praegune kellaaeg 18.11.2026 02:13:16
R A T
27.02.2013 17:00:50
Powershell Listview Context menu |
Küsimus järgmine, Powershelli GUI formis oleks vaja listview context menu käima saada.
Kahjuks ei võta see aga "add_click()" meetodit külge.
Kuidas seda teha saaks?
Koodinäide siin (sobib copy paste PS ISE-sse ja F5):
#Build the GUI
[xml]$xaml = @"
<Window
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
Title="Näide" Height="350" Width="525">
<Grid>
<ListBox x:Name="list_folders" HorizontalAlignment="Left" Height="300" Margin="10,10,0,0" VerticalAlignment="Top" Width="225" IsTabStop="True" IsTextSearchEnabled="False" TabIndex="1">
<ListBox.ContextMenu>
<ContextMenu>
<ComboBoxItem x:Name="btn_add" Content="Add"/>
</ContextMenu>
</ListBox.ContextMenu>
<ListBoxItem Content="Asi"/>
</ListBox>
<Button x:Name="btn_run" Content="Vajuta mind" HorizontalAlignment="Left" Margin="319,272,0,0" VerticalAlignment="Top" Width="104" Height="38" TabIndex="12"/>
</Grid>
</Window>
#Load the GUI
$reader=(New-Object System.Xml.XmlNodeReader $xaml)
$Window=[Windows.Markup.XamlReader]::Load( $reader )
#MAP RUN BUTTON
$btn_run=$window.FindName("btn_run")
$btn_run.Add_Click({
Write-Host "Nüüd vajuta vasaku listi peal paremat hiirenuppu ja vali: $($window.FindName("btn_add").Content)"
#MAP CONTEXT MENU ADD BUTTON
$btn_remove=$window.FindName("btn_add")
$btn_remove.Add_Click({
Write-Host "THIS DOES NOT HAPPEN!"
#Execute the GUI
$Window.ShowDialog() |
31 |
