praegune kellaaeg 08.11.2026 10:08:27
21.01.2013 11:01:43
Fujitsu arendas välja lihtsa failiedastuse arvuti monitorilt mobiilile |
link :: Fujitsu
Jaapani tehnohiid Fujitsu arendas välja tehnoloogia, millega saab võrku ühendatud arvuti ekraanilt tuvastada näiteks videomaterjali või presentatsiooni algupära ja asukohta ning lasta seda kopeerida teise kaameraga seadmesse, näiteks mobiiltelefoni. Tehnoloogia eeldab silmale nähtamatu kujutiste ühildamist videomaterjali sisse, mida mobiiltelefon siis tuvastada saab ja selle üle võrgu alla laadida saab.
Kujutised sisaldavad informatsiooni nagu IP-aadress ja arvuti täpne konfiguratsioon, et tuvastada võrgus olev arvuti. Algset videomaterjali muutma ei pea, kujutise ühildamist saab teostada reaalajas arvutiekraanil spetsiaalse tarkvara abil.
Tehnoloogiat tutvustatakse mobiilsete seadmete teemalisel messil Mobile World Congress Barcelonas, 25-28. veebruaril.
Kawasaki, Japan, January 21, 2013 — Fujitsu Laboratories Limited today announced the development of technology that makes it possible to transfer files between a PC and a mobile device by simply using a mobile phone or tablet to capture a video of a file displayed on a PC screen. The new technology is based on Fujitsu Laboratories' previously developed intermediary image communications technology(1), which enables communication between a PC screen and a mobile device by superimposing invisible communications data into images that can be captured by a mobile phone camera.
By superimposing IP addresses and other device-specific information that is invisible to the human eye onto a PC screen in real time, the technology can identify the target PC when the user takes a video of the screen with a mobile phone camera. A communications path between the target PC and mobile phone then gets established and transfers the file displayed on the screen to the phone. This makes it easy to transfer a file with a simple image capture, unlike existing methods that require complicated operations, such as having users search for and select a file from the phone's file menu. The technology is expected to lead to a variety of applications, such as forwarding photographs captured on a mobile phone to a PC or enabling multiple users to simultaneously download individual copies of presentation materials to their mobile phones during a meeting by shooting the screen displaying the presentation.
This technology can superimpose invisible communications data within the PC screen in real time. Such communications data—including IP addresses, SSIDs or other any related IDs—is used for the purpose of identifying a PC that is connected to the network. To superimpose the communications data, Fujitsu Laboratories' intermediary image communications technology is employed. The intermediary image communications technology superimposes microscopic light signals into the image, and by adjusting the number of these light signals, it can transmit information through the soft projection of light, similar to how optical communications work. The technology is used to convert communications data into signals that are invisible to the human eye, and superimpose them into the PC's desktop. Because the signal is superimposed in the desktop, no modifications to the original files are required. The technology enables the target PC to be identified simply by shooting a video of the PC screen with a mobile phone camera.
Allikas: http://www.fujitsu.com/global/news/pr/archives/month/2013/20130121-01.html
7 :: |
364 |
21.01.2013 11:57:38
Ma lugesin küll ja oleks nagu eesti keel, aga aru ei saanud essugi.
Mida ma aga originaalartiklist aru sain pilku üle libistades, on siis lühidalt kokku võttes tegemist tarkvaraga, mis näitab PC ekraanil inimsilmale tajumatut kujutist infoga arvuti võrguaadressist, autentimise infost ja faili asukohast/nimest, mida sama tarkvara nutifoni versioon kaamera abil suudab tuvastada ja siis juba automaatselt PC-sse sisse logida ja fail nutifoni laadida.
Ehk siis praktiliselt näiteks toimuks see nii, et:
1. PC-s osutad kõnealust tarkvara kasutades failile, mida tahad nutifoni laadida;
2. Tarkvara tekitab PC ekraanile silmale tajumatu kujutise PC aadressi, autentimise ja faili infoga ja vajadusel ka Wifi võrku logimise infoga;
3. Nutifonil käivitatud app käivitab kaamera, sa suunad selle PC ekraanile ja app tuvastab ekraanil oleva info;
4. Ekraanilt saadud info põhjal võtab nutifoni app PC-ga ühendust ja tõmbab faili nutifoni.
Jääb ära igasugune käsitsi autentimise tüli, ehk lihtsalt piiks-piiks ja fail tuleb.
viimati muutis Dogbert 21.01.2013 12:19:16, muudetud 1 kord |
7 :: |
364 |
Mario.
21.01.2013 12:57:48
Mõned neli kuud tagasi:
6 :: |
217 |
