praegune kellaaeg 20.11.2026 00:17:40
revo1
02.01.2013 17:58:20
K:Cisco AP confimine[Aironet 1200] |
Selline probleem, et miskipärast ei õnnestu mul Cisco Aironet 1200 confimine.
Seade: AIR-AP1231G
Vaja teha väike AP et kodus netti jagada.Aga hetke seisuga saan wifile ainult ligi,kui panna manuaalselt ip-d.
Vaja oleks teha siis WIFI, mis jagab dhcp-ga aadressit. Nett ise tuleb sisse FastEthernet0 pordist(välisühendus)
Mis ma siis tegin:
1) confisin raadio pordi ülesse ja andsin talle IP 192.168.2.1(mask 255.255.255.0)
2) lisasin ta vlan 1
3) lisasin ssid kodu ja bridgesin ta vlan 1-te, nagu ka dhcp.
DHCP:
dhcp tegin 192.168.2.1 kuni 192.168.2.1
lisasin uue pooli ja network-i 192.168.2.1 255.255.255.0
BVI1:
IP : 10.0.0.4
Hetke vaimusünnitus on tiba allpool...
Välisühenduselt(Elion) peaks ta saama IP 10.0.0.X
Tänud juba ette;)
Praegune conf, millega IP-sid ei saa :
version 12.3
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
hostname ap
enable secret 5 $1$96Jz$q9N.WRR1SKs.G9PuTnEAZ/
username Cisco password 7 02250D480809
ip subnet-zero
ip dhcp excluded-address 192.168.1.1 192.168.1.254
ip dhcp excluded-address 192.168.2.1 192.168.2.254
ip dhcp excluded-address 192.168.3.1 255.255.255.0
ip dhcp pool minu
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
lease 5
ip dhcp pool minuwifi
network 192.168.2.0 255.255.255.0
ip dhcp pool fastethernet
network 192.168.3.0 255.255.255.0
lease 10
ip dhcp pool maindhcp
lease 10
no aaa new-model
dot11 vlan-name minu vlan 1
dot11 ssid kodu
vlan 1
authentication open
guest-mode
mobility network-id 1
dot11 ssid kodu vlan 1
dot11 ssid kodu vlan 1 native
dot11 network-map
dot11 arp-cache optional
bridge irb
interface Dot11Radio0
ip address pool maindhcp
ip dhcp relay information trusted
no ip route-cache
logging event subif-link-status
ssid kodu
ssid kodu vlan 1
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
ip address 192.168.3.1 255.255.255.0
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface BVI1
ip address 10.0.0.4 255.0.0.0
no ip route-cache
ip default-gateway 192.168.3.0
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
logging snmp-trap emergencies
logging snmp-trap alerts
logging snmp-trap critical
logging snmp-trap errors
logging snmp-trap warnings
control-plane
bridge 1 route ip
line con 0
transport preferred all
transport output all
line vty 0 4
login local
transport input all
line vty 5 15
login
transport input all
end
kussu
02.01.2013 18:03:24
| Kas see Aironet puhtatõuline AP ainult pole? Mis asi sul dhcp-d teeb?
revo1
02.01.2013 18:11:41
miskipärast ainult ap-ks tegemine ilma dhcp-ta ei hakka üldse midagi tegema.
veel täpsem mudel on siis : AIR-AP 1231G-E-K9
Ma proovisin, et kui luua ainult ssid kodu ja teha see guest-mode siis ta ei näita isegi ssid-d läpakas.
Ise proovisin luua netti sellise tutoriali järgi :
http://www.youtube.com/watch?v=5RE55VBsyDE
kussu
02.01.2013 19:08:01
| Mõned aastad tagasi sai paari isendit näpitud, kuid minu mäletamist mööda ei osanud nad ise dhcp-d teha. Seega pakuks, et pead ikka mingi rondi välisühendusee ja AP vahele pistma mis su arvutitele ka IP ilusti annab.
Andrus Luht
itimees.ee
03.01.2013 13:11:21
RTFM! Keegi ei hakka sulle tasuta töötavat konfi tegema. Eriti olukorras, kus sa ise ka päris täpselt ei tea, mida ja kuidas sa tahad. Paari tunni jagu tööd (0,5h vajaduste välja selgitamine, 0,5h nende realiseerimine konfis, 1h käehoidmist ja küsimustele vastamist) spetsialistilt ja su mured on lahendatud. Meilt selle asja tellimine maksab ~150€+km.
_________________ Äriklassi serverilahenduste müük, paigaldus ja haldus. SaaS / PaaS / IaaS lahendused
Tier-3 privaatpilvede, virtuaal- ja virtuaal-privaat-serverite lahendused. 24/7 haldus, monitooring |
centraaL
03.01.2013 16:06:20
| Andrus Luht kirjutas: |
Ma arvan, et teemaalgatajat ei koti teilt selle asja tellimise hind karvavõrdki ja isik tuli siia ainult abi paluma, mitte nõudma, et kandikul asju ette toodaks. " "
peacemaki
04.01.2013 13:33:36
| Miks sa kodus vlani tegema hakkad?
heikis
24.02.2013 01:13:31
kiirel pilgul jäi silma mitu konfiviga:
sul on ju kogu subnet lisatud dhcp excluded listi.
interface, kus tahad jagada aadresse dhcp abil, peab olema IP käsitsi määratud. vastavalt ip-ile oskab ruuter valida õige dhcp pooli.
dhcp teenus peab olema käsitsi aktiveeritud (service dhcp)
ip default gateway aadress ilmselt ka vale.
saan aru, et kogu konf on sul tehtud veebiliideses?
