praegune kellaaeg 14.11.2026 06:36:20
sakunne
04.07.2012 03:22:46
Misasi on 'URA Version array' |
The server responds with a UTF-8 JSON message. Depending on the request, the
response can be composed of 5 different array types; Stop, Prediction, Flexible
Message, Baseversion or URA Version arrays. The sequence of these arrays in the
response is undefined, except that the URA Version array always appears first.
An ‘empty’ response will contain only a URA Version array. |
Seega siis pealkirjas esitatu küsimus: Misasi on 'URA Version array'
| Kommentaarid: 77 loe/lisa |
69 |
neros
04.07.2012 05:44:39
Vastavalt sellele dokumendile: http://www.tfl.gov.uk/assets/downloads/businessandpartners/tfl-live-bus-arrivals-api-documentation.pdf
URA Version Array tagastab kasutatava URA versiooninumbri. Kahjuks ei leidnud kusagilt, MIS täpselt URA on.
E: Kuigi paljud muud allikad väidavad et see on kas Uniformly Redundant Arrray või Uniform Rectangular Array...
Ja siis on veel see lõik: An increase in the minor version indicates new functions on the server side, but
queries against older versions must return the same responses, i.e. a Client using
URA V1.1 must get the same answer from a URA V1.2 or URA V1.3 server. An
increase in the major version indicates a non-compatible change in the protocol.
Võimalik, et lihtsalt midagi mis tagastab versiooninumbri ühilduvuse jaoks?
_________________ GitHub
.NET Core & Azure baasil lahendused ja arhitektuur - kontakt. |
| Kommentaarid: 48 loe/lisa |
40 |
sakunne
20.07.2012 18:18:34
Mul sama dokument ees, sellepärast küsingi
EDIT:
Igatahes vastuseks saab midagi sellist
[0,"Bressenden/Victoria",51.497219,-0.141818]
[0,"Victoria Station, Bus Station Stand",51.496169,-0.143633]
[0,"Victoria Bus Station, Stand D",51.496103,-0.14401] |
See oleks vaja teha Google Maps API jaoks söödavaks
["Bressenden/Victoria","91545",51.497219,-0.141818],
["Victoria Station, Bus Station Stand",null,51.496169,-0.143633],
["Victoria Bus Station, Stand D",51.496103,-0.14401], |
Ehk siis '0' eest ära ja komad iga rea lõppu
Jama selles, et Javascript näeb neid ridu eraldi stringidena,kumb oleks ilusam, kas teha üheks stringiks ja kasutada replacet, v iga rea puhul eraldi
69 |
