
kui ma mängin FPS`i ja lähi võitluse jaoks kasutan ma ala ~4000 DPI, kohe, kui maast snaipu leian on ühe nupuga DPI 1200. Ma vahest tõstan hiir ka keset matti, paiguta õigesse kohta, et kui ümber nurga lähen siis valmistun suuremaks madinaks seega minu jaoks on väga tähtis, et hiirt liigutades (matilt tõstes) hiire kursor väga ei liiguks.
117 |
ABC
24.05.2013 17:05:44
Soovi korral võin teha video ekraanist.
Mis siis näitab, palju umbes maksimum liigub see kursor.
24.05.2013 17:41:26
See mõneti pseudo teema - eeldab hiirt mis ei tööta ebaühtlasel pinnal...
Ja oluliselt rohkem hoolt ka mati või tööpinnaga...
201 |
lopes39
25.05.2013 17:29:20
miks see sleevitud kaabel pluss on ?
mul on g9x-l ka sleevitud kaabel ja ka kõrvaklappidel razer piranha on see sleevitud kaabel mis koguaeg on keerdus jne
pigem ilma selle riidest katteta juhtme eelis oligi see et läks vähem keerdu
ja see hiire teema et teeb ühe klõpsu asemel kaks on iga uuema hiire viga ... mu g9x teeb ka aegajalt seda ja siis puhudes nuppu alla läheb korda
samas see hiir ülesse läheb põhiliselt optilistel hiirtel .. mul laser hiirel pole seda juhtund ja eemise logitech g3-ga ka seda ei juhtund ja muidugi eelis laseril on ka see et iga pind on ok
80 euro hiire eest makstes võiks neid miinuseid vähem olla
| Kommentaarid: 10 loe/lisa |
ABC
25.05.2013 17:45:46
| lopes39, Sleevitud kaabel on + kuna mulle meeldib see kaabel ja ei ole midagi halba öelda selle kohta. Ei lähe keerdu jms.
enigma
27.05.2013 22:50:30
| Huvitav miks ostsid hiire millel juhe taga?Wiwi hiir oleks ju mugavam olnud?
ABC
27.05.2013 23:43:53
| enigma, ei ostnud.
renekas
28.05.2013 10:09:56
| Muidu need Kone hiired väga head, ise olen rahul aga üks miinus mis neil on: Rullikud tahavad jamama hakata, siis tavaliselt suruõhuga puhtaks ja tiba WD40 vahele ja töötab edasi veatult.
| Kommentaarid: 22 loe/lisa |
21 |
Velociraptor
02.06.2013 18:20:07
Sama asi ju razeriga ka, igal razeril, mida omanud olen on lõpuks rullik lolliks läinud
_________________ 🕊 Kuruppo ぽ 🕊
https://www.last.fm/user/Ingvaarr |
| Kommentaarid: 32 loe/lisa |
30 |
ABC
02.06.2013 19:40:41
| Roccat lubas, et sellel hiirel on need probleemid lahendatud. - eks näeb.
summutaja
03.06.2013 19:19:15
| Velociraptor kirjutas: |
Sama asi ju razeriga ka, igal razeril, mida omanud olen on lõpuks rullik lolliks läinud  |
Väidan vastu Razer surma lisaja olnud 3 aastat töötab laitmatult Sõbral sama case, asi on veatu
117 |
Velociraptor
03.06.2013 22:48:25
Ma arvestan razeri optimaalseks elueaks 1 aasta A noh ma kasutan vast rohkem ja intensiivsemalt
30 |
ABC
04.06.2013 14:19:59
Razeri DeathAdder on sõbral olemas, ka mitmeid aastaid vastu pidanud.
See on vist 1 õnnestunum hiir.
