12.12.2012 12:32:13
Linux kernelist kaob 386-DX/SX tugi |
Linuxi looja Linus Torvalds teatas, et järgmisest Linux kernelist kaob 386-DX/SX tugi, mis tähendab, et paarikümne aastastel arvutitel uusimat Linuxi kernelit enam kasutada ei saa. Toe eemaldamine tähendab ka väiksemat koodi. Mõned antiikraua kasutaja kindlasti kurvastavad ja nostalgitsevad, aga Linus on veendunud, et asjaga tuleb edasi minna.
author Linus Torvalds <torvalds@linux-foundation.org>
Wed, 12 Dec 2012 03:59:32 +0000 (19:59 -0800)
committer Linus Torvalds <torvalds@linux-foundation.org>
commit 743aa456c1834f76982af44e8b71d1a0b2a82e21
tree f240782115da675496c8d9d5328722933d0ef601 tree | snapshot
parent a05a4e24dcd73c2de4ef3f8d520b8bbb44570c60 commit | diff
parent 11af32b69ef7ee64c7d8848cad71a6f3749d9e37 commit | diff
Merge branch 'x86-nuke386-for-linus' of git://git./linux/kernel/git/tip/tip
Pull "Nuke 386-DX/SX support" from Ingo Molnar:
"This tree removes ancient-386-CPUs support and thus zaps quite a bit
of complexity:
24 files changed, 56 insertions(+), 425 deletions(-)
... which complexity has plagued us with extra work whenever we wanted
to change SMP primitives, for years.
Unfortunately there's a nostalgic cost: your old original 386 DX33
system from early 1991 won't be able to boot modern Linux kernels
anymore. Sniff."
I'm not sentimental. Good riddance.
* 'x86-nuke386-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, 386 removal: Document Nx586 as a 386 and thus unsupported
x86, cleanups: Simplify sync_core() in the case of no CPUID
x86, 386 removal: Remove CONFIG_X86_POPAD_OK
x86, 386 removal: Remove CONFIG_X86_WP_WORKS_OK
x86, 386 removal: Remove CONFIG_INVLPG
x86, 386 removal: Remove CONFIG_BSWAP
x86, 386 removal: Remove CONFIG_XADD
x86, 386 removal: Remove CONFIG_CMPXCHG
x86, 386 removal: Remove CONFIG_M386 from Kconfig |
Allikas: http://git.kernel.org/?p=linux/kernel/git/torvalds/linux.git;a=commit;h=743aa456c1834f76982af44e8b71d1a0b2a82e21
7 :: |
362 |
Mnator
12.12.2012 12:47:44
| Tõenäoliselt ta võiks rahumeeli 486 ka välja rookida, uued distrod on nagunii sellised, et 486-masinail kah kui üldse töötavad, siis üliaeglaselt.
12.12.2012 12:50:41
Mnator, kernel pole veel distro ja ilma töölauata jooksevad kõik distrod ka vabalt 386 peal...
Pealegi kes käseb töölauaks Gnome või KDE valida, alternatiive on piisavalt, mis ka vanemal raual normaalselt töötavad.
BTW, mul on siiani isegi üks komplektne 386DX40 plate koos mäludega olemas...
196 |
Mnator
12.12.2012 13:00:55
Etz, seda vahet tean suurepäraselt aga kui sa just ilma eranditeta ainult käsurida ei plaani kasutada, siis pead ikka töölaua juurde võtma ja nende ressursitarve minu arusaamist mööda kipub vanakestele liiaks. Ja keegi ei takista ju sind vanakeste peal vanemaid versioone kasutamast, need jäävad ju alles. Nende peal tuliuute versioonidega - kas on üldse midagi teha?
(sul on plate, mul on nurgas seismas juhuks, kui vaja mõnda igivana töövahendit kasutada, komplektne 386-kast ja jääb veel mitmeks aastaks alles ja puutumatuna seisma)
12.12.2012 13:32:22
Mnator, serveris (mail, web, Samba jm nipet-näpet) ei ole töölaual tõesti mitte mingisugust mõistlikku otstarvet
Töötavad ka 386-st ja 486-st palju kõvema rauaga masinad 100% ilma töölaua vajaduseta ja monitorist puudust tundmata.
Kunagi sai serverisse ikka Debianile KDE ka juurde lastud - igaks juhuks. Aga kui sellele sisuliselt mingit otstarvest ei leidnud (tagavara-tööjaamana kasutamine välja arvatud), siis uuel paigaldusel ei hakanud aega viitmagi selle peale.
Aga kui teemasse tagasi tulla, siis 386 ma vist enam ei leia ka oma vanaraua hulgast... Üks vahepeal mõne aastakese ruutimist harrastanud 486 on küll tolmu korjamas, aga ega temagi enam rakendust leia.
viimati muutis Dogbert 12.12.2012 13:39:15, muudetud 1 kord |
ThedEviL
12.12.2012 13:33:26
Ega jah. pole vist väga jäänud ülessandeid millega üks 386 hakkama saaks.
Sai mõned aastad tagasi üritatud 386/sx20 ruutima panna.
Lihtlabase DHCP cliendi ja serveri sai käima. Tulemüüri ei suutnud konfida. CPU load oli laes.
Torrentit tolle taga harrastada ei saanud, RAM oli täis koos laes CPU load'iga
Ja isegi videokaarti polnud talle külge topitud. Kogu vidinate pagas oli 2xlan (10mbit)+serial
Aga eks ma ei viitsinud väga optimeerida kah. Tegemist oli lihtsalt nostalgilise huviga, kas kannatab ruuterit mängida või mitte.
Ja noh PCI siini puudumise pärast polnud võimalust ka wifi suutlikust katsetada...
Ohh, olid ajad, kui videokaart oli lisavarustus. Nüüd on krdi safety enamikel platedel peal. Ilma videota ei buudi.
97 |
12.12.2012 13:41:21
Jah, isegi 486-ga ruutimisel DHCP server on tiguaeglane, mingi torrenti või P2P-ga ei tohi noid vanakesi ehmatada
Mnator
12.12.2012 14:22:42
| Dogbert kirjutas: |
Jah, isegi 486-ga ruutimisel DHCP server on tiguaeglane, mingi torrenti või P2P-ga ei tohi noid vanakesi ehmatada  |
Aga siis ju ongi nii, et 486 tugi on kah juba ülearune. Kellel seda siiski huvi pärast tarvis, sellel kõlbab vanem versioon kah kasutada, nagunii vaid lõbu pärast katsetab......
mihkelv
12.12.2012 15:55:55
Re: Linux kernelist kaob 386-DX/SX tugi |
| Tanel kirjutas: |
anymore. Sniff."
386-l kirjutas ta esimese linuxi?
| Kommentaarid: 6 loe/lisa |
12.12.2012 16:15:23
http://en.wikipedia.org/wiki/History_of_Linux#The_creation_of_Linux
Kui see tõele vastab, siis jah.
In 1991, in Helsinki, Linus Torvalds began a project that later became the Linux kernel. It was initially a terminal emulator, which Torvalds used to access the large UNIX servers of the university. He wrote the program specifically for the hardware he was using and independent of an operating system because he wanted to use the functions of his new PC with an 80386 processor. Development was done on MINIX using the GNU C compiler, which is still the main choice for compiling Linux today (although the code can be built with other compilers, such as the Intel C Compiler).[citation needed]
As Torvalds wrote in his book Just for Fun,[9] he eventually realized that he had written an operating system kernel. On 25 August 1991, he announced this system in a Usenet posting to the newsgroup "comp.os.minix.":[10]
Hello everybody out there using minix -
I'm doing a (free) operating system (just a hobby, won't be big and professional like gnu) for 386(486) AT clones. This has been brewing since april, and is starting to get ready. I'd like any feedback on things people like/dislike in minix, as my OS resembles it somewhat (same physical layout of the file-system (due to practical reasons) among other things).
I've currently ported bash(1.08) and gcc(1.40), and things seem to work. This implies that I'll get something practical within a few months, and I'd like to know what features most people would want. Any suggestions are welcome, but I won't promise I'll implement them
Linus (torvalds@kruuna.helsinki.fi)
PS. Yes – it's free of any minix code, and it has a multi-threaded fs. It is NOT portable (uses 386 task switching etc), and it probably never will support anything other than AT-harddisks, as that's all I have .
—Linus Torvalds [11] |
7 :: |
362 |
suur13
12.12.2012 17:44:26
| (just a hobby, won't be big and professional like gnu) |
Any suggestions are welcome, but I won't promise I'll implement them  |
| It is NOT portable |
| it probably never will support anything other than AT-harddisks |
Good lord...
| Kommentaarid: 204 loe/lisa |
189 |
DigeBeni
12.12.2012 18:18:41
... ammu oleks aeg olnud, viimane 486 baasil ruuter sai juba päris palju aastaid tagasi utiili viidud, 386 on aga juba nii kauge ajalugu, et ma enam ei mäletagi, kus ma seda viimati reaalselt töös nägin linuxiga seoses. Tehaste tööpinkides ikka leidub sellist riistvara veel aga reeglina on nende süsteemiplatvorm teine ...
163 |
priitjo
13.12.2012 00:52:44
õnnelik 386 kasutaja |
Kuna eraldi välja on toodud SX ja DX, siis on rõõm tõdeda, et 386NX ja 386SL tugi säilib
