eestirula3
05.11.2012 00:39:24
Excel, Dublicates funktsioon |
Kuidas teha/Kust saada "Remove Dublicates" sarnast funktsiooni, kus kustutamise asemele teeks silmapaistvamaks(värviliseks) sarnased andmed.
| Kommentaarid: 14 loe/lisa |
14 |
alfreedo
07.11.2012 19:31:21
Proovi seda.
Option Explicit
Sub Värvi_duplikaadid()
Dim OCell As Range, ProductInfo As Range
Dim FirstAddress As String
Dim i As Integer, u As Integer, ProdCount As Integer
Application.ScreenUpdating = False
u = 3
Range("a1").Activate
With ActiveSheet
Do Until ActiveCell = ""
Set ProductInfo = ActiveCell
FirstAddress = ActiveCell.Address
If ActiveCell.Interior.ColorIndex <> -4142 Then GoTo 10
With .Columns("A:A")
ProdCount = WorksheetFunction.CountIf(.Columns("A:A"), ProductInfo)
If ProdCount > 1 Then
Set OCell = .Find(ProductInfo.Value, LookAt:=xlWhole)
OCell.Activate
ActiveCell.Interior.ColorIndex = u
For i = 1 To ProdCount - 1
Set OCell = .FindNext(OCell)
OCell.Activate
Next i
u = u + 1
Else
Range(FirstAddress).Offset(1, 0).Activate
End If
End With
10
Set OCell = Nothing
ProdCount = 0
Loop
End With
Range("a1").Select
Application.CutCopyMode = False
Application.ScreenUpdating = True
Set ProductInfo = Nothing
Set OCell = Nothing
End Sub
PS.
Excel pikki ja keerulisi URL-e ei armasta.
Ja värvifont vöib tulla selline, et allolevat linki enam välja ei loe.
Näidis.
http://www.upload.ee/files/2810056/Duplic_varv.xls.html
eestirula3
07.11.2012 20:34:12
| alfreedo kirjutas: |
Proovi seda.
Option Explicit
u = 3
With ActiveSheet
OCell.Activate
OCell.Activate
Next i
u = u + 1
Else
End If
End With
10
Set OCell = Nothing
ProdCount = 0
Loop
End With
Range("a1").Select
Set OCell = Nothing
End Sub
PS.
Näidis.
http://www.upload.ee/files/2810056/Duplic_varv.xls.html |
Silme ees läheb tõesti jube kirjuks, kui rohkem sarnaseid tulemusi on.
Kas sellist süsteemi on võimalik teha:
14 |
alfreedo
07.11.2012 20:56:35
| Aga värvigammat siis pole vaja?
eestirula3
07.11.2012 21:28:25
| Aga värvigammat siis pole vaja? |
Ei ole vaja.
14 |
alfreedo
eestirula3
07.11.2012 22:11:54
Vopsti perfekto:)
14 |
