uus teema   vasta Tarkvara »  Programmeerimine »  Probleem wsgeniga märgi kõik teemad loetuks
SirShark
sõnum 05.02.2013 20:30:45 Probleem wsgeniga vasta tsitaadiga
Kui teen netbeansis buildi saan vastuseks
C:\Users\Martin\Documents\NetBeansProjects\WebServices\build.xml:23: Problem: failed to create task or type wsgen
Cause: The name is undefined.
Action: Check the spelling.
Action: Check that any custom tasks/types have been declared.
Action: Check that any <presetdef>/<macrodef> declarations have taken place.
BUILD FAILED (total time: 1 second)
nüüd panin solutioni XMLi ja kisas nii :
C:\Users\Martin\Documents\NetBeansProjects\WebServices\build.xml:21:
java.lang.SecurityException: Dangerous reflection access to sun.misc.ClassLoaderUtil by class com.sun.istack.tools.ProtectedTask detected!
at org.netbeans.TopSecurityManager.checkMemberAccess(TopSecurityManager.java:428)
at java.lang.Class.checkMemberAccess(Class.java:2157)
at java.lang.Class.getDeclaredMethod(Class.java:1934)
at com.sun.istack.tools.ProtectedTask.execute(ProtectedTask.java:138)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:291)
at sun.reflect.GeneratedMethodAccessor221.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:392)
at org.apache.tools.ant.Target.performTasks(Target.java:413)
at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1399)
at org.apache.tools.ant.Project.executeTarget(Project.java:1368)
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
at org.apache.tools.ant.Project.executeTargets(Project.java:1251)
at org.apache.tools.ant.module.bridge.impl.BridgeImpl.run(BridgeImpl.java:283)
at org.apache.tools.ant.module.run.TargetExecutor.run(TargetExecutor.java:541)
at org.netbeans.core.execution.RunClassThread.run(RunClassThread.java:153)
BUILD FAILED (total time: 5 seconds)
Kommentaarid: 35 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 29
Fukiku
Fukiku
sõnum 05.02.2013 23:18:10 vasta tsitaadiga
Kerge guugeldamise järel tundub, et tegemist on NetBeans'i bugiga. Viimastes 7.3 nightly'des peaks ta parandatud olema nende Bugzilla andmetel, samas seal võib muid asju katki olla. Seda ei suutnud kahjuks hoobilt välja raalida, kui vana build praegune 7.3 RC1 on, mida allalaadimiseks pakutakse.
Foxic is just a simple fox
Enne kui sa küsid oma küsimuse - küsi seda vannipardilt! Rangelt soovitatav enne programmeerimise alafoorumisse uue teema tegemist.
SirShark
sõnum 06.02.2013 09:36:46 vasta tsitaadiga
mul see 7.3 RC1
oskab keegi seletada kas NetBeansi projekte on võimalik eclipsesse saada?
E: Täpselt sama solution XML failiga NetBeans 7.1.2 saan teise errori.
java.lang.VerifyError: (class: com/sun/xml/ws/db/toplink/JAXBContextFactory, method: newContext signature: (Lcom/sun/xml/ws/spi/db/BindingInfo;)Lcom/sun/xml/ws/spi/db/BindingContext;) Incompatible argument to function
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:247)
at com.sun.xml.ws.util.ServiceFinder$LazyIterator.next(ServiceFinder.java:460)
at com.sun.xml.ws.util.ServiceFinder$CompositeIterator.next(ServiceFinder.java:402)
at com.sun.xml.ws.spi.db.BindingContextFactory$1.hasNext(BindingContextFactory.java:80)
at com.sun.xml.ws.spi.db.BindingContextFactory.factories(BindingContextFactory.java:110)
at com.sun.xml.ws.spi.db.BindingContextFactory.create(BindingContextFactory.java:176)
at com.sun.xml.ws.model.AbstractSEIModelImpl$1.run(AbstractSEIModelImpl.java:213)
at com.sun.xml.ws.model.AbstractSEIModelImpl$1.run(AbstractSEIModelImpl.java:186)
at java.security.AccessController.doPrivileged(Native Method)
at com.sun.xml.ws.model.AbstractSEIModelImpl.createJAXBContext(AbstractSEIModelImpl.java:186)
at com.sun.xml.ws.model.AbstractSEIModelImpl.postProcess(AbstractSEIModelImpl.java:111)
at com.sun.xml.ws.model.RuntimeModeler.buildRuntimeModel(RuntimeModeler.java:318)
at com.sun.xml.ws.db.DatabindingImpl.<init>(DatabindingImpl.java:99)
at com.sun.xml.ws.db.DatabindingProviderImpl.create(DatabindingProviderImpl.java:74)
at com.sun.xml.ws.db.DatabindingProviderImpl.create(DatabindingProviderImpl.java:58)
at com.sun.xml.ws.db.DatabindingFactoryImpl.createRuntime(DatabindingFactoryImpl.java:130)
at com.sun.tools.ws.wscompile.WsgenTool.buildModel(WsgenTool.java:236)
at com.sun.tools.ws.wscompile.WsgenTool.run(WsgenTool.java:124)
at com.sun.tools.ws.ant.WsGen2.execute(WsGen2.java:564)
at com.sun.istack.tools.ProtectedTask.execute(ProtectedTask.java:103)
at sun.reflect.GeneratedMethodAccessor99.invoke(Unknown Source)
at org.apache.tools.ant.module.bridge.impl.BridgeImpl.run(BridgeImpl.java:285)
at org.apache.tools.ant.module.run.TargetExecutor.run(TargetExecutor.java:539)
Fukiku
Fukiku
sõnum 06.02.2013 09:40:37 vasta tsitaadiga
Kas sa neid vigu ise googeldada oled proovind? Ka eelmisele su postitusele vastasin peamiselt google esimese tulemuse põhjal. Samuti paistab su küsimusele NetBeans -> Eclipse kolimise kohta infot olema küll, kui google käest küsida.
Pole ju mõtet teistel sinu eest googeldada ja siia vastust ümber trükkida. icon_smile.gif
