sõnum  |
yerba
19.06.2017 23:59
Tundub jah et on vähemalt RX480 8GB on hakanud DAG epohhi vahetudes kiirust nüüd kaotama:
00:00:24:602 180 ETH - Total Speed: 169.535 Mh/s, Total Shares: 28955, Rejected: 7, Time: 193:39
00:00:24:774 70c Setting DAG epoch #130...
00:00:49:997 180 ETH - Total Speed: 168.918 Mh/s, Total Shares: 28955, Rejected: 7, Time: 193:39
4GB RX480 kaartidega sama lugu:
00:00:37:486 c04 ETH - Total Speed: 168.524 Mh/s, Total Shares: 39663, Rejected: 11, Time: 269:52
00:00:37:736 1360 Setting DAG epoch #130...
00:01:02:926 c04 ETH - Total Speed: 167.771 Mh/s, Total Shares: 39664, Rejected: 11, Time: 269:52
R9 290X kaartidega aga midagi ei muutunud:
00:00:45:055 11e8 ETH - Total Speed: 141.324 Mh/s, Total Shares: 49486, Rejected: 13, Time: 397:00
00:00:45:258 11c8 Setting DAG epoch #130...
00:01:10:816 11e8 ETH - Total Speed: 141.242 Mh/s, Total Shares: 49486, Rejected: 13, Time: 397:01
R9 290 seeria läheb veel eriti hinda nüüd.
https://www.techpowerup.com/234482/eth-mining-lower-vram-gpus-to-be-rendered-unprofitable-in-time
Currently, an epoch takes about 4 to 5 days to conclude until a new one is started. That means that in around five month's time, a user with an RX 470 4GB will see an almost 30% decrease in hash-rate, with the same power consumption of today. And as you know, in mining, power/performance ratio is all that counts for profitability. It is expected that NVIDIA cards being used currently, such as the GTX 1060 3 GB, will see decreases as well. And there are other performance-affecting details that originate from the increased worker size as well, such as TLB (Translation Lookaside Buffer) trashing, which could see performance degradation even before the memory pool of your graphics card of choice is fully loaded, provided the TLB is itself being overflowed... With Polaris, AMD implemented a TLB cache which was, before, absent from the GCN architecture. The small size of this TLB cache means that Polaris graphics cards will likely see performance penalties from TLB trashing before the DAG size increases to their memory limits. Just another point for you to consider.
Now granted, if you know anything about Ethereum, you probably won't even care about this: the passage from PoW to PoS (Proof of Stake) is expected to occur by November 1st of this year. This means that ETH mining will simply cease to be a thing (though this implementation could see some delays, unlikely as that is.) And it lines up nicely with the 5 month, 30% computing power decrease estimation above. So maybe you don't have to worry that much about ETH mining ceasing to be profitable in 5 month's time. But if you are looking to buy into the mining craze and invest in hardware, you should study this market, and this technology, first (and pay attention to this article as well.) Likewise, if you have just recently bought into the mining hardware market with those exorbitantly-priced RX 400 and RX 500 - do the math and be ready to look for alternatives, either in cryptocurrencies or mining solutions. Don't let yourself be burned just because you want to follow the train.
Viilutaja
20.06.2017 09:47
| Miks see R9 290 seeria hinda läheb? Ma ei ole selle kaevandamisega üldse kursis ega tegelenud, seega puhtalt uudishimust ajendatud küsimus.
yerba
20.06.2017 09:51
| Viilutaja kirjutas: |
| Miks see R9 290 seeria hinda läheb? Ma ei ole selle kaevandamisega üldse kursis ega tegelenud, seega puhtalt uudishimust ajendatud küsimus. |
Tsiteerin end uuesti.
Slaava007
20.06.2017 10:22
Kellelgi eruptereid või mingeid USB minereid ala Butterfly Labs jne on pakkuda?
_________________ Arvutite tellimustööd, erilahendused. hooldus. |
Viilutaja
20.06.2017 12:46
| yerba kirjutas: |
R9 290X kaartidega aga midagi ei muutunud: |
Ok, küsin siis teistpidi, miks nende jaoks midagi ei muutunud?
yerba
20.06.2017 13:02
Oh jah, ma pean seda juttu nüüd uuesti siia kirjutama hakkama. Inimesed, miks te ise lugeda ei viitsi?
| yerba kirjutas: |
Ok, küsin siis teistpidi, miks nende jaoks midagi ei muutunud?  |
PPC
20.06.2017 14:57
280x 100 eur eest siis varsti on ka parem kui rx580 400 eest?
yerba
20.06.2017 15:47
Eiole
PPC
20.06.2017 15:55
No jah, vaatasin - neil on erinev m2lu (bus, gb) v6rreldes 290-ga. M6tlesin, et 280 on 290X praak.
Igal juhul m6tlen, et muua oma r9 290 ja osta 1060 oli rumal idee. Tundub, et varsti teenib see nagu x2 gtx1060 ja maksab 3 korda v2hem
yerba
elukaz
23.06.2017 18:46
Läheb sots võistluseks kes rohkem kaarte käima saab
dohc-48v12
23.06.2017 19:02
näha jah et hetkel ainult 8 kaarti järel Ülejäänud kuus slot-i vaba.
Aga paistab et 1080ti suudab ETH-s teha 39Mh/s ka ~265w-ga
_________________ Ime tala, Nagu ime kepike.
Siga armastab muda, aga mudane siga armastab puhast aset! |
Wusses
mehine eesti muffin
26.06.2017 12:34
Tasub hetkel kaevandamine ära?
Vaatasin mingit bitcoini kalkulaatorit ja sain et 1x 280x teenib umbes 0,04s kuus.
Või olen ma väga valesti aru saanud kaevandamisest
_________________ Ryobi,Milwaukee,AEG,Makita,paslode,senco - remont
Ostan ZX9 doonorit, käigukasti 1999-2004 |
yerba
26.06.2017 12:48
| Wusses kirjutas: |
Või olen ma väga valesti aru saanud kaevandamisest |
See on okei. Näiteks on Sul 100tk neid kaarte ja saad juba 4$ kuus. Eeldab küll tasuta elektri olemasolu.
Hazar
26.06.2017 12:53
| elukaz kirjutas: |
Läheb sots võistluseks kes rohkem kaarte käima saab  |
Kuskil jäi silma postitus, et hetkel saab selle platega ainult 6 videokaarti käima tõmmata. Minuteada rekord üldse on olnud ühe supermicro serveri plate peal 11 korraga pärast suuremat biose, windowsi ja draiverite häkkimist.
_________________ Sinuweb valmistab kodulehekülgi |
mikk55
Aeg maha 1p
26.06.2017 13:27
Mida siinsed kaevurid äikese korral teevad? Puhkepaus või usaldus Seasonic toidete või Corsair AX seeria jne vastu .
_________________ Tegelen autovõtmete lisamisega (peamiselt BMW ja Mercedes) ja osade autode puhul ka plokkide kodeerimisega jne.
M: W212 2012 e class sedaan varuosadeks, kere sile tehnika ok, euroopa auto |
yerba
26.06.2017 13:37
| mikk55 kirjutas: |
Mida siinsed kaevurid äikese korral teevad? Puhkepaus või usaldus Seasonic toidete või Corsair AX seeria jne vastu . |
Tuleb kaevurid koormakilega kinni katta, võib vihma tulla.
-huviline-
26.06.2017 15:19
| mikk55 kirjutas: |
Mis äike, mul on varras toitekast otse taevasse. Põhimõtteliselt tasuta elekter ju - oleks seda äikest vaid rohkem...
_________________ SC: -huviline-
Steam: Huviline |
-vodafone-
26.06.2017 15:30
| -huviline- kirjutas: |
| mikk55 kirjutas: |
Mis äike, mul on varras toitekast otse taevasse. Põhimõtteliselt tasuta elekter ju - oleks seda äikest vaid rohkem... |
rammus ups ka vahele, siis saab mõned tunnid peale äikest ka pimedas kaevata. Elu nagu päriskaevanduses.
xtr
26.06.2017 15:51
Mina laen serveriruumi upsi niimoodi suvel tasuta elektriga täis.
_________________ M: 3TB HDD
M: Ryzen 5600X, 5800X
M: Synology DS415+, UniFi AP |
Catfish
26.06.2017 18:46
Pole tükk aega kaevamisega tegelenud.
Praegu jalg lõhki, mõtlesin et kiusaks igavusest veidi vanu kaarte (270x, 280x)
Annab nendega üldse midagi kaevata tänapäeval??
Proovisin XMR-i: 6-tuumaline prose annab igatahes rohkem välja kui kaardid
On kellelgi häid ideid
dohc-48v12
26.06.2017 20:09
eth/Zcash/etc. Kindlasti on veel mida kokku kühveldada. Otsinkusse gpu mining.
elukaz
27.06.2017 01:38
280x kühveldab exp-i umbes sama hästi kui 470, tasuvus on sarnane ethiga. Aint voolu võtab poole rohkem.
Kui aja ülejääk on siis võid mälu taimingute biosmodi harjutada, 270x annab sedasi 20Mh välja. Parim bang for buck.
anubis
Wusses
mehine eesti muffin
28.06.2017 11:47
Mõtlesin ka et harin ja proovin kodus kaevadamist. Puhkus ja midagi targemat pole teha
Sain veidi imelikud numbrid 270x kohta, eriti see esimene
viimati muutis Wusses 28.06.2017 12:07, muudetud 1 kord |
