ufo56
06.05.2013 14:08:13
BitTorrent Sync |
link :: BitTorrent Sync
What is a Secret and how does it work?
A secret is a key that connects different devices and joins them together. We automatically generate secrets to ensure their uniqueness. Since each secret is 32 characters long, it is virtually impossible for the same secret to be automatically generated in two separate instances. After a folder is added to BitTorrent Sync, the Secret is stored in its advanced preferences and can be accessed by double or right click on a folder in the “Folders’ tab.
There are 3 types of secrets: master (full access) secret, read only Secret for one-way sync and one-time secrets (both full access and read-only). Read only and one-time secrets may be generated only for folders operated by master secrets.
If you are concerned about security, BitTorrent Sync provides opportunity to regularly generate new Secrets for a folder, or replace an existing secret with your own Base64 string more than 40 characters long. The new folder Secret should be re-entered on all the devices in sync. |
Ühesõnaga saate LAN'is või üle interneti syncida erinevaid kaustasi ning faile lihtsalt. Jagate kausta välja, teiselpool panete lihtsalt kausta tegemisel saadud salajase võtme ning ongi asi korras.
Töötab nii Windowsi, MacOSX ja Linuxi peal.
PS: tegemist pole illegaalse failijagamisega, vaid võite jagada oma isiklikke faile arvutite vahel jne.
Lae pildid -> pilt.io |
| Kommentaarid: 78 loe/lisa |
67 |
silver010
06.05.2013 14:12:20
| Üle netipulga see asi ikkagis vist ei toimi? Neil torrenti piirangud jne
| Kommentaarid: 45 loe/lisa |
42 |
bitCON
06.05.2013 14:14:20
| silver010 kirjutas: |
| Üle netipulga see asi ikkagis vist ei toimi? Neil torrenti piirangud jne |
ma saatsin edukalt (ülikooli võrk, tavaline torrent ei tööta) faili ja toimis väga hästi.
väga hea asjaga tegu
silver010
06.05.2013 14:43:23
| Kas see asi inkrementaalselt oskab ka (nende lehelt kiire üle vaatamisega ei leidnud)?
42 |
ufo56
06.05.2013 14:58:50
Kui jagad kausta välja ja seal sees mõnda faili muudad siis mõne hetke pärast hakkab ta seda ka remote masinas uuendama.
| In fact, I have a question for that. What happens if I add like 8MB to the end of the file, so no bytes are shifted over. Would it still resync the whole file or just the last 8MB that updated? |
| Sync will sync the 8Mb only. |
67 |
silver010
07.05.2013 15:30:42
| Kas ta üle sisevõrgu oskab ka automaatselt toimetada?
42 |
ufo56
07.05.2013 15:36:18
Oskab. Lannis laseb nii kiirelt kui lan võimaldab.
67 |
prtv
09.05.2013 17:27:43
Läheb käiku
_________________ |
| Kommentaarid: 82 loe/lisa |
73 |
