praegune kellaaeg 08.11.2026 21:31:28
matu21
05.11.2012 10:30:27
Outlook paneb segast |
milles on kala, et osad mailid, millel on kaasa pandud mingi fail, on Outlookis sellised nagu all näha.
Ja faili, mis peaks kaasas olema, ei ole....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-
_________________ Kõik, mis mul müügiks on, küsi julgelt soodushinda : www.digimarket.ee
Kõiki kaupasid saan müüa ka järelmaksuga
Kasutatud arvutid ja laptopid Tartus, Vanemuise 43 |
| Kommentaarid: 1400 loe/lisa |
1059 |
A.S.
05.11.2012 10:35:21
| Tegelikult see jura ongi see fail, mis on kaasa pandud. Ju siis on kodeeringuga mingid mured, üks meiliklient lihtsalt ei saa teisest aru.
| Kommentaarid: 34 loe/lisa |
34 |
matu21
05.11.2012 10:37:20
no aga kui ütlen saatjale, et saada fail uuesti, siis tuleb kohe OK ?
Üldjuhul tegu siis kirjadega, mis saadetud suuremale sihtgrupile.
1059 |
A.S.
05.11.2012 10:59:17
Probleem saatajapoolne? Või sellest "suurest sihtgrupist" on vaid sinul probleem?
Vaatasin seda jura, tundub olevat BASE64 kodeeringus, mingi Office dokument tundus välja kooruvat.
Kas on äkki kirja päisesse kodeering märkimata jäänud? Või ei saa sinu Outlook sellest aru?
Proovi vigast ja õiget kirja võrrelda, nn. RAW kujul, on mingi erinevus?
34 |
