16.01.2013 16:56:40
Programmeerija lasi oma töö firma teadmata teha Hiinas |
link :: The Register
USA-s toimus kurioosne juhtum, kus avastati ühe kriitilise tähtsusega firma turvaauditi käigus, et firma tippprogrammeerija lasi oma töö teha allhankena firma teadmata ühel Hiina firmal. Firma töötaja ise aga samal ajal kulutas oma aega parajaks erinevates suhtluskeskkondades. Juhtum avastati VPN logisid uurides, kui märgati Hiina IP-aadresse. Ei pea ilmselt lisama, et see programmeerija enam selles firmas ei tööta.
A security audit of a US critical infrastructure company last year revealed that its star developer had outsourced his own job to a Chinese subcontractor and was spending all his work time playing around on the internet.
The firm's telecommunications supplier Verizon was called in after the company set up a basic VPN system with two-factor authentication so staff could work at home. The VPN traffic logs showed a regular series of logins to the company's main server from Shenyang, China, using the credentials of the firm's top programmer, "Bob".
"The company's IT personnel were sure that the issue had to do with some kind of zero day malware that was able to initiate VPN connections from Bob's desktop workstation via external proxy and then route that VPN traffic to China, only to be routed back to their concentrator," said Verizon. "Yes, it is a bit of a convoluted theory, and like most convoluted theories, an incorrect one."
After getting permission to study Bob's computer habits, Verizon investigators found that he had hired a software consultancy in Shenyang to do his programming work for him, and had FedExed them his two-factor authentication token so they could log into his account. He was paying them a fifth of his six-figure salary to do the work and spent the rest of his time on other activities.
The analysis of his workstation found hundreds of PDF invoices from the Chinese contractors and determined that Bob's typical work day consisted of:
9:00 a.m. – Arrive and surf Reddit for a couple of hours. Watch cat videos
11:30 a.m. – Take lunch
1:00 p.m. – Ebay time
2:00-ish p.m – Facebook updates, LinkedIn
4:30 p.m. – End-of-day update e-mail to management
5:00 p.m. – Go home
The scheme worked very well for Bob. In his performance assessments by the firm's human resources department, he was the firm's top coder for many quarters and was considered expert in C, C++, Perl, Java, Ruby, PHP, and Python.
Further investigation found that the enterprising Bob had actually taken jobs with other firms and had outsourced that work too, netting him hundreds of thousands of dollars in profit as well as lots of time to hang around on internet messaging boards and checking out the latest Detective Mittens video.
Bob is no longer employed by the firm. |
HV-s ID-kaardiga autentimine
viimati muutis Tanel 16.01.2013 17:11:11, muudetud 1 kord |
7 :: |
362 |
silver010
16.01.2013 17:03:04
| Kehvasti tegi, oleks veidi kavalamalt teinud poleks vahele jäänud. On ju küll viise kuidas ühenduda läbi SSH koduserverisse ja siis alles tööserverisse jne... Kasvõi TOR-i kaudu asju ajanud.
| Kommentaarid: 45 loe/lisa |
42 |
dex
16.01.2013 17:26:16
Ülemus oli idioot, et sellise mehe lahti lasi. Oleks võinud neid teadmisi (kuidas Hiinast odavat koodi saada) parem mõistlikult ära kasutada.
Mees kolistab päev otsa interneeduses ja suudab selle kõrvalt nagu muu seas allhanget sisse osta (sealjuures veel mitmele firmale). Ma usun, et eestis otsitakse selliseid vendasid tikutulega taga.
_________________ Süümi, juumi, makkami ja kui tüüle nakkami... |
| Kommentaarid: 98 loe/lisa |
87 |
priitr
16.01.2013 17:26:28
Programmeerijana polnud Bob ehk suurem asi, aga projektijuhi ja mänedžerina ootab teda ees suur tulevik.
Müts maha mehe ees, kes suutis Hiinast sisse ostetud teenust niimoodi valida ja juhtida, et see osutus palju efektiivsemaks, kui kohapealne töö. Selle kõige kõrvalt veel nii palju vaba aega leida o0...
Veelkord - müts maha.
_________________ Tšudes ne bõvajet. |
| Kommentaarid: 27 loe/lisa |
iFlop
16.01.2013 17:38:51
Re: Programmeerija lasi oma töö firma teadmata teha Hiinas |
5:00 p.m. – Go home |
Kas selline siis ei näegi välja ühe tüüpilise kontoriinimise tööpäev?
Mulle tundub see natuke kahtlane, et lasi suvalise tegelase enda nime alt firma VPN
Või oli ta nii laisk, et ei viitsinud vajaliku tööd nt emaili teel vahendada ning allhankija pidi tema nime alt kõik otse ära tegema?
| Kommentaarid: 67 loe/lisa |
66 |
Ho Ho
16.01.2013 17:42:22
| dex kirjutas: |
| Ülemus oli idioot, et sellise mehe lahti lasi. Oleks võinud neid teadmisi (kuidas Hiinast odavat koodi saada) parem mõistlikult ära kasutada. |
Kes ütles, et firma lihtsalt mõttetut vahemeest ei elimineerinud nii, et nüüd ise otse hiinlastega suhtlevad?
| iFlop kirjutas: |
| Kas selline siis ei näegi välja ühe tüüpilise kontoriinimise tööpäev? |
On vägagi erinevaid kontoritöid ning vähegi asjalikumates kohtades säärase graafikuga hakkama ei ole võimalik saada.
87 |
iFlop
16.01.2013 17:59:22
Aga äkki ei löönudki ta niisama aega surnuks?
Nt /r/programming alt või vahel olulisi teadmisis progemise kohta saada. link
sööma peab ju igaüks?
Äkki on kontoris odva hiina kauba puudus? Ning milleks kohalikele vahendajatele maksta?
Firma FB lehel on vaja äkki toodet promoda?
ülemustega suhtlemine on igal juhul soovitatav..
5:00 p.m. – Go home
66 |
dex
16.01.2013 18:05:45
| Ho Ho kirjutas: |
| dex kirjutas: |
| iFlop kirjutas: |
On vägagi erinevaid kontoritöid ning vähegi asjalikumates kohtades säärase graafikuga hakkama ei ole võimalik saada. |
HoHo, kas Sa oled kunagi proovinud mõne krdi hiinlase või indialasega koostööd teha?
87 |
kenkauksi
16.01.2013 18:11:10
| No see vend saab kindlasti elus hakkama, kujutan ette, et ta on saanud kindlasti palju tööpakkumisi juba.
| Kommentaarid: 178 loe/lisa |
158 |
Noname
16.01.2013 18:12:56
Tundub tark mees. Ise teeks ka nii. Äri on äri
_________________ "Olukord on sitt, aga see on meie tuleviku väetis." - Lennart Meri
"Edu on kehv õpetaja. See ahvatleb tarku inimesi mõtlema, et nad ei saagi kaotada" - B. Gates |
| Kommentaarid: 372 loe/lisa |
321 |
Ho Ho
16.01.2013 18:13:45
| dex kirjutas: |
| HoHo, kas Sa oled kunagi proovinud mõne krdi hiinlase või indialasega koostööd teha? |
Kriips alla 2a olen töötanud koos ühe indialasega kes ainuisikuliselt manageerib ühe üüratu suure rakenduse serveri poolset otsa. Üks kõvemaid ning vastutustundelisemaid progejaid keda tunnen.
87 |
dex
16.01.2013 18:24:47
OK, las ta siis jääb.
87 |
WAV
16.01.2013 18:40:47
| Hindud/indialased on ju ammuteada siin maailmas parimad matemaatikud ja programmeerijad. Enamus suuremaid ülemaailmseid internetiteenuseid (alates googlest jne) on suures osas hindudest progejate meeskonna toel üles ehitatud.
| Kommentaarid: 7 loe/lisa |
ebardkonn
16.01.2013 18:53:20
| Ho Ho kirjutas: |
| dex kirjutas: |
Kriips alla 2a olen töötanud koos ühe indialasega kes ainuisikuliselt manageerib ühe üüratu suure rakenduse serveri poolset otsa. Üks kõvemaid ning vastutustundelisemaid progejaid keda tunnen. |
Täpsustaks, et see problemaatiline kaader on minu hinnangul kuskil india allhanke firmades vähemalt enda kogemus näitab sellist seisu.
| Kommentaarid: 6 loe/lisa |
upper
16.01.2013 21:44:57
| varsti valge mees imeb oma varbaid ,kui veel ulatab.
| Kommentaarid: 4 loe/lisa |
ThedEviL
16.01.2013 21:49:40
| upper kirjutas: |
| varsti valge mees imeb oma varbaid ,kui veel ulatab. |
Valge mees ei näe statistiliselt varsti oma tilli ka peeglist mitte.
Kui nende keskmine kehakaal veel kaua tõuseb...
97 |
| Kommentaarid: 92 loe/lisa |
Mario.
17.01.2013 10:49:32
Tavaline ja tuntud praktiseering, kus itimehed müüvad oma lääne töötunni hinnaga projekte, "outsource'ides" need aga Aasiasse ja ise palgavahest elades.
Tagada vaba aja näol endale privileeg, miks mitte.
6 :: |
217 |
Spezz
17.01.2013 11:12:36
| Mees on geenius küll. Probleem aga ikkagi selles peamiselt: "US critical infrastructure company".
67 |
Leinö
17.01.2013 11:21:27
| Ho Ho, erandeid leidub. Olen väga palju puutunud kokku hindudega ja hiinlastega, kelle puhul tahaks pead vastu seina taguda vahel.
| Kommentaarid: 34 loe/lisa |
33 |
Vermon
17.01.2013 11:27:22
Täpsustuseks küsin, et kas te räägite rassist või rahvusest? Et kas teid tuleks nimetada rassistideks või fashistideks?
| Kommentaarid: 14 loe/lisa |
12 |
Ho Ho
17.01.2013 11:30:53
| Leinö kirjutas: |
| Ho Ho, erandeid leidub. Olen väga palju puutunud kokku hindudega ja hiinlastega, kelle puhul tahaks pead vastu seina taguda vahel. |
Täpselt samamoodi leidub igasuguseid ka siinsamas Eestis.
Isiklikud kogemused progejatega on küll jätnud mulje, et Rootsi tegijad on ühed viletsamad
87 |
Leinö
17.01.2013 11:35:15
Vermon, miks peaks kohe fashist või rassist olema?
Ho Ho, täpselt.
33 |
Vermon
17.01.2013 11:42:27
Rassismi definitsioon on, et sa teed inimestel vahet vastavalt nende rassile. Kui sa ütled, et sul on ühe rassiga halvad kogemused siis see on rassism.
Nii lihtne see ongi
Norin niisama
12 |
Ho Ho
17.01.2013 11:52:08
| Vermon kirjutas: |
| Kui sa ütled, et sul on ühe rassiga halvad kogemused siis see on rassism |
Vale.
87 |
Vermon
17.01.2013 11:55:17
| Ho Ho kirjutas: |
| Vermon kirjutas: |
Vale. |
Õigus sul, kui sa ütleks, et arvatavasti oleks sul ka teiste sama rassi esindajatega sama kogemus, siis oleks alles rassism
12 |
Leinö
17.01.2013 12:15:40
OT
Vermon, nõme norimine.
See, et mul on osade teist rassi teatud isikutega probleeme olnud, ei tähenda, et ma olen rassist.
Imelik on see, et kui tumedanahaline(tegelt võib vist sõna "neeger" ka kasutada, kuna see on teatud rassi nimetus, nagu ka asiaadid jne) ütleb neeger teisele neegrile, siis on see ok, kuid kui valge ütleb tumedanahalisele seda, siis on maailmalõpp ja kohtukutsed jne.
Krdi topeltstandardid.
Kui sa ise kutsud oma rassi neegriks, siis võivad ka teised kutsuda.
33 |
iFlop
17.01.2013 17:01:59
| Ho Ho kirjutas: |
| Leinö kirjutas: |
Täpselt samamoodi leidub igasuguseid ka siinsamas Eestis. |
Kui offshoring'ga asendatakse kohalik tugiteenus, siis võib juhtuda, et kauge support ei saa piisavat koolitust või ei oma eelnevat kogemust vastavate probleemide lahendamisel. Sellisel juhul pole ka erilist kasu kui inimene on pühendunud ning abivalmis. Lisa sinna juurde ka keelelised kommunikatsiooniprobleemid ning saadki peaga vastu seina taguda
66 |
artur-
18.01.2013 00:56:37
Tubli mees tõesti. Kunagi ~10 aastat tagasi kui koolis käisin ja söögiraha oli vaja teenida tegin põmst sama. Ainult et plakatid ja logotaolised asjad HV kaudu
| Kommentaarid: 82 loe/lisa |
72 |
