praegune kellaaeg 18.11.2026 01:56:33
Murtpoiss
28.04.2013 14:39:40
Android: dynamically change layout width. HOW ? |
XML
<RelativeLayout
BLA BLA BLA
BLA BLA BLA
<LinearLayout
android:id="@+id/llAmpBar"
android:layout_width="250dp"
android:layout_height="30dp"
android:layout_below="@+id/bEsitlusloend"
android:layout_centerHorizontal="true"
android:gravity="center" >
<ImageView
android:id="@+id/ivAmpBar"
android:layout_width="fill_parent"
android:layout_height="fill_parent"
android:scaleType="centerCrop"
android:src="@drawable/ampbar" />
</LinearLayout>
</RelativeLayout>
JAVA Class
x on siis mingi muutuja mida saab ise muuta...
int amp = x / 175;
int vamp = 30;
LinearLayout ll = (LinearLayout) findViewById(R.id.llAmpBar);
ll.setLayoutParams(new ViewGroup.LayoutParams(amp, vamp));
Miks see ei tööta ?
kuidas tegema peaks ... google ei aita ka eriti kaasa !
_____________________________________________________________
EDIT:
Sain tööle ... kui keegi tahab siis kood oli selline
LinearLayout ll;
ll = (LinearLayout)this.findViewById(R.id.llAmpBar);
int amp = x/120;
int vamp = 40;
LayoutParams params = ll.getLayoutParams();
params.height = vamp;
params.width = amp;
muidugi see pole kogu kood aga kes tahab saab tööle
| Kommentaarid: 35 loe/lisa |
34 |
