praegune kellaaeg 08.11.2026 21:31:20
kaupz
05.11.2012 15:52:13
Automaatse proxy.pac skripti kirjutamine Win7 IE jaoks |
Kuna tööl on võrk proxy taga, siis väljaspool kontorit suvalise wifi külge haakides, tuleb proxy Puhverserver linnuke käsitsi maha võtta.
Leidsin MS lehelt 10tk näidiseid:
Aga ei suuda nendest õiget valida ega mitmest ühte kokku keerata.
Töövõrgu staatiline ip on teada.
Proxy ja port on teada.
Jah, tean et Mozilla Firefox jaoks on plugin "auto-proxy-switch".
Siis veel eraldi teema, kuidas faili asukohta määrata:
http://www.edugeek.net/forums/windows/101614-automatic-configuration-script-proxy-pac-file.html
I have tested this on numerous laptops which seems to work great,
apart from a few Windows 7 machines, specifically HP Probooks 6560b.
I have the Pac file running from the local drive, currently set to file://C:\Support\Proxy.pac - as I said this works brilliantly for the majority,
and does work for all staff in school.
As soon as the users with Probooks take their laptops home it doesn's seem to work;
I did a bit of research on this and found if you enter in a full stop after the file:// protocol (file://.C:\Support\Proxy.Pac) then it will work from home. |
_________________ O: VW T2 Hipibussi Transporter T2a VolksWagen T1 või Vana Põrnika |
| Kommentaarid: 86 loe/lisa |
