ikka low fps varsti küsin raha tagasi. Kaua võib. Regasin mängu siis kui esimene kõlakas ilmus. Sain golden tiketi sellest ajast on niipalju oodatud ,et varsti enam ei viitsi oodata. See mis toimub juba suurt ei huvita.
Link _________________ Punktkeevitus patareidele/akudele. Akutrelli/laptopi/e-bike. PM
First, I would like to thank all of you who have given helpful advice or offered words of encouragement. Though I lost today, I don't want to come off as salty... I asked the court to answer some questions, and I got some answers.
As my case was in small claims, there were no lawyers, CIG/RSI sent someone to represent their interests, but I dont wish to name them, as some people aren't so civil on the internet.
In mediation, CIG/RSI would not agree to refund the portion of my account not covered by the arbitration agreement.
Though lawyers aren't permitted, CIG/RSI lawyers drafted and submitted statements that were permitted.
The judge declined to hear anything about the conscionability or lack of consideration in the TOS.
Despite the top sentence on the TOS, CIG/RSI successfully argued that the arbitration clause should be applied to transactions even before the clause existed.
CIG/RSI repeatedly argued that there is a playable game and that funds have been earned, but the judge did not rule that either.
Following application of arbitration clause to transactions outside covered dates, court orders matter to arbitration, case is dismissed without prejudice.
Now I am just at LAX waiting to go home tonight.
Also, Santa Monica pier was only fun for like 30 minutes, not nearly as much to do as it seemed from online.
Õnnestus ka 3.2 käima saada. Selgus ka crashimise põhjus, et pagefile suurus (oli käsitsi kunagi 8GB pandud endal) jäi liiga väikeseks Aga viimase uuendusega on nad midagi muutnud küll, sest esimest korda ma nägin vahelduva eduga ka 50FPS-i (seda siis 3440x1440 resol ja 1080Ti-ga). Väga ebaühtlane ning just õhtusel ajal, paistab, et siis on serverid üsna koomas. _________________ Live long and prosper!
Vaadates videosid siis tundub et mäng tekitab mingi ca 30GB pagefaili endale. Ausalt öeldes väga alla 32GB RAM'i seda puudutada ei soovitakski siis. _________________ WoT StatsTwitch Stream
Tere,
Ehitasin endale ka arvuti, mis suudab SC vedada. Eelmine näitas ainult slaidiprogrammi. Esimest korda sain uue tööle 3.2 versiooniga, suht sujuv oli. Lendasin veidi ja aitasins mingit vaenlast puruks lasta. Maandusin ja sain kerge krim staatuse.
Teine päev oli väike uuendus 3.2.1 lad oli rohkem tunda. Püüdsin ülesandeid teha. Kuidagi õnnestus see puruks lennanud baasi uurimine ära teha. Laev on kaks korda puruks lastud, sõidetud.
Tekkinud on mõned küsimused. See hüperajami kasutamine on kuidagi kuidas parasjagu õnne on, vahest lukustub ja kerib hoo üles, aga startida ei õnnestu. Vahest teeb kohe hüppe ära. Kas ongi nii või suht juhuslik?
Tegin veits kaevamis proovi selle väikse kaevuriga tasuta päevade raames. Päris pull on. Kui ülekuumeneb laser, siis saad piraka, kolmanda pirakaga läks laev pooleks )
Tasuta proov muidu veel homseni vist. https://robertsspaceindustries.com/promotions/Gamescom-Free-Fly
Proovisin ka eila. Sain lennates kosmoses ~30fps-i. tundus nagu fps cap on peal, üldse ei tahtnud üle minna. Samuti olid koguaeg mini stutterid sees. Eriti kaevandades ajas närvi mustaks. Täitsa alpha veel ilmselt.
3.3 peaks kohe varsti Evocati testimisse minema. Peaks Hurstonit nägema ja palju vigu.. Kas meil siin Evocati liikmeid ka veel on? _________________ Hangin võimsamaid garantiiga Delli ja HP refurb- ja kasutatud tööjaamasid, vajadusel komplekteerin erilahendusi juurde.
Kas see tuleb lõpuks välja? Või läheb veel paar aastat aega?
Viimatise freefly ajal oli perf veel hullem kui eelmine kord kui proovisin. Ikka täiesti mängitamatu 970 peal. _________________ There is no place like 127.0.0.1
Pole midagi öelda - hea trailer. Millegipärast tuli selline mäng meelde nagu Freespace 2.
Siiski minujaoks kõige suurem küsimärk on mängitavus. Ma ei kahtle üldse et see saab olema väga eepiline, kuid loodan et seal ikka "mängu" ka on.
3.3 väljas, väidetavalt on praegu päris hea fps. Keskmise rigiga saavad inimesed 30 kätte stabiilselt, kohati 40+. Oleneb ilmselt serveri koormatusest ka jne. "Pre-Alpha" kohta päris ok tulemus.
Pole peale tirinud juba seda aastaid, ootan jõulud ära, võibolla siis üle mitme aasta lükkan peale, sest origin 300 seeria saab ka lõpuks ümber tehtud. Siiski - bugisid pidi palju olema, igapäevaselt selle peale aega ei kulutaks.
P.S. Arvan, et episode one Squadron 42 st võiks välja tulla 2019 jõulud - 2020 kevad. optimist ?
Kuskilt lugesin, et 3.3 tuli siis Object Container Streaming (OCS) aga seda vaid kliendi poolel. Selle effect pidi olema siis see, et miks 10-15fps-ist osaliselt tõusis 30fps peale. Serveri pool töötab ikka veel vana koodi peal ja edastab kõike suvalist infot kliendile ja sellepärast on ka serveri pool jätkuvalt ülekoormatud. Kui tuleb OCS ka serveri poolele, peaks väidetavalt elu "ilusaks" minema ja +60fps reaalususeks saama. Kui tõsi see on ei oska öelda. _________________ Live long and prosper!
Alates täna kella neljast on siis free flight kõigile, kellel ka kontot pole. Saab erinevaid laevu proovida ja kosmoses ringi kolada. See kestab nädal aega.
Install ca 40GB.
Veel infoks:
paljud missioonid on bugised
üks atmosfääriga planeet visati mängu, sinna quantum travel kestab ca 10-13 minutit olenevalt laevast.
planeet on rämedalt suur, on ka linn, kus toimub laevade in-game näitus (uued mudelid, mis veel flight ready pole, aga saab neid vahtida)
pigem on alpha CPU bottleneck kui muu, SSD ja min 12GB RAMi on rangelt soovitatav (8GB ajab asja ära, aga HDD very much not)
konsoolikäsk "r_displayinfo 3" kuvab FPSi
