uus teema   vasta Tarkvara »  WWW »  PHP text parse märgi kõik teemad loetuks
Stemugram
sõnum 26.08.2012 13:26:11 PHP text parse vasta tsitaadiga
Mul on hetkel andmed nii:
Kuupäev,      Kell, Sensor, Temp
2012/08/17 19:06:44 Sensor0 26.25
2012/08/17 19:06:44 Sensor1 27.25
2012/08/17 19:06:44 Sensor2 28.25
2012/08/17 19:06:49 Sensor0 26.25
2012/08/17 19:06:49 Sensor1 26.31
2012/08/17 19:06:49 Sensor2 25.31
Aga oleks vaja PHP-ga saada andmed järgmisele kujule:
Kuupäev,    Kell, Sensor0,Sensor1,Sensor2
2012/08/17 19:06:44 26.25, 27.25, 28.25
2012/08/17 19:06:49 26.25, 26.31, 25.31
Kuidas seda teha?
19Mart94
sõnum 26.08.2012 14:14:36 vasta tsitaadiga
php:
  1. <?php
  2.
  3. $file   = "algfail.txt";
  4. $handle = fopen($file, 'r');
  5. $data   = fread($handle, 128000);
  6.
  7. $lines  = explode("\n", $data);
  8.
  9. $main_array     = array();
  10.
  11. foreach($lines as $line) {
  12.         if(isset($first)) {
  13.                 list($date, $time, $sensor, $temp) = explode(" ", $line);
  14.                 if(!array_key_exists($date." ".$time, $main_array))
  15.                         $main_array[$date." ".$time] = array($sensor => $temp);
  16.                 else
  17.                         $main_array[$date." ".$time][$sensor] = $temp;
  18.         }
  19.
  20.         $first = true;
  21. }
  22.
  23. foreach($main_array as $key => $value) {
  24.         list($date, $time) = explode(" ", $key);
  25.
  26.         echo $date." ".$time;
  27.         foreach($value as $val_val) {
  28.                 echo " ".$val_val;
  29.         }
  30.         echo "<br />";
  31. }
  32.
  33.
  34. ?>
