praegune kellaaeg 25.10.2026 12:03:15
daniiel
20.12.2012 10:28:53
Probleem. Arvuti ei ärka enam sleep modest |
Tere,
Mul on selline mure, et kui lauaarvuti sleep mode panen siis see enam ei ärka ülesse. Ainuke võimalus on voolujuhe eemaldada ~10 sekundiks, peale mida alles saab arvuti käivitada.
Arvuti on uus, ostetud oktoobris. Kasutan windows 7. Paluks abi.
Parimat!
svenman
21.12.2012 19:05:34
The problem lies with how Microsoft have set the default state of Windows 7, no doubt influenced by the irrational and brain-dead 'green' lobby. The following solution solved the problem for me. I'll describe it at a very basic level to suit the less computer proficient - something Microsoft can never be bothered to do.
Go to Start. In the search box type "Device Manager" (without the quotes) - and then press Enter; this will open up the Device Manager. Double click on 'Universal Serial Bus controllers.' Now you will see a list of 'USB Root Hub'. Right-click the top one of these and select 'Properties'. Click on the Power Management tab, un-tick where it says 'Allow the computer to turn off this device to save power' and click 'OK'. Now repeat this action on the other 'USB Root Hub' items in the list. when they are all done you can close the Device Manager, and your USB mouse and keyboard will now be able to re-awake your computer.
It is ridiculous when, in an age where USB keyboard and mouse is replacing PS/2 devices, that Microsoft have added this feature, and even worse that they have caused USB to switch off at all. All this does is inconvenience everyone. Microsoft really need to provide an update to remove the option of allowing the USB connection to die during sleep.
Allikas: http://social.technet.microsoft.com/Forums/en-US/w7itproperf/thread/1d478f44-2a24-4cca-9cff-40d639b7a8f1/
| Kommentaarid: 80 loe/lisa |
71 |
