• Koduleht: http://www.overkillsoftware.com/payday/
• Arendaja: Overkill Software
• Väljaandja: Sony
• Stiil: Action, First person shooter
• Väljalaske kuupäev: TBA 2011
• Six High-Intensity Heists: Whether you're blowing the roof off a building to extract a safe via helicopter or emptying the vault at the First World Bank, these action-packed heists will have players on edge and always checking their six.
• Interactive Co-op Gameplay: Whether AI or live, your crew of four must operate as one to bring get the "big score." Sharing extra ammo and med kits, helping regen wounded partners, guarding key positions, taking civilian hostages or cracking through various security measures - it's all for one and one for all.
• Endless Replayability: Dynamic environments, adaptive enemy behavior,shifting entry points, FBI agents repelling down on ropes through the skylights, SWAT teams crashing through the windows and special units crawling through the ventilation shafts makes each play-through of every heist a unique fight.
• Massive Character Progression Tree: Players choose a specialty - assault, sharpshooter or support - to gain weapons and equipment that fit their preferred form of violence. Unlock trip mines, silenced pistols, machine guns and much, much more.
• Shout Out Button: Players need to be vocal and shout commands and directions to the co-op crew, as well as hostages and the police if they want to survive to spend their cut of the take.
• Hostage Trading: Hostages can be a lifeline. If anyone in the crew is taken into custody, trade hostages to get crew members back and increase the odds of completing your objectives.
• PlayStation® or PC: For keyboard and mouse marksman, as well as handheld controller snipers, PAYDAY is the uber-FPS for a high intensity shooter fix.
• More DLC: Additional heists, weapons and equipment means PAYDAY - a digitally distributed AAA quality title for less than half the price of a retail game - is total OVERKILL.
Ei mulle täitsa meeldib, graafika ilus, sound on hea ka gameplay on super
Ainuke jama, et ei saa lihtsalt mängida kuna videokaardi ventikas läheb lolliks(tahab õhku tõusta)
Mõndades üksikutes mängudes on ka nii (world of tanks)jt....kuigi arvuti on kõvasti tugevam kui mäng nõuab.
Keegi mingit rohtu ei tea sellele?
edit: selle leidsin:
"The devs are very active on the Steam forum, they're taking feedback and said that more options and push-to-talk will be on the priority list for the first patch. "
SP - Normaliga teisest levelist pole edasi saanud, alati mõrvatakse julmalt ära kuskil poolepeal. Enda meeskonna AI liikmed on suht tainad.
MP - mõned korrad proovisin. Ei ühenda ära või kui ühendab, siis on mäng korralikult sünkroonist väljas - politsei vahib niisama, oma tiimikaaslast pidin ~10x elustama, enne kui ta püsti sain jne.
Kindlasti proovin seda mängu veel. Kontsepstioon on iseenesest täitsa hea. Sutsu küll tõesti L4D pangarööviga aga mulle sellised co-op mängud meeldivadki.
Hmm, sellist jama mul pole olnud. Küll aga ei saa mõni kord Lobbyga liitudes mängu sisse - laeb ära ja siis viskab tagasi peamenüüsse ning teatab, et ühendus katkestati. Samas hostisin ise mängu ja lammutasime Sinise Siiliga koos 2-3 tiiru ja muresid nagu ei olnud. Mängul võiks olla Easy ja Normali vahel veel mingi raskusaste või siis neid natuke muditud, sest Easy on tõesti mõttetult kerge, Normal aga on juba tõsine pähkel.
Minu arust on see just huvitav, et mäng tiba raske on. (Mingis mapis oli kõikide mängijate mängude peale õnnestumis protsent 43% normaliga, hardiga 13 ja overkill raskusastmega 4%). Ei muutu üksluiseks.
viimati muutis chatro 10.08.2012 17:11:24, muudetud 2 korda
