SirShark
26.11.2012 13:51:55
Unrealircd probleemid |
* Loading IRCd configuration ..
* unrealircd.conf:1: Ignoring extra data
* unrealircd.conf:6: Ignoring extra data
* unrealircd.conf:1: unknown directive mple
[error] ERROR: efunction 'do_join' not found, you probably did not load commands.so properly (or not all required m_* modules)
[error] ERROR: efunction 'join_channel' not found, you probably did not load commands.so properly (or not all required m_* modules)
[error] ERROR: efunction 'can_join' not found, you probably did not load commands.so properly (or not all required m_* modules)
[error] ERROR: efunction 'do_mode' not found, you probably did not load commands.so properly (or not all required m_* modules)
[error] ERROR: efunction 'set_mode' not found, you probably did not load commands.so properly (or not all required m_* modules)
[error] ERROR: efunction 'm_umode' not found, you probably did not load commands.so properly (or not all required m_* modules)
[error] ERROR: efunction 'register_user' not found, you probably did not load commands.so properly (or not all required m_* modules)
[error] ERROR: efunction 'tkl_hash' not found, you probably did not load commands.so properly (or not all required m_* modules)
[error] ERROR: efunction 'tkl_typetochar' not found, you probably did not load commands.so properly (or not all required m_* modules)
[error] ERROR: efunction 'tkl_add_line' not found, you probably did not load commands.so properly (or not all required m_* modules)
[error] ERROR: efunction 'tkl_del_line' not found, you probably did not load commands.so properly (or not all required m_* modules)
[error] [--efunction errors truncated to prevent flooding--]
[error] IRCd configuration failed to pass testing
Possible error encountered (IRCd seemingly not started)
Check above for possible errors, and this output of
ircd.log. If you cannot solve the problem, read
Unreal.nfo on where to get support
tail: cannot open `/root/Unreal3.2/ircd.log' for reading: No such file or directory
Minu peakuju ei võimalda aru saada, mis valemiga seda remontida saab?
| Kommentaarid: 35 loe/lisa |
29 |
Fukiku
26.11.2012 14:11:56
Kompileerimisel mõnd vajalikku sammu vahele ei jätnud? Puusalt tulistades pakuks küll, et kompileerimine ja/või installimine on peeti läinud. Pole küll teab mis ircd haldamise kunn, aga mäletan, et Unreal läks kunagi täitsa valutult kokku ja käima. Samas kurdab ta sul muidugi ka seadistusfaili üle - kasutad enda vajadustele kohendatud näidist või üritasid nullist kokku panna ja läks miskit nihu?
PS Juurkasutajana ma ircd'd küll ei jooksutaks eales.
_________________ Foxic is just a simple fox
Enne kui sa küsid oma küsimuse - küsi seda vannipardilt! Rangelt soovitatav enne programmeerimise alafoorumisse uue teema tegemist. |
limp
26.11.2012 14:16:19
unrealircd.conf-is ikka on määratud
loadmodule "src/modules/commands.so";
võid proovida ka fullpathi. samuti ära kävita seda roodu õigustes ning teistel kasutajatel roodu katalooogi õiguseid, pole seega võid ta välja ka sealt tõsta
_________________ Ärgake lapsed, maailm on hädaohus
Windows keskkond on nagu li*s - kõik teda ke*ivad aga keegi teda ei armasta! |
| Kommentaarid: 56 loe/lisa |
52 |
SirShark
27.11.2012 01:42:14
| Ma hetkeks mõtlesin et mul jookseb seal servus samas znc, vb see segab
29 |
Fukiku
27.11.2012 11:03:41
Kas sa eelpool viidatud teooriad kontrollisid ja välistasid, et sa znc'd hakkad asjasse segama?
Veateate järgi küll miski ei viita sellele, et mingi teine programm segab, pigem ikka vigane konf ja/või install on su mureks.
SirShark
01.12.2012 13:52:35
| pigem see et nad mõlemad on binditud samasse porti kuulama
29 |
Fukiku
01.12.2012 14:17:01
No see on kindlasti ka probleem, sedasi sa asja jätta ei saa. Aga hetkel su ircd käivitumine ei jõua nii kaugele isegi. Selle kohta tuleks konkreetselt ka vastavasisuline veateade, et port on juba hõivatud. Seega soovitaks vaadata seni antud soovituste valguses asjad üle.
