7 :: |
364 |
neros
08.06.2012 08:09:46
Oot... kas kellelgi on äkki link artiklile selle vana ründe kohta? Puhtalt huvi pärast isegi loeks. Hetkel igatahes ei näe mille pärast kisa tõstetakse. Pangarööv toimuks spetsialistide poolt 15-30ne reaalse minutiga, ehk paneme juba profülaktika mõttes pangad ka kinni?
_________________ GitHub
.NET Core & Azure baasil lahendused ja arhitektuur - kontakt. |
| Kommentaarid: 48 loe/lisa |
40 |
mihkelv
| Kommentaarid: 6 loe/lisa |
soomer
08.06.2012 10:05:47
Vastused Eesti spetsialistidelt:
(Peeter Laud ja Helger Lippmaa)
Hi,
the paper presents a speed-up to Bleichenbacher's attack from CRYPTO 1998.
The attack shows that given access to an oracle O that:
*. Receives as input an RSA ciphertext
*. Answers whether the corresponding plaintext is formatted according to
PKCS #1 v1.5 padding rules;
one can build an oracle O' that decrypts / signs with the same RSA secret
key that O is using (note that O' will not output the secret key itself).
However, one invocation of O' requires a rather large (but in certain
contexts, realistic) number of invocations of O. In the current paper, the
required number of invocations is lowered, but it is still somewhat more
than "a couple of".
The attack can be used in situations where the circumstances hand you
(the attacker) the oracle O, but not the much stronger oracle O'. In these
situations, there are demonstrations that the attack works in practice and
constructs the oracle O'.
For the Estonian ID-card, we cannot imagine such situations where the
attacker has access to O, but not to O'. Hence I think that CERT.EE's
reaction has been fully adequate. To get access to oracle O, to make the
ID-card tell you whether a message has been correctly padded, you have to
tell it to decrypt that message. If some malware in the computer to which
the ID-card is attached to wants to make the decryption query, it must
submit PIN1 to the card, too. If the malware running in that computer
knows PIN1, then it already has access to O'.
Can an outside attacker obtain access to the oracle O, where the secret
key is in you ID-card? If you are using the ID-card to authenticate
yourself to the internet banking server and the likes, then it can't
because in this case, your ID-card does not decrypt anything. Rather, it
signs a message, but this is not what oracle O is about. The attacker may
get access to oracle O if you receive an encrypted document that you have
to decrypt with your ID-card. As far as I know, ID-cards are not
significantly used like this. Also, this would give the attacker a much
lower query rate to O than a malware would have.
Still, I think that the ideas to have the following functionality in
ID-card has been a bad idea:
*. both signing and decrypting with the authentication key;
*. support of PKCS #1 v1.5.
However, for now, nothing has changed. As before, when you're not using
your ID-card, do not keep it connected to your computer.
Cheers,
Peeter
On Wed, 6 Jun 2012, Helger Lipmaa wrote:
> Such a paper:
> Title: Efficient Padding Oracle Attacks on Cryptographic Hardware
> Authors: Romain Bardou, Riccardo Focard, Yusuke Kawamoto, Lorenzo
> Simionato, Graham Steel, Joe-Kai Tsay
> URL: http://hal.inria.fr/docs/00/69/19/58/PDF/RR-7944.pdf
> was accepted to CRYPTO 2012. In particular, it also attacks the
> Estonian ID card. Details are given in Section 3.3: it takes about 27
> hours to decrypt an arbitrary valid ciphertext, and 103 hours to forge
> a signature. This in the case your card has been given out in 2011 or
> later (uses a 2048-bit key), if it has been given out earlier and uses
> a 1024-bit key, decrypting and forging will take less time.
> What is interesting is Appendix 3 of the pdf file given above, that
> states the manifacturers' responses. While everybody else promised to
> correct mistakes in their products, the Estonian Certification
> Authority (Sertifitseerimiskeskus) will not. I will copy that
> paragraph here:
> We have recently led a vulnerability report of our attack on the Estonian
> eID card to the Estonian Certication Center. They showed concern
> about the vulnerability of the card we reported and informed CERT
> Estonia about the flaw. However, according to the Estonian Certication
> Center the authentication certicate is mainly used for authentication with
> SSL (in 95% of the cases), and our attack would be too slow to forge an
> SSL client response before a server timeout. At the time of our
> communication they had not decided on any countermeasures.
> Estonia, is like always, singled out in such issues. Until the flaw is
> fixed, I do recommend to either revoke signing certificates (like I
> did as soon as I got my card!), or at least check that you know where
> your ID card is at least once per 27 hours. If it's lost, somebody may
> be breaking it at the very moment.
> Helger
Mina loen sellest välja, et ära mingil juhul jätta ID kaarti lugejasse pärast kui oled PIN1 sisestanud, ning ära jäta seda ka lugejasse muudel juhtudel. Isegi kui oled jätnud võtab see 27 tundi, ning rohkem, kui su arvuti on aeglane.
Aga seda on alati soovitatud.
iFlop
08.06.2012 10:24:01
| Kas ma saan õigesti aru, et rünnak on võimalik ainult siis, kui ründaja teab PIN1/PIN2 koodi?
| Kommentaarid: 67 loe/lisa |
66 |
DVDRW
08.06.2012 10:29:32
Endal selline tähelepanek, et vahest pole sisenemisel ja maksmisel PINi vajagi panna
Siis kui ühekorra pandud. Seega arvutit ei tohi kunagi jätta üksi ID kaart sees.
Varsti tulevad müügile sellised lugejad kus sisestad PINi lugeja küljes olevalt numbriklaviatuurilt ja ongi keyloggeril vesi peal
| Kommentaarid: 28 loe/lisa |
08.06.2012 10:33:37
| See tähendabki, et sessioon pole lõpetatud, enne kui brauseri kinni paned või kaardi välja võtad. Seepärast netipangast või ostukeskkonnast väljalogimisel hoiatatakse-soovitatakse, et nüüd pange brauser kinni või paneme ise brauseri kinni.
571 |
WäntWõll
make.believe
08.06.2012 10:53:46
| Betamax kirjutas: |
| See tähendabki, et sessioon pole lõpetatud, enne kui brauseri kinni paned või kaardi välja võtad. Seepärast netipangast või ostukeskkonnast väljalogimisel hoiatatakse-soovitatakse, et nüüd pange brauser kinni või paneme ise brauseri kinni. |
Täpselt nii ja see on esimene turvalisus mida saab kasutaja ise mõjutada, kuid selle vastu eksivad või vilistavad 10-st 8 kasutajat
300 |
08.06.2012 10:55:25
| WäntWõll kirjutas: |
| Betamax kirjutas: |
Täpselt nii ja see on esimene turvalisus mida saab kasutaja ise mõjutada, kuid selle vastu eksivad või vilistavad 10-st 8 kasutajat  |
Eriti head näited on teatud kontingent riigiametnikest kes peavad erinevates registrites kolama ja tööl olles ennast id kaardiga autentima... pmst kaart pannakse hommikul lugejasse ning õhtul või lõunapausi ajal võetakse esimest korda välja
| Kommentaarid: 95 loe/lisa |
iFlop
08.06.2012 11:03:10
Kas on tõesti nii, et kui sisenen id-kaaridga x-lehele, siis on võimalik ID kaardi abil ka y-lehele siseneda ilma et PINi küsitakse?
66 |
DVDRW
08.06.2012 11:03:54
Tean inimest kes oma ID kaardi läpakasse pani ja väljaulatuva osa ära murdis, et siis ei peaks seda igakord uuesti panema
08.06.2012 11:04:03
| iFlop kirjutas: |
Kas on tõesti nii, et kui sisenen id-kaaridga x-lehele, siis on võimalik ID kaardi abil ka y-lehele siseneda ilma et PINi küsitakse?  |
Ei, aga samas keskkonnas korduvalt autentides ei ole vaja PIN'i sisestada.
iFlop
08.06.2012 11:13:47
| carlking, aga mingi timeout on ju ikka olemas? Sama sessiooni näiteks nädalateks vast püsti ei jäeta?
66 |
08.06.2012 11:17:54
No netipangas on selleks vist 10-15 minutit. Tõenäoliselt mingite turvastandardite järgi.
strohher
08.06.2012 11:25:56
| DVDRW kirjutas: |
Tean inimest kes oma ID kaardi läpakasse pani ja väljaulatuva osa ära murdis, et siis ei peaks seda igakord uuesti panema  |
See inimene kunagi välismaal ei käi? ID kaarti mujal ju ka vaja.
_________________ Tunguusia tundraahv |
30 |
08.06.2012 11:27:58
| strohher kirjutas: |
| DVDRW kirjutas: |
See inimene kunagi välismaal ei käi? ID kaarti mujal ju ka vaja. |
Selle jaoks on õigel inimesel Eesti Vabariigi pass
strohher
08.06.2012 11:35:39
carlking, mugavam on passi kaasas tassida kui ID kaarti rahakoti vahel?
30 |
WäntWõll
make.believe
08.06.2012 11:38:16
| iFlop kirjutas: |
| carlking, aga mingi timeout on ju ikka olemas? Sama sessiooni näiteks nädalateks vast püsti ei jäeta? |
See kõik on kinni brauserist ja ka OS-ist endast (erinevad käituvad erinevalt) ja portaali konfiguratsioonist.
Need kes on investeerinud või omavad üldse vahendeid on lisanud timeout-i enda veebikeskkonda, et tagada kasutaja turvalisus.
Millistel on ja millistel mitte, seda saab iga kasutaja ise kontrollida.
300 |
08.06.2012 11:49:34
| iFlop kirjutas: |
| Kas on tõesti nii, et kui sisenen id-kaaridga x-lehele, siis on võimalik ID kaardi abil ka y-lehele siseneda ilma et PINi küsitakse? :o |
Jah. Esimese lehe puhul küsitakse PINi, teise puhul ainult, kellena sisened.
147 |
PitBull
08.06.2012 11:49:39
Leht märgib, et üht olulisemat aspekti - ründe puhul tuleb teada kaardi PIN-koodi - pole uurimistöös mainitud.
Politsei- ja piirivalveameti isikutuvastamise ja dokumendibüroo juhi Helen Renneli sõnul on tegemist "teoreetilist laadi leiuga", kuna testid eeldasid lisaks ID-kaardile ja selle PIN-koodi teadmist. "Sisuliselt käsitleti olukorda, kus ukseluku muukimiseks on tarvis selle võtit," sõnas ta. |
| Kommentaarid: 16 loe/lisa |
16 |
08.06.2012 12:04:28
| Viimase aja üsna levinud moevärk on igatahes see, et ID-kaart vedeleb päevade-kuude viisi ID-lugejas ning isiku-dokumendina on kaasas autojuhiluba.
211 |
LKits
08.06.2012 12:52:02
| Betamax kirjutas: |
Aga seda saaks ju browseriarendajatele ette sööta, et mingi käsu peale (mida pang kasutajale edastab) kustutatakse ID-kaardi sessioon ilma akent/lehitsejat sulgemata. Peaks ju olema võimalik.
Aga jah - kui kurjategija teab juba PIN1 ja PIN2, siis kaardi "emuleerimine" ei tohiks olla ülimalt raske.
EDIT:
| tahanteada kirjutas: |
| Viimase aja üsna levinud moevärk on igatahes see, et ID-kaart vedeleb päevade-kuude viisi ID-lugejas ning isiku-dokumendina on kaasas autojuhiluba. |
Ei ole viimase aja moevärk. Pea iga päev puutun kokku, kus kliendid ütlevad, et nende ID-kaart on kodus lugejas - seda juba siis 3 aasta jooksul.
| Kommentaarid: 13 loe/lisa |
08.06.2012 12:54:27
Say what?
Oled sa kursis sellega mis toimub id kaardi "sees" kui allkirjastad või autendid?
Krüptograafia ja andmeturve ei ole viimase kümnendi leiutis, selle alustalad ja põhimeetodid on paika pandud juba aastakümned tagasi.
LKits
08.06.2012 13:05:28
Kas ID-kaardi toorel (RAW data) kujul kloonida polegi siis võimalik?
Targad onud ütlevad, et mitte. Reverse engineeringut tahad teha?
Ilma PIN koodideta ja kehtivate sertideta pole ka originaal ID-kaardiga midagi teha.
Oluliselt lihtsam on ID-kaart pihta panna a PIN koodid kuidagi sebida.
(eeldusel, et jõuad midagi nendega teha, enne kui ID-kaart lukku pannakse).
HV-s ID-kaardiga autentimine
viimati muutis Tanel 08.06.2012 13:07:38, muudetud 1 kord |
7 :: |
364 |
08.06.2012 13:07:36
LKits, http://enos.itcollege.ee/~valdo/turve_ohtune/
uuri id kaardi teemad läbi, päris huvitav kursus oli kevadel
LKits
7 :: |
364 |
08.06.2012 13:25:07
| LKits kirjutas: |
Kuna takistus on ainult andmete lugemises, siis olen suhteliselt veendunud, et on olemas ID-kaardi lugeja, mis suudab lugeda absoluutselt kõiki andmeid toorel kujul ning siis tekitada nende andmete põhjal "virtuaalne ID-kaart", mis emuleerib, et too näiks justkui oleks kasutajal füüsiline ID-kaart lugejas.
Tegemist on 100% fiktiivse oletusega, aga reaalsus on see, et sellised seadmed eksisteerivad ning on avalikkuse eest saladuses. |
See asi ei ole isegi unes võimalik, vaata vähem CSI seriaale
ID Kaart on pöördkonstrueeritamatu seade!
priitr
08.06.2012 13:36:52
| LKits kirjutas: |
Ka ID-kaardi kiibi/andmekandja sees toimub pidev andmete muutumine?
Kas ID-kaardi toorel (RAW data) kujul kloonida polegi siis võimalik? |
Ei, kindlasti ei toimu kaardilugejast eraldatud kaardil mingisugust andmete muutumist. Kiipkaart pole ju miskit muud, kui väike väga spetsiifiliste funktstioonidega arvuti, millel on oma operatsioonisüsteem ja millel on väga täpselt fikseeritud keskkonnas töötav(ad) rakendusprogramm(id).
Kaarti kloonimiseks pole vaja teha muud, kui kaardilt välja lugeda andmed, mis on muidu mõeldud kasutamiseks kaardi API (e käsustiku) vahendusel. Ehk välispidiselt öeldakse kaardile 'siin on minu PIN, palun tekita neile andmetele digiallkiri', mille peale kaart kontrollib, et PIN on õige, tekitab sobiva digiallkirja genereerimise keskkonna ja kasutades kunagi kaardile tekitatud privaatvõtit tekitab RSA allkirja ning tagastab selle küsijale. Vahetult privaatvõtit kasutaja kunagi ei näe ja lugeda ei saa. Kaardi klooni tekitamiseks (et kloonitud kaart käituks samade sisendandmete puhul identselt originaaliga) on vaja originaalilt lugeda ka tavaliselt varjatud andmed.
See on aga tänapäevaste krüptokaartide puhul üldjuhul _väga_ keeruline ülesanne. Võitlus ja võidurelvastumine kiipkaarditootjate ja spioonide/varaste vahel on kestnud kiipkaartide laialdasemast kasutuselevõtust kaheksakümnendate alguses ja nagu ikka, vahelduva eduga. Kasutatavaid meetmeid ja vastumeetmeid on kümneid.
Millised meetmed on realiseeritud konkreetselt Eesti ID-kaardi (või tegelikult kaartide) aluseks olevate krüptokaartide kaitseks, ma paraku öelda ei oska. Kindlasti on riigi pädevates organites kodanikke, kes teavad, aga ei ütle. Ja õige kah, milleks kurikaelte jaoks asju lihtsamaks teha.
_________________ Tšudes ne bõvajet. |
| Kommentaarid: 27 loe/lisa |
ThedEviL
08.06.2012 13:46:14
| carlking kirjutas: |
| Betamax kirjutas: |
Eriti head näited on teatud kontingent riigiametnikest kes peavad erinevates registrites kolama ja tööl olles ennast id kaardiga autentima... pmst kaart pannakse hommikul lugejasse ning õhtul või lõunapausi ajal võetakse esimest korda välja  |
Äh. Sa oled optimistlik
Mul on tuttavast riigiametnik kes räägib, et ta ei viitsi id kaarti välja kakkuda ja hoiab koguaeg arvutis.....
Veel kommenteeris et kas kuidagi pin koodi küsimist ei saa ära koristada
97 |
08.06.2012 13:48:20
jajah, nagu mobiili SIM kaardil saab PIN koodi küsimist välja lülitada... soovita talle, et las lõikab ID kaardilt kiibi välja ja paneb mobiili ning seal seadetest võtab PIN1 küsimise maha
ThedEviL
08.06.2012 13:53:02
jajah, nagu mobiili SIM kaardil saab PIN koodi küsimist välja lülitada... soovita talle, et las lõikab ID kaardilt kiibi välja ja paneb mobiili ning seal seadetest võtab PIN1 küsimise maha  |
annan nõu edasi. Ostan sulle 4paki kui ta nii teeb
97 |
08.06.2012 14:03:27
| LKits kirjutas: |
Ei ole viimase aja moevärk. Pea iga päev puutun kokku, kus kliendid ütlevad, et nende ID-kaart on kodus lugejas - seda juba siis 3 aasta jooksul. |
Viimase aja moevärk on hoopis, et ID kaart on naise/mehe käes
| Kommentaarid: 39 loe/lisa |
08.06.2012 14:08:11
| ThedEviL kirjutas: |
| Mul on tuttavast riigiametnik kes räägib, et ta ei viitsi id kaarti välja kakkuda ja hoiab koguaeg arvutis |
Isegi Tanel oli üks nendest, kes hoidis 24/7 ID-kaarti sülearvuti lugejas. Aga tal oli vist mingi kiipkaardiga turvasüsteem sellel arvutil.
571 |
priitr
08.06.2012 14:08:36
Kiipkaartide turvaküsimustest ülevaate saamiseks on täiesti loetav sihuke ülevaade. Plussiks veel see, et kajastab olukorda ajal, kui esimese versiooni Eesti ID-kaart välja tuli.
profs.info.uaic.ro/~fltiplea/IS/Witt2002.pdf
iFlop
08.06.2012 14:45:58
| Aga kui selle Padding Oracle Attack abil saab ID kaardi sees olevad võtmed kätte, siis ei tohiks ju ID kaardi "emuleerimine" enam nii võimatu olla?
66 |
08.06.2012 14:50:48
See seaks siis senise avaliku võtme infrastruktuuri meetodid üldise kahtluse alla. Seega väga vähe usutav, et sellise asjaga ligilähedalegi saadakse.
WäntWõll
make.believe
08.06.2012 15:09:12
Asutustele koos digitaalkinnitusega on minuteada SK-l lahendus olemas, eraiskul ei näe pointi.
300 |
pois11
08.06.2012 15:18:18
| Ma kasutan tihti kahte panka korraga.. nordea ja swedbank... kui olen nordeasse sisse loginud ja välja loginud siis swedbanka sisenemiseks piisab ainult kasutajanimest. Natukene tundub küll ebaturvaline aga samas hea kiire/lihtne.
| Kommentaarid: 113 loe/lisa |
110 |
iFlop
08.06.2012 15:34:26
pois11, WTF??? Mis brauserit sa kasutad? Ning kas see toimib ka siis kui lehed on avatud eraldi tab'idel? Kas on olemas ka mingi ajapiirang, mille jooksul enam ilma PINita sisse logida ei saa?
M-ID puhul õnneks sellist "mugavust" ei ole.
66 |
priitr
08.06.2012 15:37:47
| iFlop kirjutas: |
| Aga kui selle Padding Oracle Attack abil saab ID kaardi sees olevad võtmed kätte, siis ei tohiks ju ID kaardi "emuleerimine" enam nii võimatu olla? |
Nii ja naa. Ütleme nii, et see 'emuleerimine' on väga aeglane ja nõuab originaalse kaardi ja selle PIN1 pidevat olemasolu.
Ei saa võtmeid kätte. Niipaljukest, kui mina sealt kokkuvõtvast jutust välja loen, siis väidavad nad, et siis saad 48-110 tunniga autentimisvõtmega (PIN1) suvalise sõnumi rsa mõttes signeerida, kui lubad kaardil ca 120000-200000 korda toimetada. Ehk siis saad oma internetipanka sisse, kui selle veebiserver nii kaua su allkirja oodata viitsib.
Teadjad parandagu mind, kui valesti aru sain.
JHPnr165
08.06.2012 15:41:25
"peksa on suitsu tahad" ja "lahtihäkkimine" on 5 sekundiga tehtud...ja kui siit veel edasi minna siis õiges kohas olles toimib ka "hääljuhtimine" rahaülekandel ja muudel teenustel paremini kui Siri iföönil ja muudel analoogsetel rakendustel info otsimine netist (neil ei saa isegi pangaülekandeid teha hääljuhtimisega erinevalt "hääljuhtimisest" peale "peksa on suitsu tahad" "häkkimist")
08.06.2012 15:43:18
No täielikku turvalisust ei ole nagunii kunagi võimalik saavutada. Alati on võimalik koheselt ka sertifitseerimiskeskuse teenusnumbrile helistada ja oma sertifikaadid peatada... las mässavad siis selle pin koodi ja kaardiga kui väga tahavad
iFlop
08.06.2012 15:46:11
| priitr kirjutas: |
| iFlop kirjutas: |
Teadjad parandagu mind, kui valesti aru sain. |
ok tänud! Siis ei tohiks esialgu veel mitte midagi hullu olla.
66 |
08.06.2012 15:55:43
| Betamax kirjutas: |
Isegi Tanel oli üks nendest, kes hoidis 24/7 ID-kaarti sülearvuti lugejas. Aga tal oli vist mingi kiipkaardiga turvasüsteem sellel arvutil. |
Hoidmine on üks asi, aga kas ka arvuti terve see aeg sisselülitatud olekus on, on juba teine asi...
pois11
08.06.2012 16:09:12
| iFlop kirjutas: |
M-ID puhul õnneks sellist "mugavust" ei ole. |
Brauserks on internet explorer 9, eraldi tab`e ei ole vist proovinud ja aega pole ka mõõtnu.
110 |
ufo56
08.06.2012 16:22:37
Endal id kaart vedeleb ma ei tea kus laua taga maas, pole digitaalse isikutunnistuse saamisest saadik seda välja võtnud.
Lae pildid -> pilt.io |
| Kommentaarid: 79 loe/lisa |
67 |
WäntWõll
make.believe
08.06.2012 16:31:54
| ufo56 kirjutas: |
| Endal id kaart vedeleb ma ei tea kus laua taga maas, pole digitaalse isikutunnistuse saamisest saadik seda välja võtnud. |
Mis seal vahet on, elektrooniline kasutus on 1:1 oma headuses ja riskidega ID-kaardiga
300 |
LKits
