praegune kellaaeg 08.11.2026 00:25:55
rapsacc
14.12.2012 13:50:16
Openvpn TLS Error: TLS handshake failed |
Selline lugu: Sain koolituse ja test keskkonnale ligipääsemiseks pean looma vpn ühenduse
Esijalgu oli kõik korras, ja siis hakkasin saama TLS errorit. Siis võtsin ühendust koolitusega. Nemad logisid minu kasutaja ja parooliga sisse - neil probleeme ei olnud. Pärast seda kui nad olid sisse loginud sain ka mina ühenduse tagasi (päevaks). Ja siis jälle sama jama.
kasutan windows 7 mille peal on backtrack 5r3 virtual machine
kodus kasutan tele2 3g interneti
tööl on püsiühendus läbi soome proxy serveri
client.config fail
client
dev tap
proto udp
rport 1194
remote xxx.xxx.xxx.xxx
resolv-retry infinite
nobind
ca efw-1333989184.pem
persist-key
persist-tun
auth-user-pass
comp-lzo
ja kui terminalis siis ühendust loon
root@bt:~/lab# openvpn --config configfile.conf
Thu Dec 13 06:14:07 2012 OpenVPN 2.1.0 i486-pc-linux-gnu [SSL] [LZO2] [EPOLL] [PKCS11] [MH] [PF_INET6] [eurephia] built on Jul 20 2010
Enter Auth Username:user
Enter Auth Password:
Thu Dec 13 06:14:25 2012 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Thu Dec 13 06:14:25 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Thu Dec 13 06:14:25 2012 LZO compression initialized
Thu Dec 13 06:14:25 2012 UDPv4 link local: [undef]
Thu Dec 13 06:14:25 2012 UDPv4 link remote: [AF_INET]xxx.xxx.xxx.xxx:1194
Thu Dec 13 06:15:25 2012 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Thu Dec 13 06:15:25 2012 TLS Error: TLS handshake failed
Thu Dec 13 06:15:25 2012 SIGUSR1[soft,tls-error] received, process restarting
Thu Dec 13 06:15:27 2012 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Thu Dec 13 06:15:27 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Oskab keegi aidata?
tulemüüris ei tohiks probleem olla, sest vahepeal on ühendus olnud.
tiitise
| Kommentaarid: 6 loe/lisa |
